RTEMS 6.1-rc1
Data Structures | Enumerator | Variables
Key_manager
struct  _domain_slot_config
 Key Manager slot configuration structure. More...
keymgr_lock_t _domain_slot_config::lockControl
keymgr_allow_t _domain_slot_config::allowUser
keymgr_allow_t _domain_slot_config::allowNonSecure
keymgr_lock_t _domain_slot_config::lockList
uint8_t _domain_slot_config::whiteList
Driver version
enum  _keymgr_lock { kKEYMGR_Unlock = 0u , kKEYMGR_Lock = 1u }
enum  _keymgr_allow { kKEYMGR_Disallow = 0u , kKEYMGR_Allow = 1u }
enum  _keymgr_slot {
  kKEYMGR_Slot0 = 0u , kKEYMGR_Slot1 = 1u , kKEYMGR_Slot2 = 2u , kKEYMGR_Slot3 = 3u ,
  kKEYMGR_Slot4 = 4u
typedef enum _keymgr_lock keymgr_lock_t
typedef enum _keymgr_allow keymgr_allow_t
typedef enum _keymgr_slot keymgr_slot_t
typedef struct _domain_slot_config domain_slot_config_t
status_t KEYMGR_MasterKeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock)
 Configures Master key settings. More...
status_t KEYMGR_OTFAD1KeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock)
 Configures OTFAD1 key settings. More...
status_t KEYMGR_OTFAD2KeyControll (KEY_MANAGER_Type *base, keymgr_select_t select, keymgr_lock_t lock)
 Configures OTFAD2 key settings. More...
void KEYMGR_IEEKeyReload (KEY_MANAGER_Type *base)
 Restart load key signal for IEE. More...
void KEYMGR_PUFKeyLock (KEY_MANAGER_Type *base, keymgr_lock_t lock)
 Lock the key select from PUF. More...
status_t KEYMGR_SlotControl (KEY_MANAGER_Type *base, domain_slot_config_t *config, keymgr_slot_t slot)
 Configures Slot Domain control. More...
void KEYMGR_Init (KEY_MANAGER_Type *base)
 Resets Key Manager module to factory default values. More...
status_t KEYMGR_GetDefaultConfig (domain_slot_config_t *config)
 Sets the default configuration of Key manager slot. More...
#define FSL_KEYMGR_DRIVER_VERSION   (MAKE_VERSION(2, 0, 2))
 Key Manager driver version. Version 2.0.2. More...
#define KEYMGR_IEE_RELOAD   1u
#define KEYMGR_SEL_OCOTP   0u
#define KEYMGR_SEL_UDF   0u
#define KEYMGR_SEL_PUF   1u
#define keymgr_select_t   uint8_t
◆ FSL_KEYMGR_DRIVER_VERSION
Current version: 2.0.2
Change log:
  • Version 2.0.2
    • Fix MISRA-2012 issues
  • Version 2.0.1
  • Version 2.0.0
    • Initial version
◆ KEYMGR_GetDefaultConfig()
status_t KEYMGR_GetDefaultConfig ( domain_slot_config_t config)
This function initialize Key Manager slot config structure to default values.
Parameters
configPointer to slot configuration structure.
brief Sets the default configuration of Key manager slot.
param config Pointer to slot configuration structure.
◆ KEYMGR_IEEKeyReload()
void KEYMGR_IEEKeyReload ( KEY_MANAGER_Type base)
This function genrates Key Manager's restart signal for IEE key.
Parameters
baseKey Manager peripheral address.
brief Restart load key signal for IEE.
param base Key Manager peripheral address.
◆ KEYMGR_Init()
void KEYMGR_Init ( KEY_MANAGER_Type base)
This function performs hardware reset of Key Manager module.
Parameters
brief Enables clock for Key Manager module.
This function enables clocks for Key Manager module.
◆ KEYMGR_MasterKeyControll()
status_t KEYMGR_MasterKeyControll ( KEY_MANAGER_Type base,
keymgr_lock_t  lock
This function configures Key Manager's setting for Master key.
Parameters
selectselect source for Master key.
locksetting for lock Master key.
Returns
status of Master key control operation
brief Configures Master key settings.
param base Key Manager peripheral address. param select select source for Master key. param lock setting for lock Master key. return status of Master key control operation
◆ KEYMGR_OTFAD1KeyControll()
status_t KEYMGR_OTFAD1KeyControll ( KEY_MANAGER_Type base,
keymgr_lock_t  lock
This function configures Key Manager's setting for OTFAD1 key.
Parameters
selectselect source for OTFAD1 key.
locksetting for lock OTFAD1 key.
Returns
status of OTFAD1 key control operation
brief Configures OTFAD1 key settings.
param base Key Manager peripheral address. param select select source for OTFAD1 key. param lock setting for lock OTFAD1 key. return status of OTFAD1 key control operation
◆ KEYMGR_OTFAD2KeyControll()
status_t KEYMGR_OTFAD2KeyControll ( KEY_MANAGER_Type base,
keymgr_lock_t  lock
This function configures Key Manager's setting for OTFAD2 key.
Parameters
selectselect source for OTFAD2 key.
locksetting for lock OTFAD2 key.
Returns
status of OTFAD2 key control operation
brief Configures OTFAD2 key settings.
param base Key Manager peripheral address. param select select source for OTFAD2 key. param lock setting for lock OTFAD2 key. return status of OTFAD2 key control operation
◆ KEYMGR_PUFKeyLock()
void KEYMGR_PUFKeyLock ( KEY_MANAGER_Type base,
keymgr_lock_t  lock
This function locks selection of key for PUF.
Parameters
lockSetting for selection of key for PUF.
brief Lock the key select from PUF.
◆ KEYMGR_SlotControl()
status_t KEYMGR_SlotControl ( KEY_MANAGER_Type base,
domain_slot_config_t config,
keymgr_slot_t  slot
This function configures domain slot control which locks and allows writes.
Parameters
slotSelect slot to be configured.
Returns
status of slot control operation
brief Configures Slot Domain control.
param base Key Manager peripheral address. param config Pointer to slot configuration structure. param slot Select slot to be configured.
Variable Documentation
◆ allowNonSecure
Allow non-secure write access to domain control register or domain register.
◆ allowUser
Allow user write access to domain control register or domain register.
◆ lockControl
Lock control register of slot.
◆ lockList
Lock whitelist. SLOTx_CTRL[WHITE_LIST] cannot be changed.
◆ whiteList
Domains that on the Whitelist can change given slot. Each field represents one domain. Bit0~Bit3 represent DOMAIN0~DOMAIN3 respectively.
