RTEMS
5.1
Provides services for all APIs. More...
Modules | |
API Mutex Handler | |
Provides routines to ensure mutual exclusion on API level. | |
Address Handler | |
Support for Address Manipulation. | |
Assert Handler | |
Support for Assert Statements. | |
Atomic Operations | |
Support for atomic operations. | |
Atomic Operations CPU | |
Atomic Operations CPU API. | |
Barrier Handler | |
Functionality for Foundation Barrier Services. | |
Basic Definitions | |
Bitmap Priority Thread Routines | |
Bitmap Priority Thread Routines. | |
CPU Architecture Support | |
Provides CPU architecture dependent services. | |
Chain Handler | |
Provides Data Structures Chain Node and Chain Control. | |
Context Handler | |
Functionality for Abstraction of Thread Context Management. | |
Freechain Handler | |
The Freechain Handler. | |
Heap Handler | |
The Heap Handler provides a heap. | |
Helpers | |
Timespec Helpers. | |
ISR Handler | |
ISR Handler. | |
Internal Error Handler | |
Internal Error Handler. | |
MP Packet Handler | |
MP Packte Handler. | |
MPCI Handler | |
MPCI Handler. | |
Memory Handler | |
Low level handler to provide memory areas for higher level memory handlers such as the Workspace Handler. | |
Message Queue Handler | |
Message Queue Handler. | |
Mutex Handler | |
Mutex Handler. | |
Object Handler Multiprocessing Support | |
Object Handler Multiprocessing Support. | |
Once Functions. | |
The _Once() function for pthread_once() and rtems_gxx_once(). | |
Priority Handler | |
Priority Handler. | |
Processor Mask | |
Processor Mask. | |
Profiling Support | |
Profiling support. | |
RTEMS Copyright Notice | |
Copyright Notice for RTEMS. | |
RTEMS Per CPU Information | |
Red-Black Tree Handler | |
Red-Black Tree Handler. | |
SMP Barriers | |
The SMP barrier provides barrier synchronization for SMP systems at the lowest level. | |
SMP Locks | |
The SMP lock provides mutual exclusion for SMP systems at the lowest level. | |
SMP Support | |
SMP Support. | |
Scheduler Handler | |
Score Timestamp | |
Score Timestamp. | |
ScoreRWLock | |
ScoreRWLock. | |
Semaphore Handler | |
Semaphore Handler. | |
Set Errno | |
Stack Handler | |
Stack Handler. | |
System Information | |
System State Handler | |
Management of the internal system state of RTEMS. | |
Thread Handler | |
Thread Handler. | |
Thread Handler Multiprocessing Support | |
Thread Handler Multiprocessing Support. | |
Thread Queue Handler | |
Thread Queue Handler. | |
Thread States | |
SuperCore Thread States. | |
Thread-Local Storage (TLS) | |
Thread-local storage (TLS) support. | |
Time of Day Handler | |
Time of Day Handler. | |
Timecounter Handler | |
Timecounter Handler. | |
User Extension Handler | |
The User Extension Handler provides invocation of application dependent routines at critical points in the life of each thread and the system as a whole. | |
Watchdog Handler | |
Watchdog Handler. | |
Workspace Handler | |
Files | |
file | basedefs.h |
Basic Definitions. | |
file | objectgetinfoid.c |
Get Information of an Object from an ID. | |
file | objectgetnameasstring.c |
Extracts a Node from a Chain. | |
file | objectnamespaceremove.c |
Removes Object from Namespace. | |
file | objectnametoid.c |
Object Name To Id. | |
file | smp.c |
SMP Support. | |
