RTEMS 6.1-rc1
Telnet configuration structure. More...
#include <telnetd.h>
Data Fields | |
rtems_telnetd_command | command |
Function invoked for each Telnet connection. More... | |
void * | arg |
Argument for command function. | |
rtems_task_priority | priority |
Task priority. More... | |
size_t | stack_size |
Task stack size. More... | |
rtems_shell_login_check_t | login_check |
Login check function. More... | |
bool | keep_stdio |
This is an obsolete configuration option. More... | |
uint16_t | client_maximum |
Maximum number of clients which can connect to the system at a time. More... | |
uint16_t | port |
Server port number in host byte order. More... | |
uint16_t rtems_telnetd_config_table::client_maximum |
Use 0 for the default value.
rtems_telnetd_command rtems_telnetd_config_table::command |
The first parameter contains the device name. The second parameter contains the argument pointer of this configuration table.
bool rtems_telnetd_config_table::keep_stdio |
It must be set to false, otherwise rtems_telnetd_start() will do nothing and returns with a status of RTEMS_NOT_IMPLEMENTED.
rtems_shell_login_check_t rtems_telnetd_config_table::login_check |
Method used for login checks. Use NULL
to disable a login check.
uint16_t rtems_telnetd_config_table::port |
rtems_task_priority rtems_telnetd_config_table::priority |
Task priority.
size_t rtems_telnetd_config_table::stack_size |
Task stack size.
