RTEMS 6.1-rc1
Test context for spec:/rtems/sem/req/set-priority test case. More...
rtems_id runner_scheduler_id
 This member contains the scheduler identifier of the runner task.
rtems_id other_scheduler_id
 This member contains the scheduler identifier of a scheduler not used by the runner task.
uint32_t count
 This member specifies the initial count of the semaphore.
rtems_attribute attribute_set
 This member specifies the attribute set of the semaphore.
rtems_id the_semaphore_id
 This member contains the semaphore identifier.
bool valid_id
 If this member is true, then the semaphore_id parameter value shall be associated with the semaphore, otherwise it shall be not associated with a semaphore.
rtems_task_priority old_priority_value
 This member may contain the task priority returned by rtems_semaphore_set_priority().
rtems_id semaphore_id
 This member specifies the semaphore_id parameter for the rtems_semaphore_set_priority() call.
rtems_id scheduler_id
 This member specifies the scheduler_id parameter for the rtems_semaphore_set_priority() call.
rtems_task_priority new_priority
 This member specifies the new_priority parameter for the rtems_semaphore_set_priority() call.
rtems_task_priorityold_priority
 This member specifies the old_priority parameter for the rtems_semaphore_set_priority() call.
rtems_status_code status
 This member contains the status of the rtems_semaphore_set_priority() call.
struct {
   size_t   pcs [5]
 This member defines the pre-condition states for the next action.
   bool   in_action_loop
 If this member is true, then the test action loop is executed.
   size_t   index
 This member contains the next transition map index.
   RtemsSemReqSetPriority_Entry   entry
 This member contains the current transition map entry.
   bool   skip
 If this member is true, then the current transition variant should be skipped.
Map
