RTEMS 6.1-rc1
- l -
- l : tte_data
- l0 : SPARC_Minimum_stack_frame
- l0_and_l1 : Context_Control
- l1 : SPARC_Minimum_stack_frame
- l2 : Context_Control, SPARC_Minimum_stack_frame
- l2caccc : l2cache
- l2cc : l2cache
- l2ccb : l2cache
- l2ceinj : l2cache
- l2ceinjcfg : l2cache
- l2cerr : l2cache
- l2cerra : l2cache
- l2cfma : l2cache
- l2cfsi : l2cache
- l2cmtrr : l2cache
- l2cs : l2cache
- l2cscrub : l2cache
- l2csdel : l2cache
- l2ctcb : l2cache
- l3 : Context_Control, SPARC_Minimum_stack_frame
- l4 : Context_Control, SPARC_Minimum_stack_frame
- l5 : Context_Control, SPARC_Minimum_stack_frame
- l6 : Context_Control, SPARC_Minimum_stack_frame
- l7 : Context_Control, SPARC_Minimum_stack_frame
- l_next : link_map
- label : rtems_rtl_archive_symbol, rtems_rtl_loader_format
- land_direction : grgpio
- land_imask : grgpio
- land_output : grgpio
- laneNum : _csi2rx_config
- LAR : DWT_Type, ITM_Type
- largest : Heap_Information
- last : RtemsIntrReqEntryRemove_Context, RtemsSchedulerReqRemoveProcessor_Context
- last_cleanup_context : _Thread_Control
- last_close : rtems_termios_device_handler, sc16is752_context
- last_data_block : _rtems_rfs_inode, rtems_rfs_block_map_s
- last_errno : rtems_rap_data_s, rtems_rtl_data
- last_error : rtems_rap_data_s, rtems_rtl_data
- last_map_block : _rtems_rfs_inode, rtems_rfs_block_map_s
- last_target : ALT_I2C_DEV_s
- last_user_extensions_iterator : _Thread_Control
- LASTEDGE : ENC_Type
- LASTEDGEH : ENC_Type
- LastLinkedListNodeAddress : __MDMA_HandleTypeDef
- lastSckToPcsDelayInNanoSec : _lpspi_master_config
- latchcfg : gptimer
- latest_deadline : Rate_monotonic_Control
- LCCCR : DSI_TypeDef
- LCCR : DSI_TypeDef
- lcd_fb_addr : _isi_Video
- lcd_hsize : _isi_Video
- lcd_nbpp : _isi_Video
- lcd_vsize : _isi_Video
- LCKR : GPIO_TypeDef
- LCOLCR : DSI_TypeDef
- LCOMP : ENC_Type
- lcr : sc16is752_context
- LCVCIDR : DSI_TypeDef
- LDO_LPSR_ANA_BYPASS_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_ANA_ENABLE_SP : ANADIG_PMU_Type
- LDO_LPSR_ANA_LP_MODE_SP : ANADIG_PMU_Type
- LDO_LPSR_ANA_STBY_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_ANA_TRACKING_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_BYPASS_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_ENABLE_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_LP_MODE_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_STBY_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_TRACKING_EN_SP : ANADIG_PMU_Type
- LDO_LPSR_DIG_TRG_SP0 : ANADIG_PMU_Type
- LDO_LPSR_DIG_TRG_SP1 : ANADIG_PMU_Type
- LDO_LPSR_DIG_TRG_SP2 : ANADIG_PMU_Type
- LDO_LPSR_DIG_TRG_SP3 : ANADIG_PMU_Type
- LDO_PLL_ENABLE_SP : ANADIG_PMU_Type
- LDVAL : PIT_Type
- left : rtems_bdbuf_buffer::rtems_bdbuf_avl_node
- LeftBitShift : ADC_InitTypeDef
- leftData : _spdif_edma_transfer
- LeftDelay : SAIEx_PdmMicDelayParamTypeDef
- leftTcd : _spdif_edma_handle
- legacy_device_context : rtems_termios_tty
- len : _GmacTxDescriptor::_GmacTxStatus::_GmacTxStatusBM, i2c_msg, mmap_mappings_s, spi_ioc_transfer, stm32f4_i2c_message
- length : _enet_buffer_struct, _enet_rx_bd_struct, _enet_tx_bd_struct, _flexcan_frame, _Regulator_Message_t, bfin_uart_channel_t, Dual_ported_memory_Control, MP_packet_Prefix, rtems_blkdev_sg_buffer, rtems_rtl_rap, rtems_rtl_unresolv_symbol, rtl_unresolved_name_data
- Length : XNandPsu_BadBlockPattern
- length_param : RtemsRatemonReqPeriod_Context
- level : _pwm_signal_param, drvmgr_bus, drvmgr_dev, rtems_debugger_block, rtems_rtl_obj_cache, rtems_rtl_obj_cpmp
- libc_reent : _Thread_Control
- LIFCR : DMA_TypeDef
- Life : _Thread_Control
- lifetime_allocated : Heap_Statistics
- lifetime_freed : Heap_Statistics
- limit : AArch32_PMSA_Region
- limit_address : Partition_Control
- LinBlueFieldPosition : RTEMS_PACKED
- LinBlueMaskSize : RTEMS_PACKED
- LinBytesPerScanLine : RTEMS_PACKED
- Line : EXTI_ConfigTypeDef, EXTI_HandleTypeDef
- line : rtems_assert_context
- lineOrder : _lcdifv2_display_config
- linePitch_Bytes : _csi_config
- LinGreenFieldPosition : RTEMS_PACKED
- LinGreenMaskSize : RTEMS_PACKED
- LINIT : ENC_Type
- link : _rtems_rfs_file_shared, _rtems_rfs_inode_handle, rtems_bdbuf_buffer, rtems_bdbuf_group, rtems_bdbuf_swapout_worker, rtems_rtl_obj, rtems_rtl_obj_sect, rtems_rtl_unresolv_block
- LinkedListNodeCounter : __MDMA_HandleTypeDef
- linkmap : rtems_rtl_obj
- links : _rtems_rfs_inode
- linkTransfer : _pdm_edma_transfer
- LinNumberOfImagePages : RTEMS_PACKED
- LinRedFieldPosition : RTEMS_PACKED
- LinRedMaskSize : RTEMS_PACKED
- LinRsvdFieldPosition : RTEMS_PACKED
- LinRsvdMaskSize : RTEMS_PACKED
- LIPCR : LTDC_TypeDef
- LISR : DMA_TypeDef
- LMDR : MCM_Type
- LMFAR : MCM_Type
- LMFATR : MCM_Type
- LMFDHR : MCM_Type
- LMFDLR : MCM_Type
- LMOD : ENC_Type
- LMPECR : MCM_Type
- LMPEIR : MCM_Type
- lo : bsp_tlb_entry_t
- load : rtems_rtl_loader_table
- LOAD : SysTick_Type, TMR_Type
- load_order : rtems_rtl_obj_sect
- loader : rtems_rtl_obj
- loads : _rtems_rfs_inode_handle
- LoadToActiveDelay : FMC_SDRAM_TimingTypeDef
- local : SPARC_Register_window
- local_size : rtems_rtl_obj
- local_syms : rtems_rtl_obj
- local_table : Objects_Information, rtems_rtl_obj
- location : ALT_I2C_DEV_s, rtems_flashdev_ioctl_page_info, rtems_ramdisk_config
- Lock : __DMA_HandleTypeDef, __I2C_HandleTypeDef, __I2S_HandleTypeDef, __MDMA_HandleTypeDef, __SAI_HandleTypeDef, __SMARTCARD_HandleTypeDef, __SPI_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef
- lock : _dcic_region_config, _rdc_domain_assignment, _rdc_mem_access_config, _rdc_periph_access_config, _xrdc2_master_domain_assignment
- Lock : ADC_HandleTypeDef, COMP_HandleTypeDef, CRC_HandleTypeDef
- LOCK : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- Lock : FLASH_ProcessTypeDef, IRDA_HandleTypeDef, MMC_HandleTypeDef, NAND_HandleTypeDef, NOR_HandleTypeDef
- LOCK : OCOTP_Type
- Lock : OPAMP_HandleTypeDef, RTC_HandleTypeDef
- lock : rtems_bdbuf_cache, rtems_fdt_data, rtems_flashdisk, rtems_nvdisk, rtems_rap_data_s, rtems_rtl_data, rtems_stdio_redirect
- Lock : SD_HandleTypeDef, SDRAM_HandleTypeDef, SMBUS_HandleTypeDef, SRAM_HandleTypeDef, SWPMI_HandleTypeDef, TIM_HandleTypeDef
- LOCK_BYP : DSI_HOST_NXP_FDSOI28_DPHY_INTFC_Type
- lock_context : ScoreSchedSmpValSmp_Context
- Lock_context : Thread_queue_Context, Thread_queue_Lock_context
- lock_line_en : L2CC
- lockAssignList : _src_domain_mode_authentication
- lockControl : _domain_slot_config
- lockdown : gr740_iopll
- LOCKED0 : OCOTP_Type
- LOCKED1 : OCOTP_Type
- LOCKED2 : OCOTP_Type
- LOCKED3 : OCOTP_Type
- LOCKED4 : OCOTP_Type
- LockLevel : TIM_BreakDeadTimeConfigTypeDef
- lockList : _domain_slot_config
- lockMode : _xrdc2_mem_access_config, _xrdc2_mem_slot_access_config, _xrdc2_periph_access_config
- lockSetting : _src_setpoint_authentication
- lockWhiteList : _src_setpoint_authentication
- LogBlockNbr : HAL_MMC_CardInfoTypeDef, HAL_SD_CardInfoTypeDef
- LogBlockSize : HAL_MMC_CardInfoTypeDef, HAL_SD_CardInfoTypeDef
- login_buffer : rtems_user_env_t
- login_check : rtems_telnetd_config_table
- Lookup_node : POSIX_Keys_Key_value_pair
- lookupMode : _pxp_lut_config
- lookupTable : _flexspi_mem_config, _FlexSPIConfig
- loopback : DacCmd
- LOOPBACK : USB_ANALOG_Type
- LOOPBACK_CLR : USB_ANALOG_Type
- LOOPBACK_SET : USB_ANALOG_Type
- LOOPBACK_TOG : USB_ANALOG_Type
- loopCount : lpadc_conv_command_config_t
- loopCountIndex : lpadc_conv_result_t
- loopDivider : _clock_arm_pll_config, _clock_audio_pll_config, _clock_audio_pll_gpc_config, _clock_enet_pll_config, _clock_sys_pll_config, _clock_usb_pll_config, _clock_video_pll_config
- loopDivider1 : _clock_enet_pll_config
- lor_direction : grgpio
- lor_imask : grgpio
- lor_output : grgpio
- lowAlarmTemp : _tempmon_config, _tmpsns_config
- LowBreakSignal : DFSDM_Filter_AwdParamTypeDef
- lower_wrprot_block : ALT_QSPI_DEV_SIZE_CONFIG_s
- lowerRightX : _dcic_region_config
- lowerRightY : _dcic_region_config
- lowestAddress : _ssarc_group_config
- LowPowerAutoWait : ADC_InitTypeDef
- lowpowerMap : _dcdc_setpoint_config
- LOWPWR_CTRL : XTALOSC24M_Type
- LOWPWR_CTRL_CLR : XTALOSC24M_Type
- LOWPWR_CTRL_SET : XTALOSC24M_Type
- LOWPWR_CTRL_TOG : XTALOSC24M_Type
- LowThreshold : ADC_AnalogWDGConfTypeDef, DFSDM_Filter_AwdParamTypeDef
- LPATCLKR : SNVS_Type
- LPATCR : SNVS_Type
- LPATCTLR : SNVS_Type
- LPATRC1R : SNVS_Type
- LPATRC2R : SNVS_Type
- LPCR : DSI_TypeDef, SNVS_Type
- lpf : spwtdp
- LPGPR : SNVS_Type
- LPGPR0_LEGACY_ALIAS : SNVS_Type
- LPGPR_ALIAS : SNVS_Type
- LPLR : SNVS_Type
- LPLVDR : SNVS_Type
- LPMCCR : DSI_TypeDef
- LPMCR : DSI_TypeDef
- LPMKCR : SNVS_Type
- LPOS : ENC_Type
- LPOSH : ENC_Type
- LPSECR : SNVS_Type
- LPSMCLR : SNVS_Type
- LPSMCMR : SNVS_Type
- lpspiSoftwareTCD : _lpspi_master_edma_handle, _lpspi_slave_edma_handle
- LPSR : SNVS_Type
- LPSR_1P8_LDO_OTP_TRIM_VALUE : ANADIG_PMU_Type
- LPSRTCLR : SNVS_Type
- LPSRTCMR : SNVS_Type
- LPSVCR : SNVS_Type
- LPTAR : SNVS_Type
- LPTDC2R : SNVS_Type
- LPTDCR : SNVS_Type
- LPTDSR : SNVS_Type
- LPTGF1CR : SNVS_Type
- LPTGF2CR : SNVS_Type
- LPTGFCR : SNVS_Type
- Lptim1ClockSelection : RCC_PeriphCLKInitTypeDef
- Lptim2ClockSelection : RCC_PeriphCLKInitTypeDef
- Lptim345ClockSelection : RCC_PeriphCLKInitTypeDef
- LPTR : OCTOSPI_TypeDef, QUADSPI_TypeDef
- Lpuart1ClockSelection : RCC_PeriphCLKInitTypeDef
- LPZMKR : SNVS_Type
- lru : rtems_bdbuf_cache
- lrunstat : grspwrouter
- lrxHostTo_ByteClk : _dsi_config
- lsb_first : spi_bus
- LSEState : RCC_OscInitTypeDef
- LSIState : RCC_OscInitTypeDef
- LSR : DWT_Type, ITM_Type
- LSUCNT : DWT_Type
- LTMR64H : PIT_Type
- LTMR64L : PIT_Type
- LTR1 : ADC_TypeDef
- LTR1_TR1 : ADC_TypeDef
- LTR2 : ADC_TypeDef
- LTR2_DIFSEL : ADC_TypeDef
- LTR3 : ADC_TypeDef
- LTR3_RES10 : ADC_TypeDef
- LUT : FLEXSPI_Type, GFXMMU_TypeDef
- LUT0_ADDR : LCDIF_Type
- LUT0_DATA : LCDIF_Type
- LUT1_ADDR : LCDIF_Type
- LUT1_DATA : LCDIF_Type
- LUT_CTRL : LCDIF_Type
- LUTCR : FLEXSPI_Type
- lutCustomSeq : _flexspi_mem_config, _FlexSPIConfig
- lutCustomSeqEnable : _flexspi_mem_config, _FlexSPIConfig
- LUTKEY : FLEXSPI_Type
- lutMode : _pxp_dither_config
- LVCIDR : DSI_TypeDef
- lvdsmclk : gr740_iopll
- LWR : DMA2D_TypeDef
- lxor_direction : grgpio
- lxor_imask : grgpio
- lxor_output : grgpio
