RTEMS 6.1-rc1
Test context for spec:/rtems/task/req/set-scheduler test case. More...
Data Fields | |
rtems_id | runner_id |
This member contains the runner task identifier. | |
rtems_id | scheduler_a_id |
This member contains the scheduler A identifier. | |
rtems_id | scheduler_b_id |
This member contains the scheduler B identifier. | |
rtems_id | scheduler_d_id |
This member contains the scheduler D identifier. | |
rtems_id | worker_id [3] |
This member contains the worker task identifiers. | |
rtems_id | mutex_id [2] |
This member contains the mutex identifiers. | |
bool | additional_home_priority |
If this member is true, then the task shall have an additional priority for the home scheduler. | |
bool | second_eligible_scheduler |
If this member is true, then the task shall have a second eligible scheduler. | |
bool | pinned |
If this member is true, then the task shall be pinned to a processor. | |
bool | blocked |
If this member is true, then the task shall be blocked. | |
bool | enqueued |
If this member is true, then the task shall be enqueued on a thread queue. | |
rtems_id | scheduler_to_set_id |
This member specifies the scheduler identifier to set. | |
bool | affinity_supported |
If this member is true, then the affinity of the task shall be supported by the scheduler. | |
rtems_status_code | status |
This member contains the return value of the rtems_task_set_scheduler() call. | |
rtems_id | task_id |
This member specifies if the task_id parameter value. | |
rtems_id | scheduler_id |
This member specifies if the scheduler_id parameter value. | |
rtems_task_priority | priority |
This member specifies if the priority parameter value. | |
rtems_id | new_scheduler |
This member contains the identifier of the new scheduler. | |
rtems_task_priority | new_priority [2] |
This member contains the new priorities of the task. | |
struct { | |
size_t pci [10] | |
This member defines the pre-condition indices for the next action. | |
size_t pcs [10] | |
This member defines the pre-condition states for the next action. | |
bool in_action_loop | |
If this member is true, then the test action loop is executed. | |
size_t index | |
This member contains the next transition map index. | |
RtemsTaskReqSetScheduler_Entry entry | |
This member contains the current transition map entry. | |
bool skip | |
If this member is true, then the current transition variant should be skipped. | |
} | Map |
