RTEMS 6.1-rc1
- k -
- k0 : regs.h
- k1 : regs.h
- kCLOCK_CoreSysClk : fsl_clock.h
- KERNEL_PAGE_WIDTH : tlb.h
- KEY_MANAGER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER__PUF : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER__PUF_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_BASE : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_BASE_ADDRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_BASE_PTRS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_IEE_KEY_CTRL_RELOAD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_MASTER_KEY_CTRL_LOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_MASTER_KEY_CTRL_SELECT : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_OTFAD1_KEY_CTRL_LOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_OTFAD1_KEY_CTRL_SELECT : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_OTFAD2_KEY_CTRL_LOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_OTFAD2_KEY_CTRL_SELECT : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_PUF_KEY_CTRL_LOCK : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT0_CTRL_LOCK_CONTROL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT0_CTRL_LOCK_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT0_CTRL_TZ_NS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT0_CTRL_TZ_USER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT0_CTRL_WHITE_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT1_CTRL_LOCK_CONTROL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT1_CTRL_LOCK_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT1_CTRL_TZ_NS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT1_CTRL_TZ_USER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT1_CTRL_WHITE_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT2_CTRL_LOCK_CONTROL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT2_CTRL_LOCK_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT2_CTRL_TZ_NS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT2_CTRL_TZ_USER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT2_CTRL_WHITE_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT3_CTRL_LOCK_CONTROL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT3_CTRL_LOCK_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT3_CTRL_TZ_NS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT3_CTRL_TZ_USER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT3_CTRL_WHITE_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT4_CTRL_LOCK_CONTROL : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT4_CTRL_LOCK_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT4_CTRL_TZ_NS : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT4_CTRL_TZ_USER : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEY_MANAGER_SLOT4_CTRL_WHITE_LIST : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KEYMANAGER_CLOCKS : fsl_clock.h
- KPP : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_BASE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_BASE_ADDRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_BASE_PTRS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_CLOCKS : fsl_clock.h
- KPP_IRQS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KDDR_KCDD : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KDDR_KRDD : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPCR_KCO : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPCR_KRE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPDR_KCD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPDR_KRD : MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KDIE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KDSC : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KPKD : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KPKR : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KRIE : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
- KPP_KPSR_KRSS : MIMXRT1052.h, MIMXRT1166_cm4.h, MIMXRT1166_cm7.h
