RTEMS 6.1-rc1
- n -
- N : APSR_Type, xPSR_Type
- nack_enable : ALT_I2C_SLAVE_CONFIG_s
- NACKEnable : SMARTCARD_InitTypeDef
- name : _Scheduler_Control, _standard_version, drvmgr_dev, drvmgr_drv, drvmgr_map_entry, link_map, Objects_Control, rtems_disk_device, rtems_fdt_blob, rtems_fdt_index_entry, rtems_fdt_shell_cmd, rtems_initialization_tasks_table, rtems_interrupt_server_config, rtems_message_queue_config, rtems_profiling_smp_lock, rtems_rap_app, rtems_rtl_archive, rtems_rtl_obj_sect, rtems_rtl_obj_sect_finder, rtems_rtl_obj_sym, rtems_rtl_rap_sectdef, rtems_rtl_shell_cmd, rtems_rtl_unresolv_rec, rtems_rtl_unresolv_reloc, rtems_rtl_unresolv_symbol, rtems_rtl_unresolved_archive_reloc_data, rtems_rtl_unresolved_reloc_data, rtems_stack_checker_info, rtems_task_config, rtems_trace_buffering_shell_cmd_t, RtemsSchedulerReqIdent_Context, RtemsSupportReqIsNameValid_Context, RtemsTimerReqCreate_Context, rtl_unresolved_name_data, section_detail, Thread_Configuration, Thread_queue_Queue
- name_length : Objects_Information
- name_local_object : RtemsReqIdent_Context, RtemsReqIdentLocal_Context
- name_p : Objects_Name
- name_rec : rtems_rtl_unresolved_reloc_data
- name_u32 : Objects_Name
- names : rtems_fdt_index, rtems_rtl_archive_symbols, rtems_rtl_obj_print
- NandBank : FMC_NAND_InitTypeDef
- NANDCR0 : SEMC_Type
- NANDCR1 : SEMC_Type
- NANDCR2 : SEMC_Type
- NANDCR3 : SEMC_Type
- nargs : ofw_args_t
- nb_codec_ovf : ISI_Descriptors
- nb_prev_ovf : ISI_Descriptors
- NbrOfConversion : ADC_InitTypeDef
- NbrOfDiscConversion : ADC_InitTypeDef
- NbRxDataToProcess : __SMARTCARD_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef
- NbSectors : FLASH_CRCInitTypeDef, FLASH_EraseInitTypeDef
- NbSectorsToErase : FLASH_ProcessTypeDef
- NBTP : FDCAN_GlobalTypeDef
- NbTxDataToProcess : __SMARTCARD_HandleTypeDef, __UART_HandleTypeDef, __USART_HandleTypeDef
- NBYTES : _edma_tcd
- nbytes : _flexio_camera_edma_handle, _flexio_i2s_edma_handle, _flexio_spi_master_edma_handle, _flexio_uart_edma_handle, _flexspi_dma_handle, _flexspi_edma_handle, _lpi2c_master_edma_handle, _lpspi_master_edma_handle, _lpspi_slave_edma_handle, _lpuart_edma_handle, _pdm_sdma_handle, _spdif_edma_handle, sai_edma_handle
- NBYTES_MLNO : DMA_Type
- NBYTES_MLOFFNO : DMA_Type
- NBYTES_MLOFFYES : DMA_Type
- NDAT1 : FDCAN_GlobalTypeDef
- NDAT2 : FDCAN_GlobalTypeDef
- NDTR : DMA_Stream_TypeDef
- needColorConvert : _flexio_mculcd_smartdma_handle
- needExitNoCmdMode : _flexspi_nor_config
- needRestart : _flexio_i2c_master_handle
- needRestoreNoCmdMode : _flexspi_nor_config
- nest_level : CORE_recursive_mutex_Control
- nested : ScoreMtxReqSurrender_Context
- nested_request : RtemsTaskReqRestart_Context
- new_priority : RtemsSemReqSetPriority_Context, RtemsTaskReqSetPriority_Context, RtemsTaskReqSetScheduler_Context
- new_scheduler : RtemsTaskReqSetScheduler_Context
- next : Chain_Node, drvmgr_bus, drvmgr_bus_res, drvmgr_dev, drvmgr_drv, Heap_Block
- Next : ISI_FrameBufferDescriptors
- NEXT : PXP_Type
- next : rtems_blkdev_read_ahead, rtems_debugger_threads, rtems_fdisk_segment_ctl, rtems_interrupt_entry, rtems_interrupt_server_action
- NEXT_BUF : LCDIF_Type
- next_in_bus : drvmgr_dev
- next_in_drv : drvmgr_dev
- next_length : Rate_monotonic_Control
- nfo : tte_data
- ngroups : rtems_user_env_t
- NLR : DMA2D_TypeDef
- node : _rtems_rfs_inode_handle
- Node : CORE_message_queue_Buffer
- node : mmap_mappings_s, MPCI_Configuration
- Node : Objects_Control, Priority_Aggregation
- node : Priority_Aggregation
- Node : Priority_Node
- node : rtems_blkdev_read_ahead, rtems_fdt_blob, rtems_interrupt_server_control, rtems_interrupt_server_entry, rtems_rap_app, rtems_rtl_archive, rtems_rtl_obj_depends, rtems_rtl_obj_sect, rtems_rtl_obj_sym, rtems_rtl_ptr, rtems_rtl_ptr_chain, rtems_rtl_sptr_chain
- Node : Scheduler_EDF_Node, Scheduler_EDF_SMP_Ready_queue, TOD_Hook, Watchdog_Control
- node_destroy : Scheduler_Operations
- node_handle : ofw_tree_node
- node_initialize : Scheduler_Operations
- nodes : Thread_Scheduler_control
- NoDivider : SAI_InitTypeDef
- NoErase : RTC_TamperTypeDef
- noiseFilterAdjustment : _pdm_hwvad_noise_filter
- noiseGain : _pdm_hwvad_noise_filter
- NonInvertingInput : COMP_InitTypeDef, OPAMP_InitTypeDef
- NORCR0 : SEMC_Type
- NORCR1 : SEMC_Type
- NORCR2 : SEMC_Type
- NORCR3 : SEMC_Type
- normal_mode : RtemsSignalReqCatch_Context
- NoStretchMode : I2C_InitTypeDef, SMBUS_InitTypeDef
- notepads_enabled : rtems_api_configuration_table
- now : RtemsTaskReqWakeAfter_Context, RtemsTaskReqWakeWhen_Context
- now_monotonic : CReqClockNanosleep_Context
- now_realtime : CReqClockNanosleep_Context
- npc : CPU_Exception_frame, CPU_Interrupt_frame
- nPRIV : CONTROL_Type
- nr_blocks : rtems_blkdev_read_ahead
- nret : ofw_args_t
- NSAC : HAL_MMC_CardCSDTypeDef, HAL_SD_CardCSDTypeDef
- NSBank : FMC_NORSRAM_InitTypeDef
- nsize : _flexspi_dma_handle, _flexspi_edma_handle
- NSS : SPI_InitTypeDef
- NSSPMode : SPI_InitTypeDef
- NSSPolarity : SPI_InitTypeDef
- num : _AsyncTwi
- num_entries : rtems_fdt_index
- NumBD : TaskSetupParamSet_t
- number : Heap_Information, RtemsEventValEventConstant_Context, RtemsSignalValSignalConstant_Context
- number_of_initialization_tasks : rtems_api_configuration_table
- number_of_pending_messages : CORE_message_queue_Control
- number_of_readers : CORE_RWLock_Control
- number_of_used_blocks : Partition_Control
- number_of_waiting_threads : CORE_barrier_Control
- NumberOfBanks : RTEMS_PACKED
- NumberOfImagePages : RTEMS_PACKED
- NumberOfPlanes : RTEMS_PACKED
- NumBitsECC : XNandPsu_Geometry
- NumBitsPerCell : XNandPsu_Geometry
- NumBlocks : XNandPsu_Geometry
- NumBytes : TaskSetupParamSet_t
- numerator : _clock_audio_pll_config, _clock_audio_pll_gpc_config, _clock_sys_pll_config, _clock_video_pll_config
- numExtraEoTp : _dsi_config
- numLanes : _dsi_config
- NumLuns : __attribute__, XNandPsu_Geometry
- NumMsg : XQspiPsu
- NumOfParamPages : __attribute__
- NumPages : XNandPsu_Geometry
- NumTargetBlocks : XNandPsu_Geometry
- NumTargetPages : XNandPsu_Geometry
- NumTargets : XNandPsu_Geometry
- nv_ops : rtems_nvdisk_device_desc
- NVDDR2Features : __attribute__
- NVDDR2TimingMode : __attribute__
- NVDDR2WarmupCycles : __attribute__
- NVDDRTimingMode : __attribute__
- NWELLRegulatorSize : _pmu_gpc_body_bias_config
