RTEMS 6.1-rc1
Data Structures | Enumerator | Variables
Lcdifv2
struct  _lcdifv2_display_config
 LCDIF v2 display configure structure. More...
struct  _lcdifv2_buffer_config
 LCDIF v2 source buffer configuration. More...
struct  _lcdifv2_blend_config
 LCDIF v2 layer alpha blending configuration. More...
uint16_t _lcdifv2_display_config::panelWidth
uint16_t _lcdifv2_display_config::panelHeight
uint8_t _lcdifv2_display_config::hsw
uint8_t _lcdifv2_display_config::hfp
uint8_t _lcdifv2_display_config::hbp
uint8_t _lcdifv2_display_config::vsw
uint8_t _lcdifv2_display_config::vfp
uint8_t _lcdifv2_display_config::vbp
uint32_t _lcdifv2_display_config::polarityFlags
lcdifv2_line_order_t _lcdifv2_display_config::lineOrder
uint16_t _lcdifv2_buffer_config::strideBytes
lcdifv2_pixel_format_t _lcdifv2_buffer_config::pixelFormat
uint8_t _lcdifv2_blend_config::globalAlpha
lcdifv2_alpha_mode_t _lcdifv2_blend_config::alphaMode
lcdifv2_pd_alpha_mode_t _lcdifv2_blend_config::pdAlphaMode
lcdifv2_pd_color_mode_t _lcdifv2_blend_config::pdColorMode
lcdifv2_pd_global_alpha_mode_t _lcdifv2_blend_config::pdGlobalAlphaMode
lcdifv2_pd_factor_mode_t _lcdifv2_blend_config::pdFactorMode
Driver version
enum  _lcdifv2_polarity_flags {
  kLCDIFV2_VsyncActiveHigh = 0U , kLCDIFV2_HsyncActiveHigh = 0U , kLCDIFV2_DataEnableActiveHigh = 0U , kLCDIFV2_DriveDataOnRisingClkEdge = 0U ,
  kLCDIFV2_DataActiveHigh = 0U , kLCDIFV2_VsyncActiveLow = LCDIFV2_CTRL_INV_VS_MASK , kLCDIFV2_HsyncActiveLow = LCDIFV2_CTRL_INV_HS_MASK , kLCDIFV2_DataEnableActiveLow = LCDIFV2_CTRL_INV_DE_MASK ,
  kLCDIFV2_DriveDataOnFallingClkEdge = LCDIFV2_CTRL_INV_PXCK_MASK , kLCDIFV2_DataActiveLow = LCDIFV2_CTRL_NEG_MASK
 LCDIF v2 signal polarity flags. More...
enum  _lcdifv2_interrupt {
  kLCDIFV2_Layer0FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(0) , kLCDIFV2_Layer1FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(1) , kLCDIFV2_Layer2FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(2) , kLCDIFV2_Layer3FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(3) ,
  kLCDIFV2_Layer4FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(4) , kLCDIFV2_Layer5FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(5) , kLCDIFV2_Layer6FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(6) , kLCDIFV2_Layer7FifoEmptyInterrupt = LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(7) ,
  kLCDIFV2_Layer0DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(0) , kLCDIFV2_Layer1DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(1) , kLCDIFV2_Layer2DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(2) , kLCDIFV2_Layer3DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(3) ,
  kLCDIFV2_Layer4DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(4) , kLCDIFV2_Layer5DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(5) , kLCDIFV2_Layer6DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(6) , kLCDIFV2_Layer7DmaDoneInterrupt = LCDIFV2_MAKE_DMA_DONE_INTERRUPT(7) ,
  kLCDIFV2_Layer0DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(0) , kLCDIFV2_Layer1DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(1) , kLCDIFV2_Layer2DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(2) , kLCDIFV2_Layer3DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(3) ,
  kLCDIFV2_Layer4DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(4) , kLCDIFV2_Layer5DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(5) , kLCDIFV2_Layer6DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(6) , kLCDIFV2_Layer7DmaErrorInterrupt = LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(7) ,
  kLCDIFV2_VerticalBlankingInterrupt = (1U << 2U) , kLCDIFV2_OutputUnderrunInterrupt = (1U << 1U) , kLCDIFV2_VsyncEdgeInterrupt = (1U << 0U)
 The LCDIF v2 interrupts. More...
enum  _lcdifv2_line_order {
  kLCDIFV2_LineOrderRGB = 0 , kLCDIFV2_LineOrderRBG , kLCDIFV2_LineOrderGBR , kLCDIFV2_LineOrderGRB ,
  kLCDIFV2_LineOrderBRG , kLCDIFV2_LineOrderBGR
 The LCDIF v2 output line order. More...
enum  _lcdifv2_csc_mode { kLCDIFV2_CscDisable = 0U , kLCDIFV2_CscYUV2RGB , kLCDIFV2_CscYCbCr2RGB }
 LCDIF v2 color space conversion mode. More...
enum  _lcdifv2_pixel_format {
  kLCDIFV2_PixelFormatIndex1BPP = LCDIFV2_CTRLDESCL5_BPP(0U) , kLCDIFV2_PixelFormatIndex2BPP = LCDIFV2_CTRLDESCL5_BPP(1U) , kLCDIFV2_PixelFormatIndex4BPP = LCDIFV2_CTRLDESCL5_BPP(2U) , kLCDIFV2_PixelFormatIndex8BPP = LCDIFV2_CTRLDESCL5_BPP(3U) ,
  kLCDIFV2_PixelFormatRGB565 = LCDIFV2_CTRLDESCL5_BPP(4U) , kLCDIFV2_PixelFormatARGB1555 = LCDIFV2_CTRLDESCL5_BPP(5U) , kLCDIFV2_PixelFormatARGB4444 = LCDIFV2_CTRLDESCL5_BPP(6U) , kLCDIFV2_PixelFormatUYVY ,
  kLCDIFV2_PixelFormatVYUY , kLCDIFV2_PixelFormatYUYV , kLCDIFV2_PixelFormatYVYU , kLCDIFV2_PixelFormatRGB888 = LCDIFV2_CTRLDESCL5_BPP(8U) ,
  kLCDIFV2_PixelFormatARGB8888 = LCDIFV2_CTRLDESCL5_BPP(9U) , kLCDIFV2_PixelFormatABGR8888 = LCDIFV2_CTRLDESCL5_BPP(10U)
 LCDIF v2 pixel format. More...
enum  _lcdifv2_alpha_mode { kLCDIFV2_AlphaDisable , kLCDIFV2_AlphaOverride , kLCDIFV2_AlphaEmbedded , kLCDIFV2_AlphaPoterDuff }
 LCDIF v2 layer alpha blending mode. More...
enum  _lcdifv2_pd_alpha_mode { kLCDIFV2_PD_AlphaStraight = 0 , kLCDIFV2_PD_AlphaInversed = 1 }
 LCDIF v2 PoterDuff alpha mode. More...
enum  _lcdifv2_pd_color_mode { kLCDIFV2_PD_ColorNoAlpha = 0 , kLCDIFV2_PD_ColorWithAlpha = 1 }
 LCDIF v2 PoterDuff color mode. More...
enum  _lcdifv2_pd_global_alpha_mode { kLCDIFV2_PD_GlobalAlpha = 0 , kLCDIFV2_PD_LocalAlpha = 1 , kLCDIFV2_PD_ScaledAlpha = 2 }
 LCDIF v2 PoterDuff global alpha mode. More...
enum  _lcdifv2_pd_factor_mode { kLCDIFV2_PD_FactorOne = 0 , kLCDIFV2_PD_FactorZero = 1 , kLCDIFV2_PD_FactorStraightAlpha = 2 , kLCDIFV2_PD_FactorInversedAlpha = 3 }
 LCDIF v2 PoterDuff factor mode. More...
enum  _lcdifv2_pd_blend_mode {
  kLCDIFV2_PD_Src = 0 , kLCDIFV2_PD_Atop , kLCDIFV2_PD_Over , kLCDIFV2_PD_In ,
  kLCDIFV2_PD_Out , kLCDIFV2_PD_Dst , kLCDIFV2_PD_DstAtop , kLCDIFV2_PD_DstOver ,
  kLCDIFV2_PD_DstIn , kLCDIFV2_PD_DstOut , kLCDIFV2_PD_Xor , kLCDIFV2_PD_Clear ,
  kLCDIFV2_PD_Max
 LCDIFv2 Porter Duff blend mode. Note: Don't change the enum item value. More...
enum  _lcdifv2_pd_layer { kLCDIFV2_PD_SrcLayer = 0 , kLCDIFV2_PD_DestLayer = 1 , kLCDIFV2_PD_LayerMax = 2 }
 LCDIFv2 Porter Duff layer. Note: Don't change the enum item value. More...
typedef enum _lcdifv2_line_order lcdifv2_line_order_t
typedef struct _lcdifv2_display_config lcdifv2_display_config_t
typedef enum _lcdifv2_csc_mode lcdifv2_csc_mode_t
typedef enum _lcdifv2_pixel_format lcdifv2_pixel_format_t
typedef struct _lcdifv2_buffer_config lcdifv2_buffer_config_t
typedef enum _lcdifv2_alpha_mode lcdifv2_alpha_mode_t
typedef enum _lcdifv2_pd_alpha_mode lcdifv2_pd_alpha_mode_t
typedef enum _lcdifv2_pd_color_mode lcdifv2_pd_color_mode_t
typedef enum _lcdifv2_pd_global_alpha_mode lcdifv2_pd_global_alpha_mode_t
typedef enum _lcdifv2_pd_factor_mode lcdifv2_pd_factor_mode_t
typedef struct _lcdifv2_blend_config lcdifv2_blend_config_t
typedef enum _lcdifv2_pd_blend_mode lcdifv2_pd_blend_mode_t
typedef enum _lcdifv2_pd_layer lcdifv2_pd_layer_t
#define FSL_LCDIFV2_DRIVER_VERSION   (MAKE_VERSION(2, 3, 2))
 LCDIF v2 driver version.
#define LCDIFV2_ADDR_CPU_2_IP(addr)   (addr)
#define LCDIFV2_MAKE_FIFO_EMPTY_INTERRUPT(layer)   (1UL << ((uint32_t)(layer) + 24U))
 LCDIF v2 FIFO empty interrupt.
#define LCDIFV2_MAKE_DMA_DONE_INTERRUPT(layer)   (1UL << ((uint32_t)(layer) + 16U))
 LCDIF v2 DMA done interrupt.
#define LCDIFV2_MAKE_DMA_ERROR_INTERRUPT(layer)   (1UL << ((uint32_t)(layer) + 8U))
 LCDIF v2 DMA error interrupt.
#define LCDIFV2_LUT_ENTRY_NUM   256U
LCDIF v2 initialization and de-initialization
void LCDIFV2_Init (LCDIFV2_Type *base)
 Initializes the LCDIF v2. More...
void LCDIFV2_Deinit (LCDIFV2_Type *base)
 Deinitializes the LCDIF peripheral. More...
void LCDIFV2_Reset (LCDIFV2_Type *base)
 Reset the LCDIF v2. More...
Display
void LCDIFV2_DisplayGetDefaultConfig (lcdifv2_display_config_t *config)
 Gets the LCDIF display default configuration structure. More...
void LCDIFV2_SetDisplayConfig (LCDIFV2_Type *base, const lcdifv2_display_config_t *config)
 Set the LCDIF v2 display configurations. More...
LUT
status_t LCDIFV2_SetLut (LCDIFV2_Type *base, uint8_t layerIndex, const uint32_t *lutData, uint16_t count, bool useShadowLoad)
 Set the LUT data. More...
Layer operation
void LCDIFV2_SetLayerBufferConfig (LCDIFV2_Type *base, uint8_t layerIndex, const lcdifv2_buffer_config_t *config)
 Set the layer source buffer configuration. More...
void LCDIFV2_SetLayerBlendConfig (LCDIFV2_Type *base, uint8_t layerIndex, const lcdifv2_blend_config_t *config)
 Set the layer alpha blend mode. More...
void LCDIFV2_SetCscMode (LCDIFV2_Type *base, uint8_t layerIndex, lcdifv2_csc_mode_t mode)
 Set the color space conversion mode. More...
Porter Duff
status_t LCDIFV2_GetPorterDuffConfig (lcdifv2_pd_blend_mode_t mode, lcdifv2_pd_layer_t layer, lcdifv2_blend_config_t *config)
 Get the blend configuration for Porter Duff blend. More...
Misc
status_t LCDIFV2_GetMultiLayerGlobalAlpha (const uint8_t blendedAlpha[], uint8_t globalAlpha[], uint8_t layerCount)
 Get the global alpha values for multiple layer blend. More...
◆ _lcdifv2_alpha_mode
Disable alpha blend.
Use the gobal alpha value, pixel defined alpha value is overridden.
Use the pixel defined alpha value.
Use the PoterDuff alpha blending.
◆ _lcdifv2_csc_mode
kLCDIFV2_CscDisable
Disable the CSC.
kLCDIFV2_CscYUV2RGB
YUV to RGB.
YCbCr to RGB.
◆ _lcdifv2_interrupt
Layer 0 FIFO empty.
Layer 1 FIFO empty.
Layer 2 FIFO empty.
Layer 3 FIFO empty.
Layer 4 FIFO empty.
Layer 5 FIFO empty.
Layer 6 FIFO empty.
Layer 7 FIFO empty.
Layer 0 DMA done.
Layer 1 DMA done.
Layer 2 DMA done.
Layer 3 DMA done.
Layer 4 DMA done.
Layer 5 DMA done.
Layer 6 DMA done.
Layer 7 DMA done.
Layer 0 DMA error.
Layer 1 DMA error.
Layer 2 DMA error.
Layer 3 DMA error.
Layer 4 DMA error.
Layer 5 DMA error.
Layer 6 DMA error.
Layer 7 DMA error.
Start of vertical blanking period.
Output buffer underrun.
Interrupt at VSYNC edge.
◆ _lcdifv2_line_order
RGB
RBG
GBR
GRB
BRG
BGR
◆ _lcdifv2_pd_alpha_mode
Straight mode.
Inversed mode.
◆ _lcdifv2_pd_blend_mode
kLCDIFV2_PD_Src
Source Only
kLCDIFV2_PD_Atop
Source Atop
kLCDIFV2_PD_Over
Source Over
kLCDIFV2_PD_In
Source In.
kLCDIFV2_PD_Out
Source Out.
kLCDIFV2_PD_Dst
Destination Only.
kLCDIFV2_PD_DstAtop
Destination Atop.
kLCDIFV2_PD_DstOver
Destination Over.
kLCDIFV2_PD_DstIn
Destination In.
kLCDIFV2_PD_DstOut
Destination Out.
kLCDIFV2_PD_Xor
XOR.
kLCDIFV2_PD_Clear
Clear.
kLCDIFV2_PD_Max
Used for boarder detection.
◆ _lcdifv2_pd_color_mode
Output color directly.
Output color multiples alpha.
◆ _lcdifv2_pd_factor_mode
Use 1.
Use 0.
Use straight alpha.
Use inversed alpha.
◆ _lcdifv2_pd_global_alpha_mode
Use global alpha.
Use local alpha.
Use scaled alpha.
◆ _lcdifv2_pd_layer
Source layer.
Destination layer.
◆ _lcdifv2_pixel_format
LUT index 1 bit.
LUT index 2 bit.
LUT index 4 bit.
LUT index 8 bit.
RGB565, two pixels use 32 bits.
ARGB1555, two pixels use 32 bits.
ARGB4444, two pixels use 32 bits.
UYVY, only layer 0 and layer 1 support this.
VYUY, only layer 0 and layer 1 support this.
YUYV, only layer 0 and layer 1 support this.
YVYU, only layer 0 and layer 1 support this.
RGB888 packed, one pixel uses 24 bits.
ARGB8888 unpacked, one pixel uses 32 bits.
ABGR8888 unpacked, one pixel uses 32 bits.
◆ _lcdifv2_polarity_flags
VSYNC active high.
HSYNC active high.
Data enable line active high.
Output data on rising clock edge, capture data on falling clock edge.
Data active high.
VSYNC active low.
HSYNC active low.
Data enable line active low.
Output data on falling clock edge, capture data on rising clock edge.
Data active high.
◆ LCDIFV2_Deinit()
void LCDIFV2_Deinit ( LCDIFV2_Type base)
Parameters
baseLCDIF peripheral base address.
brief Deinitializes the LCDIF peripheral.
param base LCDIF peripheral base address.
◆ LCDIFV2_DisplayGetDefaultConfig()
void LCDIFV2_DisplayGetDefaultConfig ( lcdifv2_display_config_t config)
This function sets the configuration structure to default values. The default configuration is set to the following values.
config->panelWidth = 0U;
config->panelHeight = 0U;
config->hsw = 3U;
config->hfp = 3U;
config->hbp = 3U;
config->vsw = 3U;
config->vfp = 3U;
config->vbp = 3U;
@ kLCDIFV2_LineOrderRGB
Definition: fsl_lcdifv2.h:114
@ kLCDIFV2_DataActiveHigh
Definition: fsl_lcdifv2.h:67
@ kLCDIFV2_HsyncActiveHigh
Definition: fsl_lcdifv2.h:63
@ kLCDIFV2_DriveDataOnRisingClkEdge
Definition: fsl_lcdifv2.h:65
@ kLCDIFV2_DataEnableActiveHigh
Definition: fsl_lcdifv2.h:64
@ kLCDIFV2_VsyncActiveHigh
Definition: fsl_lcdifv2.h:62
Definition: deflate.c:114
Parameters
configPointer to the LCDIF configuration structure.
brief Gets the LCDIF display default configuration structure.
param config Pointer to the LCDIF configuration structure.
◆ LCDIFV2_GetMultiLayerGlobalAlpha()
status_t LCDIFV2_GetMultiLayerGlobalAlpha ( const uint8_t  blendedAlpha[],
uint8_t  layerCount
This function calculates the global alpha value for each layer based on the desired blended alpha.
When all layers use the global alpha, the relationship of blended alpha and global alpha of each layer is:
Layer 7: ba7 = ga7 Layer 6: ba6 = ga6 * (1-ga7) Layer 5: ba5 = ga5 * (1-ga6) * (1-ga7) Layer 4: ba4 = ga4 * (1-ga5) * (1-ga6) * (1-ga7) Layer 3: ba3 = ga3 * (1-ga4) * (1-ga5) * (1-ga6) * (1-ga7) Layer 2: ba2 = ga2 * (1-ga3) * (1-ga4) * (1-ga5) * (1-ga6) * (1-ga7) Layer 1: ba1 = ga1 * (1-ga2) * (1-ga3) * (1-ga4) * (1-ga5) * (1-ga6) * (1-ga7) Layer 0: ba0 = 1 * (1-ga1) * (1-ga2) * (1-ga3) * (1-ga4) * (1-ga5) * (1-ga6) * (1-ga7)
Here baN is the blended alpha of layer N, gaN is the global alpha configured to layer N.
This function calculates the global alpha based on the blended alpha. The blendedAlpha and globalAlpha are all arrays of size layerCount. The first layer is a background layer, so blendedAlpha[0] is useless, globalAlpha[0] is always 255.
Parameters
[in]blendedAlphaThe desired blended alpha value, alpha range 0~255.
[out]globalAlphaCalculated global alpha set to each layer register.
[in]layerCountTotal layer count.
Return values
kStatus_SuccessGet successfully.
kStatus_InvalidArgumentThe argument is invalid.
◆ LCDIFV2_GetPorterDuffConfig()
status_t LCDIFV2_GetPorterDuffConfig ( lcdifv2_pd_blend_mode_t  mode,
lcdifv2_blend_config_t config
This function gets the blend configuration for Porter Duff blend, config->pdFactorMode is set according to layer and mode, other blend configurations are set to:
config->pdColorMode = kLCDIFV2_PD_ColorStraight;
config->pdGlobalAlphaMode = kLCDIFV2_PD_LocalAlpha;
@ kLCDIFV2_AlphaPoterDuff
Definition: fsl_lcdifv2.h:185
@ kLCDIFV2_PD_AlphaStraight
Definition: fsl_lcdifv2.h:193
@ kLCDIFV2_PD_LocalAlpha
Definition: fsl_lcdifv2.h:212
This is the basic Porter Duff blend configuration, user still could modify the configurations after this function.
Parameters
modePorter Duff blend mode.
layerThe configuration for source layer or destination layer.
configPointer to the configuration.
Return values
kStatus_SuccessGet the configuration successfully.
◆ LCDIFV2_Init()
void LCDIFV2_Init ( LCDIFV2_Type base)
This function ungates the LCDIF v2 clock and release the peripheral reset.
Parameters
baseLCDIF v2 peripheral base address.
brief Initializes the LCDIF v2.
param base LCDIF v2 peripheral base address.
◆ LCDIFV2_Reset()
void LCDIFV2_Reset ( LCDIFV2_Type base)
Reset the LCDIF v2.
Parameters
brief Reset the LCDIF v2.
◆ LCDIFV2_SetCscMode()
void LCDIFV2_SetCscMode ( LCDIFV2_Type base,
uint8_t  layerIndex,
Supports YUV2RGB and YCbCr2RGB.
Parameters
baseLCDIFv2 peripheral base address.
layerIndexIndex of the layer.
modeThe conversion mode.
brief Set the color space conversion mode.
param base LCDIFv2 peripheral base address. param layerIndex Index of the layer. param mode The conversion mode.
◆ LCDIFV2_SetDisplayConfig()
void LCDIFV2_SetDisplayConfig ( LCDIFV2_Type base,
const lcdifv2_display_config_t config
Parameters
brief Set the LCDIF v2 display configurations.
param base LCDIF peripheral base address. param config Pointer to the LCDIF configuration structure.
◆ LCDIFV2_SetLayerBlendConfig()
void LCDIFV2_SetLayerBlendConfig ( LCDIFV2_Type base,
uint8_t  layerIndex,
const lcdifv2_blend_config_t config
Parameters
layerIndexIndex of the CSC unit.
configPointer to the blend configuration.
brief Set the layer alpha blend mode.
param base LCDIFv2 peripheral base address. param layerIndex Index of the CSC unit. param config Pointer to the blend configuration.
◆ LCDIFV2_SetLayerBufferConfig()
void LCDIFV2_SetLayerBufferConfig ( LCDIFV2_Type base,
uint8_t  layerIndex,
const lcdifv2_buffer_config_t config
Parameters
layerIndexLayer layerIndex.
brief Set the layer source buffer configuration.
param base LCDIFv2 peripheral base address. param layerIndex Layer layerIndex. param config Pointer to the configuration.
◆ LCDIFV2_SetLut()
status_t LCDIFV2_SetLut ( LCDIFV2_Type base,
uint8_t  layerIndex,
const uint32_t *  lutData,
uint16_t  count,
bool  useShadowLoad
Set the LUT data.
This function sets the specific layer LUT data, if useShadowLoad is true, call LCDIFV2_TriggerLayerShadowLoad after this function, the LUT will be loaded to the hardware during next vertical blanking period. If useShadowLoad is false, the LUT data is loaded to hardware directly.
Parameters
layerIndexWhich layer to set.
lutDataThe LUT data to load.
countCount of lutData.
useShadowLoadUse shadow load.
Return values
kStatus_SuccessSet success.
kStatus_FailPrevious LUT data is not loaded to hardware yet.
brief Set the LUT data.
param base LCDIF v2 peripheral base address. param layerIndex Which layer to set. param lutData The LUT data to load. param count Count of lutData. retval kStatus_Success Set success. retval kStatus_Fail Previous LUT data is not loaded to hardware yet.
Variable Documentation
◆ alphaMode
Alpha mode.
◆ globalAlpha
Global alpha value, only used when alphaMode is kLCDIFV2_AlphaOverride or kLCDIFV2_AlphaPoterDuff
◆ hbp
Horizontal back porch.
◆ hfp
Horizontal front porch.
◆ hsw
HSYNC pulse width.
◆ lineOrder
Line order.
◆ panelHeight
Display panel height, how many lines per panel.
◆ panelWidth
Display panel width, pixels per line.
◆ pdAlphaMode
PoterDuff alpha mode, only used when alphaMode is kLCDIFV2_AlphaPoterDuff
◆ pdColorMode
PoterDuff color mode, only used when alphaMode is kLCDIFV2_AlphaPoterDuff
◆ pdFactorMode
PoterDuff factor mode, only used when alphaMode is kLCDIFV2_AlphaPoterDuff
◆ pdGlobalAlphaMode
PoterDuff global alpha mode, only used when alphaMode is kLCDIFV2_AlphaPoterDuff
◆ pixelFormat
Source buffer pixel format.
◆ polarityFlags
OR'ed value of _lcdifv2_polarity_flags, used to contol the signal polarity.
◆ strideBytes
Number of bytes between two vertically adjacent pixels, suggest 64-bit aligned.
◆ vbp
Vertical back porch.
◆ vfp
Vrtical front porch.
◆ vsw
VSYNC pulse width.
