RTEMS 6.1-rc1
Thread register context. More...
#include <cpu.h>
uint64_t register_x19
uint64_t register_x20
uint64_t register_x21
uint64_t register_x22
uint64_t register_x23
uint64_t register_x24
uint64_t register_x25
uint64_t register_x26
uint64_t register_x27
uint64_t register_x28
uint64_t register_fp
uint64_t register_lr
uint64_t register_sp
uint64_t isr_dispatch_disable
 This member is used for the external interrupt controller (EIC) support. More...
uint64_t thread_id
void * register_sp
uint32_t thread_id
uint32_t register_r4
uint32_t register_r5
uint32_t register_r6
uint32_t register_r7
uint32_t register_p3
uint32_t register_p4
uint32_t register_p5
uint32_t register_fp
uint32_t register_sp
uint32_t register_rets
uint32_t imask
uint32_t eflags
void * esp
void * ebp
uint32_t ebx
uint32_t esi
uint32_t edi
segment_descriptors gs
uint32_t isr_dispatch_disable
uint32_t r11
uint32_t r12
uint32_t r13
uint32_t r14
uint32_t r15
uint32_t r16
uint32_t r17
uint32_t r18
uint32_t r19
uint32_t r20
uint32_t r21
uint32_t r22
uint32_t r23
uint32_t r24
uint32_t r25
uint32_t gp
uint32_t fp
uint32_t sp
uint32_t ra
uint32_t ie
uint32_t epc
uint32_t sr
uint32_t d2
uint32_t d3
uint32_t d4
uint32_t d5
uint32_t d6
uint32_t d7
void * a2
void * a3
void * a4
void * a5
void * a6
void * a7_msp
void * thread_pointer
uint32_t r1
uint32_t r26
uint32_t r27
uint32_t r28
uint32_t r29
uint32_t r30
uint32_t r31
uint32_t rmsr
__MIPS_REGISTER_TYPE s0
__MIPS_REGISTER_TYPE s1
__MIPS_REGISTER_TYPE s2
__MIPS_REGISTER_TYPE s3
__MIPS_REGISTER_TYPE s4
__MIPS_REGISTER_TYPE s5
__MIPS_REGISTER_TYPE s6
__MIPS_REGISTER_TYPE s7
__MIPS_REGISTER_TYPE sp
__MIPS_REGISTER_TYPE fp
__MIPS_REGISTER_TYPE ra
__MIPS_REGISTER_TYPE c0_sr
__MIPS_REGISTER_TYPE c0_epc
void *fp nogap
void *sp nogap
uint32_t r0 nogap
uint32_t r1 nogap
uint32_t r2 nogap
uint32_t r3 nogap
uint32_t r4 nogap
uint32_t r5 nogap
uint32_t r6 nogap
uint32_t r7 nogap
uint32_t r8 nogap
uint32_t r9 nogap
uint32_t r10 nogap
uint32_t r11 nogap
uint32_t r12 nogap
uint32_t r13 nogap
uint32_t status
uint32_t stack_mpubase
uint32_t stack_mpuacc
uint32_t some_integer_register
uint32_t some_system_register
uint32_t stack_pointer
uint32_t r2
uint32_t r3
uint32_t r4
uint32_t r5
uint32_t r6
uint32_t r7
uint32_t r8
uint32_t r9
uint32_t r10
uint32_t epcr
uint32_t eear
uint32_t esr
uint8_t context [PPC_DEFAULT_CACHE_LINE_SIZE+sizeof(ppc_context)+(sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE==0 ? 0 :PPC_DEFAULT_CACHE_LINE_SIZE - sizeof(ppc_context) % PPC_DEFAULT_CACHE_LINE_SIZE)]
uint32_t reserved
uintptr_t ra
uintptr_t sp
uintptr_t tp
uintptr_t s0
uintptr_t s1
uintptr_t s2
uintptr_t s3
uintptr_t s4
uintptr_t s5
uintptr_t s6
uintptr_t s7
uintptr_t s8
uintptr_t s9
uintptr_t s10
uintptr_t s11
uint32_t * r15
uint32_t macl
uint32_t mach
uint32_t * pr
uint32_t * r14
uint32_t * r7
uint32_t * r6
uint32_t * r3
uint32_t * r2
uint32_t * r1
uint32_t * r0
uint32_t gbr
uint32_t g5
uint32_t g7
double l0_and_l1
uint32_t l2
uint32_t l3
uint32_t l4
uint32_t l5
uint32_t l6
uint32_t l7
uint32_t i0
uint32_t i1
uint32_t i2
uint32_t i3
uint32_t i4
uint32_t i5
uint32_t i6_fp
uint32_t i7
uint32_t o6_sp
uint32_t o7
uint32_t psr
uint64_t g1
uint64_t g2
uint64_t g3
uint64_t g4
uint64_t g5
uint64_t g6
uint64_t g7
uint64_t l0
uint64_t l1
uint64_t l2
uint64_t l3
uint64_t l4
uint64_t l5
uint64_t l6
uint64_t l7
uint64_t i0
uint64_t i1
uint64_t i2
uint64_t i3
uint64_t i4
uint64_t i5
uint64_t i6_fp
uint64_t i7
uint64_t o0
uint64_t o1
uint64_t o2
uint64_t o3
uint64_t o4
uint64_t o5
uint64_t o6_sp
uint64_t o7
uint32_t pad
uint32_t r3_stack_pointer
uint32_t psw
uint64_t rflags
uint64_t rbx
void * rsp
void * rbp
uint64_t r12
uint64_t r13
uint64_t r14
uint64_t r15
SPARC basic context.
This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another.
The thread register context covers the non-volatile registers, the thread stack pointer, the return address, and the processor status.
There is no need to save the global pointer (gp) since it is a system wide constant and set-up with the C runtime environment.
This structure defines the non-volatile integer and processor state context for the SPARC architecture according to "SYSTEM V APPLICATION BINARY INTERFACE - SPARC Processor Supplement", Third Edition.
The registers g2 through g4 are reserved for applications. GCC uses them as volatile registers by default. So they are treated like volatile registers in RTEMS as well.
The register g6 contains the per-CPU control of the current processor. It is an invariant of the processor context. This register must not be saved and restored during context switches or interrupt services.
Field Documentation
◆ g5
uint32_t Context_Control::g5
This will contain the contents of the g5 register.
◆ g7
uint32_t Context_Control::g7
This will contain the contents of the g7 register.
◆ i0
uint32_t Context_Control::i0
This will contain the contents of the i0 register.
◆ i1
uint32_t Context_Control::i1
This will contain the contents of the i1 register.
◆ i2
uint32_t Context_Control::i2
This will contain the contents of the i2 register.
◆ i3
uint32_t Context_Control::i3
This will contain the contents of the i3 register.
◆ i4
uint32_t Context_Control::i4
This will contain the contents of the i4 register.
◆ i5
uint32_t Context_Control::i5
This will contain the contents of the i5 register.
◆ i6_fp
uint32_t Context_Control::i6_fp
This will contain the contents of the i6 (e.g. frame pointer) register.
◆ i7
uint32_t Context_Control::i7
This will contain the contents of the i7 register.
◆ isr_dispatch_disable [1/2]
uint32_t Context_Control::isr_dispatch_disable
It corresponds to Per_CPU_Control::isr_dispatch_disable.
This field is used to prevent heavy nesting of calls to _Thread_Dispatch on an interrupted task's stack. This is problematic on the slower SPARC CPU models at high interrupt rates.
◆ isr_dispatch_disable [2/2]
◆ l0_and_l1
double Context_Control::l0_and_l1
This will contain the contents of the l0 and l1 registers.
Using a double l0_and_l1 will put everything in this structure on a double word boundary which allows us to use double word loads and stores safely in the context switch.
◆ l2
uint32_t Context_Control::l2
This will contain the contents of the l2 register.
◆ l3
uint32_t Context_Control::l3
This will contain the contents of the l3 register.
◆ l4
uint32_t Context_Control::l4
This will contain the contents of the l4 register.
◆ l5
uint32_t Context_Control::l5
This will contain the contents of the l5 registeer.
◆ l6
uint32_t Context_Control::l6
This will contain the contents of the l6 register.
◆ l7
uint32_t Context_Control::l7
This will contain the contents of the l7 register.
◆ o6_sp
uint32_t Context_Control::o6_sp
This will contain the contents of the o6 (e.g. frame pointer) register.
◆ o7
uint32_t Context_Control::o7
This will contain the contents of the o7 (e.g. address of CALL instruction) register.
◆ psr
uint32_t Context_Control::psr
This will contain the contents of the processor status register.
◆ r3_stack_pointer
uint32_t Context_Control::r3_stack_pointer
This field is the stack pointer (e.g. r3).
◆ rbx
uint64_t Context_Control::rbx
Callee-saved registers as listed in the SysV ABI document: https://github.com/hjl-tools/x86-psABI/wiki/X86-psABI
◆ some_integer_register
uint32_t Context_Control::some_integer_register
This field is a hint that a port will have a number of integer registers that need to be saved at a context switch.
◆ some_system_register
uint32_t Context_Control::some_system_register
This field is a hint that a port will have a number of system registers that need to be saved at a context switch.
◆ stack_pointer
uint32_t Context_Control::stack_pointer
This field is a hint that a port will have a register that is the stack pointer.
The documentation for this struct was generated from the following files:
