rtems_task_priority | _RTEMS_Maximum_priority (void) |
rtems_status_code | rtems_task_create (rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id) |
| RTEMS Task Create. More...
rtems_status_code | rtems_task_ident (rtems_name name, uint32_t node, rtems_id *id) |
| RTEMS Task Name to Id. More...
rtems_status_code | rtems_task_delete (rtems_id id) |
| RTEMS Delete Task. More...
void | rtems_task_exit (void) RTEMS_NO_RETURN |
rtems_status_code | rtems_task_mode (rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set) |
| RTEMS Task Mode. More...
rtems_status_code | rtems_task_restart (rtems_id id, rtems_task_argument argument) |
| RTEMS Task Restart. More...
rtems_status_code | rtems_task_suspend (rtems_id id) |
| RTEMS Suspend Task. More...
rtems_status_code | rtems_task_resume (rtems_id id) |
| RTEMS Resume Task. More...
rtems_status_code | rtems_task_set_priority (rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority) |
| RTEMS Set Task Priority. More...
rtems_status_code | rtems_task_get_priority (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority *priority) |
| Gets the current priority of the specified task with respect to the specified scheduler instance. More...
rtems_status_code | rtems_task_start (rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument) |
| RTEMS Start Task. More...
rtems_status_code | rtems_task_wake_when (rtems_time_of_day *time_buffer) |
| RTEMS Task Wake When. More...
rtems_status_code | rtems_task_wake_after (rtems_interval ticks) |
| RTEMS Task Wake After. More...
rtems_status_code | rtems_task_is_suspended (rtems_id id) |
| rtems_task_is_suspended More...
rtems_status_code | rtems_task_get_affinity (rtems_id id, size_t cpusetsize, cpu_set_t *cpuset) |
| Gets the processor affinity set of a task. More...
rtems_status_code | rtems_task_set_affinity (rtems_id id, size_t cpusetsize, const cpu_set_t *cpuset) |
| Sets the processor affinity set of a task. More...
rtems_status_code | rtems_task_get_scheduler (rtems_id task_id, rtems_id *scheduler_id) |
| Gets the scheduler of a task. More...
rtems_status_code | rtems_task_set_scheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority) |
| Sets the scheduler instance of a task. More...
rtems_id | rtems_task_self (void) |
| RTEMS Get Self Task Id. More...
void | rtems_task_iterate (rtems_task_visitor visitor, void *arg) |
| Iterates over all tasks in the system. More...
rtems_status_code | rtems_scheduler_ident (rtems_name name, rtems_id *id) |
| Identifies a scheduler by its name. More...
rtems_status_code | rtems_scheduler_ident_by_processor (uint32_t cpu_index, rtems_id *id) |
| Identifies a scheduler by a processor index. More...
rtems_status_code | rtems_scheduler_ident_by_processor_set (size_t cpusetsize, const cpu_set_t *cpuset, rtems_id *id) |
| Identifies a scheduler by a processor set. More...
RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t | rtems_get_current_processor (void) |
| Returns the index of the current processor. More...
RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t | rtems_get_processor_count (void) |
| Returns the processor maximum supported by the system. More...
rtems_status_code | rtems_scheduler_get_processor_set (rtems_id scheduler_id, size_t cpusetsize, cpu_set_t *cpuset) |
| Gets the set of processors owned by the specified scheduler instance. More...
rtems_status_code | rtems_scheduler_add_processor (rtems_id scheduler_id, uint32_t cpu_index) |
| Adds a processor to the set of processors owned by the specified scheduler instance. More...
rtems_status_code | rtems_scheduler_remove_processor (rtems_id scheduler_id, uint32_t cpu_index) |
| Removes a processor from set of processors owned by the specified scheduler instance. More...
rtems_status_code | rtems_scheduler_get_maximum_priority (rtems_id scheduler_id, rtems_task_priority *priority) |
| Gets the maximum task priority of the specified scheduler instance. More...
rtems_status_code | rtems_scheduler_map_priority_to_posix (rtems_id scheduler_id, rtems_task_priority priority, int *posix_priority) |
| Map a task priority to the corresponding POSIX thread priority. More...
rtems_status_code | rtems_scheduler_map_priority_from_posix (rtems_id scheduler_id, int posix_priority, rtems_task_priority *priority) |
| Map a POSIX thread priority to the corresponding task priority. More...
