RTEMS 6.1-rc1
Interrupt stack frame (ISF). More...
#include <cpu.h>
Data Fields | |
uint64_t | x0 |
uint64_t | register_lr_original |
uint64_t | register_lr |
uint64_t | x1 |
uint64_t | x2 |
uint64_t | x3 |
uint64_t | x4 |
uint64_t | x5 |
uint64_t | x6 |
uint64_t | x7 |
uint64_t | x8 |
uint64_t | x9 |
uint64_t | x10 |
uint64_t | x11 |
uint64_t | x12 |
uint64_t | x13 |
uint64_t | x14 |
uint64_t | x15 |
uint64_t | x16 |
uint64_t | x17 |
uint64_t | x18 |
uint64_t | x19 |
uint64_t | x20 |
uint64_t | x21 |
uint64_t | register_elr |
uint64_t | register_spsr |
uint64_t | register_fpsr |
uint64_t | register_fpcr |
uint32_t | reserved [3] |
uint32_t | isr_vector |
uint32_t | ebx |
uint32_t | ebp |
uint32_t | esp |
uint32_t | edx |
uint32_t | ecx |
uint32_t | eax |
uint32_t | eip |
uint32_t | cs |
uint32_t | eflags |
uint32_t | r1 |
uint32_t | r2 |
uint32_t | r3 |
uint32_t | r4 |
uint32_t | r5 |
uint32_t | r6 |
uint32_t | r7 |
uint32_t | r8 |
uint32_t | r9 |
uint32_t | r10 |
uint32_t | ra |
uint32_t | ba |
uint32_t | ea |
uint32_t | vecnum |
__MIPS_REGISTER_TYPE | r0 |
__MIPS_REGISTER_TYPE | at |
__MIPS_REGISTER_TYPE | v0 |
__MIPS_REGISTER_TYPE | v1 |
__MIPS_REGISTER_TYPE | a0 |
__MIPS_REGISTER_TYPE | a1 |
__MIPS_REGISTER_TYPE | a2 |
__MIPS_REGISTER_TYPE | a3 |
__MIPS_REGISTER_TYPE | t0 |
__MIPS_REGISTER_TYPE | t1 |
__MIPS_REGISTER_TYPE | t2 |
__MIPS_REGISTER_TYPE | t3 |
__MIPS_REGISTER_TYPE | t4 |
__MIPS_REGISTER_TYPE | t5 |
__MIPS_REGISTER_TYPE | t6 |
__MIPS_REGISTER_TYPE | t7 |
__MIPS_REGISTER_TYPE | s0 |
__MIPS_REGISTER_TYPE | s1 |
__MIPS_REGISTER_TYPE | s2 |
__MIPS_REGISTER_TYPE | s3 |
__MIPS_REGISTER_TYPE | s4 |
__MIPS_REGISTER_TYPE | s5 |
__MIPS_REGISTER_TYPE | s6 |
__MIPS_REGISTER_TYPE | s7 |
__MIPS_REGISTER_TYPE | t8 |
__MIPS_REGISTER_TYPE | t9 |
__MIPS_REGISTER_TYPE | k0 |
__MIPS_REGISTER_TYPE | k1 |
__MIPS_REGISTER_TYPE | gp |
__MIPS_REGISTER_TYPE | sp |
__MIPS_REGISTER_TYPE | fp |
__MIPS_REGISTER_TYPE | ra |
__MIPS_REGISTER_TYPE | c0_sr |
__MIPS_REGISTER_TYPE | mdlo |
__MIPS_REGISTER_TYPE | mdhi |
__MIPS_REGISTER_TYPE | badvaddr |
__MIPS_REGISTER_TYPE | cause |
__MIPS_REGISTER_TYPE | epc |
__MIPS_FPU_REGISTER_TYPE | f0 |
__MIPS_FPU_REGISTER_TYPE | f1 |
__MIPS_FPU_REGISTER_TYPE | f2 |
__MIPS_FPU_REGISTER_TYPE | f3 |
__MIPS_FPU_REGISTER_TYPE | f4 |
__MIPS_FPU_REGISTER_TYPE | f5 |
__MIPS_FPU_REGISTER_TYPE | f6 |
__MIPS_FPU_REGISTER_TYPE | f7 |
__MIPS_FPU_REGISTER_TYPE | f8 |
__MIPS_FPU_REGISTER_TYPE | f9 |
__MIPS_FPU_REGISTER_TYPE | f10 |
__MIPS_FPU_REGISTER_TYPE | f11 |
__MIPS_FPU_REGISTER_TYPE | f12 |
__MIPS_FPU_REGISTER_TYPE | f13 |
__MIPS_FPU_REGISTER_TYPE | f14 |
__MIPS_FPU_REGISTER_TYPE | f15 |
__MIPS_FPU_REGISTER_TYPE | f16 |
__MIPS_FPU_REGISTER_TYPE | f17 |
__MIPS_FPU_REGISTER_TYPE | f18 |
__MIPS_FPU_REGISTER_TYPE | f19 |
__MIPS_FPU_REGISTER_TYPE | f20 |
__MIPS_FPU_REGISTER_TYPE | f21 |
__MIPS_FPU_REGISTER_TYPE | f22 |
__MIPS_FPU_REGISTER_TYPE | f23 |
__MIPS_FPU_REGISTER_TYPE | f24 |
__MIPS_FPU_REGISTER_TYPE | f25 |
__MIPS_FPU_REGISTER_TYPE | f26 |
__MIPS_FPU_REGISTER_TYPE | f27 |
__MIPS_FPU_REGISTER_TYPE | f28 |
__MIPS_FPU_REGISTER_TYPE | f29 |
__MIPS_FPU_REGISTER_TYPE | f30 |
__MIPS_FPU_REGISTER_TYPE | f31 |
__MIPS_REGISTER_TYPE | fcsr |
__MIPS_REGISTER_TYPE | feir |
__MIPS_REGISTER_TYPE | tlbhi |
__MIPS_REGISTER_TYPE | inx |
__MIPS_REGISTER_TYPE | rand |
__MIPS_REGISTER_TYPE | ctxt |
__MIPS_REGISTER_TYPE | exctype |
__MIPS_REGISTER_TYPE | mode |
__MIPS_REGISTER_TYPE | prid |
__MIPS_REGISTER_TYPE | tar |
uint32_t | special_interrupt_register |
uintptr_t | FRAME_SP |
uintptr_t | FRAME_LR |
uintptr_t | EXC_SRR0 |
uintptr_t | EXC_SRR1 |
uint32_t | RESERVED_FOR_ALIGNMENT_0 |
uint32_t | EXC_INTERRUPT_ENTRY_INSTANT |
uint32_t | EXC_CR |
uint32_t | EXC_XER |
uintptr_t | EXC_CTR |
uintptr_t | EXC_LR |
uintptr_t | EXC_INTERRUPT_FRAME |
PPC_GPR_TYPE | GPR0 |
PPC_GPR_TYPE | GPR1 |
PPC_GPR_TYPE | GPR2 |
PPC_GPR_TYPE | GPR3 |
PPC_GPR_TYPE | GPR4 |
PPC_GPR_TYPE | GPR5 |
PPC_GPR_TYPE | GPR6 |
PPC_GPR_TYPE | GPR7 |
PPC_GPR_TYPE | GPR8 |
PPC_GPR_TYPE | GPR9 |
PPC_GPR_TYPE | GPR10 |
PPC_GPR_TYPE | GPR11 |
PPC_GPR_TYPE | GPR12 |
SPARC_Minimum_stack_frame | Stack_frame |
uint32_t | psr |
uint32_t | pc |
uint32_t | npc |
uint32_t | g1 |
uint32_t | g2 |
uint32_t | g3 |
uint32_t | g4 |
uint32_t | g5 |
uint32_t | reserved_for_alignment |
uint32_t | g7 |
uint32_t | i0 |
uint32_t | i1 |
uint32_t | i2 |
uint32_t | i3 |
uint32_t | i4 |
uint32_t | i5 |
uint32_t | i6_fp |
uint32_t | i7 |
uint32_t | y |
uint32_t | tpc |
SPARC64_Minimum_stack_frame | Stack_frame |
uint64_t | tstate |
uint64_t | tpc |
uint64_t | tnpc |
uint64_t | pil |
uint64_t | y |
uint64_t | g1 |
uint64_t | g2 |
uint64_t | g3 |
uint64_t | g4 |
uint64_t | g5 |
uint64_t | g6 |
uint64_t | g7 |
uint64_t | o0 |
uint64_t | o1 |
uint64_t | o2 |
uint64_t | o3 |
uint64_t | o4 |
uint64_t | o5 |
uint64_t | o6_sp |
uint64_t | o7 |
uint64_t | tvec |
uint64_t | rax |
uint64_t | rcx |
uint64_t | rdx |
uint64_t | rsi |
uint64_t | r8 |
uint64_t | r9 |
uint64_t | r10 |
uint64_t | r11 |
uint64_t | saved_rsp |
This defines the set of integer and processor state registers that must be saved during an interrupt. This set does not include any which are in Context_Control.
Context saved on stack for an interrupt.
NOTE: The PSR, PC, and NPC are only saved in this structure for the benefit of the user's handler.
uint32_t CPU_Interrupt_frame::g1 |
This is the offset of the g1 register on an ISF.
uint32_t CPU_Interrupt_frame::g2 |
This is the offset of the g2 register on an ISF.
uint32_t CPU_Interrupt_frame::g3 |
This is the offset of the g3 register on an ISF.
uint32_t CPU_Interrupt_frame::g4 |
This is the offset of the g4 register on an ISF.
uint32_t CPU_Interrupt_frame::g5 |
This is the offset of the g5 register on an ISF.
uint32_t CPU_Interrupt_frame::g7 |
This is the offset of the g7 register on an ISF.
uint32_t CPU_Interrupt_frame::i0 |
This is the offset of the i0 register on an ISF.
uint32_t CPU_Interrupt_frame::i1 |
This is the offset of the i1 register on an ISF.
uint32_t CPU_Interrupt_frame::i2 |
This is the offset of the i2 register on an ISF.
uint32_t CPU_Interrupt_frame::i3 |
This is the offset of the i3 register on an ISF.
uint32_t CPU_Interrupt_frame::i4 |
This is the offset of the i4 register on an ISF.
uint32_t CPU_Interrupt_frame::i5 |
This is the offset of the i5 register on an ISF.
uint32_t CPU_Interrupt_frame::i6_fp |
This is the offset of the i6 register on an ISF.
uint32_t CPU_Interrupt_frame::i7 |
This is the offset of the i7 register on an ISF.
uint32_t CPU_Interrupt_frame::npc |
This is the offset of the XXX on an ISF.
uint32_t CPU_Interrupt_frame::pc |
uint32_t CPU_Interrupt_frame::psr |
This is the offset of the PSR on an ISF.
uint64_t CPU_Interrupt_frame::rax |
uint32_t CPU_Interrupt_frame::reserved_for_alignment |
This is the offset is reserved for alignment on an ISF.
uint32_t CPU_Interrupt_frame::special_interrupt_register |
This field is a hint that a port will have a number of integer registers that need to be saved when an interrupt occurs or when a context switch occurs at the end of an ISR.
SPARC_Minimum_stack_frame CPU_Interrupt_frame::Stack_frame |
On an interrupt, we must save the minimum stack frame.
uint32_t CPU_Interrupt_frame::tpc |
This is the offset of the tpc register on an ISF.
uint32_t CPU_Interrupt_frame::y |
This is the offset of the y register on an ISF.
