RTEMS 6.1-rc4
rtems_driver_address_table Struct Reference
This structure contains the device driver entries. More...
#include <io.h>
rtems_device_driver_entry initialization_entry
 This member is the device driver initialization entry.
rtems_device_driver_entry open_entry
 This member is the device driver open entry.
rtems_device_driver_entry close_entry
 This member is the device driver close entry.
rtems_device_driver_entry read_entry
 This member is the device driver read entry.
rtems_device_driver_entry write_entry
 This member is the device driver write entry.
rtems_device_driver_entry control_entry
 This member is the device driver control entry.
This structure is used to register a device driver via rtems_io_register_driver().
Field Documentation
◆ close_entry
rtems_device_driver_entry rtems_driver_address_table::close_entry
This entry is called by rtems_io_close().
◆ control_entry
rtems_device_driver_entry rtems_driver_address_table::control_entry
This entry is called by rtems_io_control().
◆ initialization_entry
rtems_device_driver_entry rtems_driver_address_table::initialization_entry
This entry is called by rtems_io_initialize().
◆ open_entry
rtems_device_driver_entry rtems_driver_address_table::open_entry
This entry is called by rtems_io_open().
◆ read_entry
rtems_device_driver_entry rtems_driver_address_table::read_entry
This entry is called by rtems_io_read().
◆ write_entry
rtems_device_driver_entry rtems_driver_address_table::write_entry
This entry is called by rtems_io_write().
