RTEMS  5.1
Modules | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
i386 Specific Support
i386 specific support. More...
 Processor Dependent Interrupt Management
 i386 Interrupt Management
 i386 Assembler Support
 i386 Paravirtualization Support
struct  Context_Control
 Thread register context. More...
struct  Context_Control_fp
 SPARC basic context. More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_CACHE_LINE_BYTES   64
#define CPU_STRUCTURE_ALIGNMENT
#define CPU_MAXIMUM_PROCESSORS   32
#define I386_CONTEXT_CONTROL_EFLAGS_OFFSET   0
#define I386_CONTEXT_CONTROL_ESP_OFFSET   4
#define I386_CONTEXT_CONTROL_EBP_OFFSET   8
#define I386_CONTEXT_CONTROL_EBX_OFFSET   12
#define I386_CONTEXT_CONTROL_ESI_OFFSET   16
#define I386_CONTEXT_CONTROL_EDI_OFFSET   20
#define I386_CONTEXT_CONTROL_GS_0_OFFSET   24
#define I386_CONTEXT_CONTROL_GS_1_OFFSET   28
#define I386_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   32
#define _CPU_Context_Get_SP(_context)   (_context)->esp
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MODES_INTERRUPT_MASK   0x00000001 /* interrupt level in mode */
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   1024
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define _CPU_ISR_Disable(_level)   i386_disable_interrupts( _level )
#define _CPU_ISR_Enable(_level)   i386_enable_interrupts( _level )
#define _CPU_ISR_Flash(_level)   i386_flash_interrupts( _level )
#define _CPU_ISR_Set_level(_new_level)
#define _CPU_Interrupt_stack_setup(_lo, _hi)
#define CPU_EFLAGS_INTERRUPTS_ON   0x00003202
#define CPU_EFLAGS_INTERRUPTS_OFF   0x00003002
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_fp_area)
#define CPU_USE_GENERIC_BITFIELD_CODE   FALSE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)   ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)   (_priority)
#define CPU_PER_CPU_CONTROL_SIZE   0
#define CPU_INTERRUPT_FRAME_SIZE   52
typedef void(* cpuExcHandlerType) (CPU_Exception_frame *)
typedef void(* CPU_ISR_handler) (void)
typedef uint32_t CPU_Counter_ticks
enum  Intel_symbolic_exception_name {
  I386_EXCEPTION_DIVIDE_BY_ZERO = 0, I386_EXCEPTION_DEBUG = 1, I386_EXCEPTION_NMI = 2, I386_EXCEPTION_BREAKPOINT = 3,
  I386_EXCEPTION_OVERFLOW = 4, I386_EXCEPTION_BOUND = 5, I386_EXCEPTION_ILLEGAL_INSTR = 6, I386_EXCEPTION_MATH_COPROC_UNAVAIL = 7,
  I386_EXCEPTION_DOUBLE_FAULT = 8, I386_EXCEPTION_I386_COPROC_SEG_ERR = 9, I386_EXCEPTION_INVALID_TSS = 10, I386_EXCEPTION_SEGMENT_NOT_PRESENT = 11,
  I386_EXCEPTION_STACK_SEGMENT_FAULT = 12, I386_EXCEPTION_GENERAL_PROT_ERR = 13, I386_EXCEPTION_PAGE_FAULT = 14, I386_EXCEPTION_INTEL_RES15 = 15,
  I386_EXCEPTION_FLOAT_ERROR = 16, I386_EXCEPTION_ALIGN_CHECK = 17, I386_EXCEPTION_MACHINE_CHECK = 18, I386_EXCEPTION_ENTER_RDBG = 50
void rtems_exception_init_mngt (void)
RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled (uint32_t level)
uint32_t _CPU_ISR_Get_level (void)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context. More...
void _CPU_Fatal_halt (uint32_t source, uint32_t error) RTEMS_NO_RETURN
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_vector (uint32_t vector, CPU_ISR_handler new_handler, CPU_ISR_handler *old_handler)
void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context) RTEMS_NO_RETURN
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
uint32_t _CPU_Counter_frequency (void)
CPU_Counter_ticks _CPU_Counter_read (void)
RTEMS_INLINE_ROUTINE void _CPU_Context_volatile_clobber (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Context_validate (uintptr_t pattern)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal (void)
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation (void)
cpuExcHandlerType _currentExcHandler
Context_Control_fp _CPU_Null_fp_context
i386 Architecture Support
This include file contains information pertaining to the Intel i386 processor.
This file contains definitions for data structure related to Intel system programming. More information can be found on Intel site and more precisely in the following book :
Pentium Processor familly
Developper's Manual
Volume 3 : Architecture and Programming Manual
Formerly contained in and extracted from libcpu/i386/cpu.h.
This file contains definition and constants related to Intel Cpu
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
uint16_t __value_in_register = ( _value ); \
uint16_t __output = 0; \
__asm__ volatile ( "bsfw %0,%1 " \
: "=r" ( __value_in_register ), "=r" ( __output ) \
: "0" ( __value_in_register ), "1" ( __output ) \
( _output ) = __output; \
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _fp_area)
Value:
memcpy( *_fp_area, &_CPU_Null_fp_context, CPU_CONTEXT_FP_SIZE ); \
Definition: cpu.h:652
◆ _CPU_Interrupt_stack_setup
#define _CPU_Interrupt_stack_setup (   _lo,
  _hi
Value:
do { \
_hi = (void*)(((uintptr_t)(_hi) - 4) & ~ (CPU_STACK_ALIGNMENT - 1)); \
} while (0)
Definition: cpu.h:308
◆ _CPU_ISR_Set_level
#define _CPU_ISR_Set_level (   _new_level)
Value:
if ( _new_level ) __asm__ volatile ( "cli" ); \
else __asm__ volatile ( "sti" ); \
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
◆ _CPU_Context_Initialize()
void _CPU_Context_Initialize ( Context_Control the_context,
void *  stack_area_begin,
uint32_t  new_level,
void(*)(void)  entry_point,
bool  is_fp,
void *  tls_area
The following steps are performed:
  • setting a starting address
  • preparing the stack
  • preparing the stack and frame pointers
  • setting the proper interrupt level in the context
Parameters
[in]contextpoints to the context area
[in]stack_area_beginis the low address of the allocated stack area
[in]stack_area_sizeis the size of the stack area in bytes
[in]new_levelis the interrupt level for the task
[in]entry_pointis the task's entry point
[in]is_fpis set to true if the task is a floating point task
[in]tls_areais the thread-local storage (TLS) area
◆ _CPU_Context_restore()
void _CPU_Context_restore ( Context_Control new_context)
This routine is generally used only to restart self in an efficient manner. It may simply be a label in _CPU_Context_switch.
Parameters
[in]new_contextpoints to the context to be restored.
Note
May be unnecessary to reload some registers.
Port Specific Information:
XXX document implementation including references if appropriate
◆ _CPU_Context_switch()
void _CPU_Context_switch ( Context_Control run,
Context_Control heir
CPU switch context.
This routine switches from the run context to the heir context.
Parameters
[in]runpoints to the context of the currently executing task
[in]heirpoints to the context of the heir task
◆ _CPU_Exception_frame_print()
void _CPU_Exception_frame_print ( const CPU_Exception_frame frame)
See also
rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
◆ _CPU_Fatal_halt()
void _CPU_Fatal_halt ( uint32_t  source,
uint32_t  error
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license/LICENSE.
◆ _CPU_Initialize()
void _CPU_Initialize ( void  )
CPU initialization.
CPU initialize. This routine performs CPU dependent initialization.
CPU initialization.
◆ _CPU_ISR_Get_level()
uint32_t _CPU_ISR_Get_level ( void  )
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode.
Note
This routine usually must be implemented as a subroutine.
