RTEMS
5.1
#define | TRUE 1 |
#define | FALSE 0 |
#define | RTEMS_INLINE_ROUTINE static inline |
#define | RTEMS_COMPILER_MEMORY_BARRIER() |
#define | RTEMS_NO_INLINE |
#define | RTEMS_NO_RETURN |
#define | RTEMS_COMPILER_NO_RETURN_ATTRIBUTE RTEMS_NO_RETURN |
#define | RTEMS_CONST |
#define | RTEMS_PURE |
#define | RTEMS_COMPILER_PURE_ATTRIBUTE RTEMS_PURE |
#define | RTEMS_DEPRECATED |
Public name for task floating point context area. More... | |
#define | RTEMS_COMPILER_DEPRECATED_ATTRIBUTE RTEMS_DEPRECATED |
#define | RTEMS_SECTION(_section) |
Instructs the compiler to place a specific variable or function in the specified section. | |
#define | RTEMS_USED |
Instructs the compiler that a specific variable or function is used. | |
#define | RTEMS_UNUSED |
#define | RTEMS_COMPILER_UNUSED_ATTRIBUTE RTEMS_UNUSED |
#define | RTEMS_PACKED |
#define | RTEMS_ALIAS(_target) |
Instructs the compiler to generate an alias to the specified target function. | |
#define | RTEMS_WEAK_ALIAS(_target) |
Instructs the compiler to generate a weak alias to the specified target function. | |
#define | RTEMS_ALIGNED(_alignment) |
Instructs the compiler to enforce the specified alignment. | |
#define | RTEMS_COMPILER_PACKED_ATTRIBUTE RTEMS_PACKED |
#define | _Assert_Unreachable() do { } while ( 0 ) |
#define | RTEMS_UNREACHABLE() _Assert_Unreachable() |
Tells the compiler that this program point is unreachable. | |
#define | RTEMS_PRINTFLIKE(_format_pos, _ap_pos) |
Tells the compiler that this function expects printf()-like arguments. | |
#define | RTEMS_MALLOCLIKE |
Tells the compiler that this function is a memory allocation function similar to malloc(). | |
#define | RTEMS_ALLOC_SIZE(_index) |
Tells the compiler the memory allocation size parameter of this function similar to malloc(). | |
#define | RTEMS_ALLOC_SIZE_2(_count_index, _size_index) |
Tells the compiler the memory allocation item count and item size parameter of this function similar to calloc(). | |
#define | RTEMS_ALLOC_ALIGN(_index) |
Tells the compiler the memory allocation alignment parameter of this function similar to aligned_alloc(). | |
#define | RTEMS_WARN_UNUSED_RESULT |
Tells the compiler that the result of this function should be used. | |
#define | RTEMS_OBFUSCATE_VARIABLE(_var) (void) (_var) |
Obfuscates the variable so that the compiler cannot perform optimizations based on the variable value. More... | |
#define | RTEMS_DECLARE_GLOBAL_SYMBOL(_name) extern char _name[] |
Declares a global symbol with the specified name. More... | |
#define | _RTEMS_SYMBOL_NAME(_name) _name |
Constructs a symbol name. More... | |
#define | RTEMS_SYMBOL_NAME(_name) _RTEMS_SYMBOL_NAME( _name ) |
#define | RTEMS_DEFINE_GLOBAL_SYMBOL(_name, _value) |
Defines a global symbol with the specified name and value. More... | |
#define | RTEMS_PREDICT_TRUE(_exp) ( _exp ) |
Returns the value of the specified integral expression and tells the compiler that the predicted value is true (1). More... | |
#define | RTEMS_PREDICT_FALSE(_exp) ( _exp ) |
Returns the value of the specified integral expression and tells the compiler that the predicted value is false (0). More... | |
#define | RTEMS_RETURN_ADDRESS() NULL |
Returns the return address of the current function. More... | |
#define | RTEMS_STATIC_ASSERT(cond, msg) |
#define | RTEMS_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0])) |
#define | RTEMS_ZERO_LENGTH_ARRAY 0 |
#define | RTEMS_CONTAINER_OF(_m, _type, _member_name) ( (_type *) ( (uintptr_t) ( _m ) - offsetof( _type, _member_name ) ) ) |
Returns a pointer to the container of a specified member pointer. More... | |
#define | RTEMS_TYPEOF_REFX(_ptr_level, _ptr_type) __typeof__(_ptr_level(union { int z; __typeof__(_ptr_type) x; }){0}.x) |
#define | RTEMS_DECONST(_type, _var) ((_type)(uintptr_t)(const void *) ( _var )) |
Removes the const qualifier from a type of a variable. More... | |
#define | RTEMS_DEVOLATILE(_type, _var) ((_type)(uintptr_t)(volatile void *) ( _var )) |
Removes the volatile qualifier from a type of a variable. More... | |
#define | RTEMS_DEQUALIFY(_type, _var) ((_type)(uintptr_t)(const volatile void *) ( _var )) |
Removes the all qualifiers from a type of a variable. More... | |
#define | RTEMS_HAVE_MEMBER_SAME_TYPE(_t_lhs, _m_lhs, _t_rhs, _m_rhs) true |
Evaluates to true if the members of two types have the same type. More... | |
#define | RTEMS_CONCAT(_x, _y) _x##_y |
Concatenates _x and _y without expanding. | |
#define | RTEMS_XCONCAT(_x, _y) RTEMS_CONCAT( _x, _y ) |
Concatenates expansion of _x and expansion of _y. | |
#define | RTEMS_STRING(_x) #_x |
Stringifies _x without expanding. | |
#define | RTEMS_XSTRING(_x) RTEMS_STRING( _x ) |
Stringifies expansion of _x. | |
Typedefs | |
typedef void *proc_ptr | RTEMS_DEPRECATED |
#define _RTEMS_SYMBOL_NAME | ( | _name | ) | _name |
_name | The user defined name of the symbol. The name shall be a valid designator. On the name a macro expansion is performed. |
#define FALSE 0 |
This ensures that RTEMS has FALSE defined in all situations.
#define RTEMS_COMPILER_MEMORY_BARRIER | ( | ) |
The following macro is a compiler specific way to ensure that memory writes are not reordered around certain points. This specifically can impact interrupt disable and thread dispatching critical sections.
#define RTEMS_CONST |
The following defines a compiler specific attribute which informs the compiler that the method has no effect except the return value and that the return value depends only the value of parameters.
#define RTEMS_CONTAINER_OF | ( | _m, | |
_type, | |||
_member_name | |||
) | ( (_type *) ( (uintptr_t) ( _m ) - offsetof( _type, _member_name ) ) ) |
[in] | _m | The pointer to a member of the container. |
[in] | _type | The type of the container. |
[in] | _member_name | The designator name of the container member. |
#define RTEMS_DECLARE_GLOBAL_SYMBOL | ( | _name | ) | extern char _name[] |
This macro must be placed at file scope.
The name must be a valid designator.
#define RTEMS_DECONST | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(const void *) ( _var )) |
[in] | _type | The target type for the variable. |
[in] | _var | The variable. |
#define RTEMS_DEFINE_GLOBAL_SYMBOL | ( | _name, | |
_value | |||
This macro shall be placed at file scope.
_name | The user defined name of the symbol. The name shall be a valid designator. On the name a macro expansion is performed and afterwards it is stringified. |
_value | The value of the symbol. On the value a macro expansion is performed and afterwards it is stringified. It shall expand to an integer expression understood by the assembler. |
typedef struct timespec rtems_thread_cpu_usage_t RTEMS_DEPRECATED |
Represents the CPU usage per thread.
Information structure returned by the Heap Handler via the Region Manager.
Instructs the compiler to issue a warning whenever a variable or function with this attribute will be used.
When using nanoseconds granularity timing, RTEMS may internally use a variety of representations.
#define RTEMS_DEQUALIFY | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(const volatile void *) ( _var )) |
#define RTEMS_DEVOLATILE | ( | _type, | |
_var | |||
) | ((_type)(uintptr_t)(volatile void *) ( _var )) |
#define RTEMS_HAVE_MEMBER_SAME_TYPE | ( | _t_lhs, | |
_m_lhs, | |||
_t_rhs, | |||
_m_rhs | |||
) | true |
[in] | _t_lhs | Left hand side type. |
[in] | _m_lhs | Left hand side member. |
[in] | _t_rhs | Right hand side type. |
[in] | _m_rhs | Right hand side member. |
#define RTEMS_INLINE_ROUTINE static inline |
The following (in conjunction with compiler arguments) are used to choose between the use of static inline functions and macro functions. The static inline implementation allows better type checking with no cost in code size or execution speed.
#define RTEMS_NO_INLINE |
The following defines a compiler specific attribute which informs the compiler that the method must not be inlined.
#define RTEMS_NO_RETURN |
The following macro is a compiler specific way to indicate that the method will NOT return to the caller. This can assist the compiler in code generation and avoid unreachable paths. This can impact the code generated following calls to rtems_fatal_error_occurred and _Terminate.
#define RTEMS_OBFUSCATE_VARIABLE | ( | _var | ) | (void) (_var) |
The variable must be simple enough to fit into a register.
#define RTEMS_PACKED |
Instructs the compiler that a specific structure or union members will be placed so that the least memory is used.
#define RTEMS_PREDICT_FALSE | ( | _exp | ) | ( _exp ) |
[in] | _exp | The expression. |
#define RTEMS_PREDICT_TRUE | ( | _exp | ) | ( _exp ) |
#define RTEMS_PURE |
The following defines a compiler specific attribute which informs the compiler that the method has no effect except the return value and that the return value depends only on parameters and/or global variables.
#define RTEMS_RETURN_ADDRESS | ( | ) | NULL |
#define RTEMS_STATIC_ASSERT | ( | cond, | |
msg | |||
#define RTEMS_UNUSED |
Instructs the compiler that a specific variable is deliberately unused. This can occur when reading volatile device memory or skipping arguments in a variable argument method.
#define TRUE 1 |
This ensures that RTEMS has TRUE defined in all situations.
typedef void* proc_ptr RTEMS_DEPRECATED |
XXX: Eventually proc_ptr needs to disappear!!!
