RTEMS 6.1-rc1
Test context for spec:/rtems/task/req/wake-after test case. More...
T_scheduler_log_4 scheduler_log
 This member provides the scheduler operation records.
uint64_t now
 This member contains the clock tick value before the rtems_task_wake_after() call.
rtems_id worker_id
 This member contains the worker task identifier.
bool suspended
 If this member is true, then the worker shall be suspended during the rtems_task_wake_after() call.
TaskTimerInfo timer_info
 This member contains the timer information of the worker task.
rtems_status_code status
 This member contains the return value of the rtems_task_wake_after() call.
rtems_interval ticks
 This member specifies the ticks parameter value.
struct {
   size_t   pcs [2]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsTaskReqWakeAfter_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
