#define | AARCH64_MULTILIB_HAS_WFI |
#define | AARCH64_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE |
#define | AARCH64_MULTILIB_HAS_BARRIER_INSTRUCTIONS |
#define | AARCH64_MULTILIB_HAS_CPACR |
#define | AARCH64_MULTILIB_CACHE_LINE_MAX_64 |
#define | CPU_NAME "AArch64" |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER FALSE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_SOFTWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH FALSE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 32 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x1 |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1024 * 8) |
#define | CPU_SIZEOF_POINTER __SIZEOF_POINTER__ |
#define | CPU_ALIGNMENT 16 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 16 |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_LIBC_INIT_FINI_ARRAY TRUE |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | AARCH64_CONTEXT_CONTROL_THREAD_ID_OFFSET 0x70 |
#define | AARCH64_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE 0x68 |
#define | AARCH64_EXCEPTION_FRAME_SIZE 0x350 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET 0xF8 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET 0xF0 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET 0x108 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET 0x118 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET 0x128 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET 0x138 |
#define | AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET 0x150 |
#define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) AArch64_interrupt_enable( _isr_cookie ) |
#define | _CPU_ISR_Flash(_isr_cookie) AArch64_interrupt_flash( _isr_cookie ) |
#define | _CPU_Context_Get_SP(_context) (_context)->register_sp |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Initialize_fp(_destination) |
#define | VECTOR_POINTER_OFFSET 0x78 |
#define | VECTOR_ENTRY_SIZE 0x80 |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_INTERRUPT_FRAME_SIZE 0x2E0 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 11 |
enum | AArch64_symbolic_exception_name {
AARCH64_EXCEPTION_SP0_SYNCHRONOUS = 0
, AARCH64_EXCEPTION_SP0_IRQ = 1
, AARCH64_EXCEPTION_SP0_FIQ = 2
, AARCH64_EXCEPTION_SP0_SERROR = 3
AARCH64_EXCEPTION_SPx_SYNCHRONOUS = 4
, AARCH64_EXCEPTION_SPx_IRQ = 5
, AARCH64_EXCEPTION_SPx_FIQ = 6
, AARCH64_EXCEPTION_SPx_SERROR = 7
AARCH64_EXCEPTION_LEL64_SYNCHRONOUS = 8
, AARCH64_EXCEPTION_LEL64_IRQ = 9
, AARCH64_EXCEPTION_LEL64_FIQ = 10
, AARCH64_EXCEPTION_LEL64_SERROR = 11
AARCH64_EXCEPTION_LEL32_SYNCHRONOUS = 12
, AARCH64_EXCEPTION_LEL32_IRQ = 13
, AARCH64_EXCEPTION_LEL32_FIQ = 14
, AARCH64_EXCEPTION_LEL32_SERROR = 15
MAX_EXCEPTIONS = 16
, AARCH64_EXCEPTION_MAKE_ENUM_64_BIT = INT_MAX
void | _CPU_ISR_Set_level (uint32_t level) |
| Sets the hardware interrupt level by the level value. More...
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint64_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area) |
void | _CPU_Initialize (void) |
| CPU initialization. More...
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
| CPU switch context.
RTEMS_NO_RETURN void | _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir) |
RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _AArch64_Exception_interrupt_no_nest (void) |
void | _AArch64_Exception_interrupt_nest (void) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _CPU_Exception_resume (CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _CPU_Exception_dispatch_and_resume (CPU_Exception_frame *frame) |
void | _CPU_Exception_disable_thread_dispatch (void) |
int | _CPU_Exception_frame_get_signal (CPU_Exception_frame *frame) |
void | _CPU_Exception_frame_set_resume (CPU_Exception_frame *frame, void *address) |
void | _CPU_Exception_frame_make_resume_next_instruction (CPU_Exception_frame *frame) |
void | _AArch64_Exception_frame_copy (CPU_Exception_frame *new_ef, CPU_Exception_frame *old_ef) |
void | _AArch64_Exception_default (CPU_Exception_frame *frame) |
RTEMS_NO_RETURN void | _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error) |
void | _CPU_Context_volatile_clobber (uintptr_t pattern) |
void | _CPU_Context_validate (uintptr_t pattern) |
ARM AArch64 Architecture Support.
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
