RTEMS 6.1-rc1
Modules | Data Structures | Macros | Functions
PowerPC Architecture Support. More...
 PowerPC Assembler Support
 PowerPC Assembler Support.
 PowerPC Paravirtualization Support
 PowerPC Paravirtualization Support.
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define FRAME_LINK_SPACE   8
#define SRR0_FRAME_OFFSET   FRAME_LINK_SPACE
#define SRR1_FRAME_OFFSET   (SRR0_FRAME_OFFSET + PPC_REG_SIZE)
#define EXCEPTION_NUMBER_OFFSET   (SRR1_FRAME_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_INTERRUPT_ENTRY_INSTANT_OFFSET   (EXCEPTION_NUMBER_OFFSET + 4)
#define EXC_CR_OFFSET   (EXCEPTION_NUMBER_OFFSET + 8)
#define EXC_XER_OFFSET   (EXC_CR_OFFSET + 4)
#define EXC_CTR_OFFSET   (EXC_XER_OFFSET + 4)
#define EXC_LR_OFFSET   (EXC_CTR_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_INTERRUPT_FRAME_OFFSET   (EXC_LR_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_GPR_OFFSET(gpr)    ((gpr) * PPC_GPR_SIZE + PPC_EXC_INTERRUPT_FRAME_OFFSET + PPC_REG_SIZE)
#define PPC_EXC_GPR3_PROLOGUE_OFFSET   PPC_EXC_GPR_OFFSET(3)
#define PPC_EXC_FRAME_SIZE   PPC_EXC_GPR_OFFSET(33)
#define CPU_INTERRUPT_FRAME_SIZE    (PPC_EXC_GPR_OFFSET(13) + PPC_STACK_RED_ZONE_SIZE)
#define GPR0_OFFSET   PPC_EXC_GPR_OFFSET(0)
#define GPR1_OFFSET   PPC_EXC_GPR_OFFSET(1)
#define GPR2_OFFSET   PPC_EXC_GPR_OFFSET(2)
#define GPR3_OFFSET   PPC_EXC_GPR_OFFSET(3)
#define GPR4_OFFSET   PPC_EXC_GPR_OFFSET(4)
#define GPR5_OFFSET   PPC_EXC_GPR_OFFSET(5)
#define GPR6_OFFSET   PPC_EXC_GPR_OFFSET(6)
#define GPR7_OFFSET   PPC_EXC_GPR_OFFSET(7)
#define GPR8_OFFSET   PPC_EXC_GPR_OFFSET(8)
#define GPR9_OFFSET   PPC_EXC_GPR_OFFSET(9)
#define GPR10_OFFSET   PPC_EXC_GPR_OFFSET(10)
#define GPR11_OFFSET   PPC_EXC_GPR_OFFSET(11)
#define GPR12_OFFSET   PPC_EXC_GPR_OFFSET(12)
#define GPR13_OFFSET   PPC_EXC_GPR_OFFSET(13)
#define GPR14_OFFSET   PPC_EXC_GPR_OFFSET(14)
#define GPR15_OFFSET   PPC_EXC_GPR_OFFSET(15)
#define GPR16_OFFSET   PPC_EXC_GPR_OFFSET(16)
#define GPR17_OFFSET   PPC_EXC_GPR_OFFSET(17)
#define GPR18_OFFSET   PPC_EXC_GPR_OFFSET(18)
#define GPR19_OFFSET   PPC_EXC_GPR_OFFSET(19)
#define GPR20_OFFSET   PPC_EXC_GPR_OFFSET(20)
#define GPR21_OFFSET   PPC_EXC_GPR_OFFSET(21)
#define GPR22_OFFSET   PPC_EXC_GPR_OFFSET(22)
#define GPR23_OFFSET   PPC_EXC_GPR_OFFSET(23)
#define GPR24_OFFSET   PPC_EXC_GPR_OFFSET(24)
#define GPR25_OFFSET   PPC_EXC_GPR_OFFSET(25)
#define GPR26_OFFSET   PPC_EXC_GPR_OFFSET(26)
#define GPR27_OFFSET   PPC_EXC_GPR_OFFSET(27)
#define GPR28_OFFSET   PPC_EXC_GPR_OFFSET(28)
#define GPR29_OFFSET   PPC_EXC_GPR_OFFSET(29)
#define GPR30_OFFSET   PPC_EXC_GPR_OFFSET(30)
#define GPR31_OFFSET   PPC_EXC_GPR_OFFSET(31)
#define CPU_PER_CPU_CONTROL_SIZE   0
#define CPU_THREAD_LOCAL_STORAGE_VARIANT   10
RTEMS_NO_RETURN void _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error)
void _CPU_Context_volatile_clobber (uintptr_t pattern)
void _CPU_Context_validate (uintptr_t pattern)
PowerPC CPU Department Source.
PowerPc MSR and Registers Access Definitions.
This file contains some powerpc MSR and registers access definitions.
◆ _CPU_Fatal_halt()
RTEMS_NO_RETURN void _CPU_Fatal_halt ( uint32_t  source,
CPU_Uint32ptr  error
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
  1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
  2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
