RTEMS  5.1
tasks.h
1
9 /*
10  * COPYRIGHT (c) 1989-2014.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  */
17
18 #ifndef _RTEMS_RTEMS_TASKS_H
19 #define _RTEMS_RTEMS_TASKS_H
20
21 #include <rtems/rtems/attr.h>
22 #include <rtems/rtems/status.h>
23 #include <rtems/rtems/types.h>
24 #include <rtems/score/smp.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif
29
44 #define RTEMS_SELF OBJECTS_ID_OF_SELF
45
50 #define RTEMS_YIELD_PROCESSOR WATCHDOG_NO_TIMEOUT
51
55 typedef uint32_t rtems_task_priority;
56
63 #define RTEMS_NO_PRIORITY RTEMS_CURRENT_PRIORITY
64
69 #define RTEMS_MINIMUM_PRIORITY 1
70
71 rtems_task_priority _RTEMS_Maximum_priority( void );
72
83 #define RTEMS_MAXIMUM_PRIORITY _RTEMS_Maximum_priority()
84
89 #define RTEMS_CURRENT_PRIORITY 0
90
91 struct _Thread_Control;
92
96 typedef struct _Thread_Control rtems_tcb;
97
101 typedef void rtems_task;
102
107
113  );
114
121 typedef struct {
125  size_t stack_size;
137
159  rtems_name name,
160  rtems_task_priority initial_priority,
161  size_t stack_size,
162  rtems_mode initial_modes,
163  rtems_attribute attribute_set,
164  rtems_id *id
165 );
166
188  rtems_name name,
189  uint32_t node,
190  rtems_id *id
191 );
192
208  rtems_id id
209 );
210
211 void rtems_task_exit( void ) RTEMS_NO_RETURN;
212
229  rtems_mode mode_set,
230  rtems_mode mask,
231  rtems_mode *previous_mode_set
232 );
233
247  rtems_id id,
248  rtems_task_argument argument
249 );
250
265  rtems_id id
266 );
267
281  rtems_id id
282 );
283
300  rtems_id id,
301  rtems_task_priority new_priority,
302  rtems_task_priority *old_priority
303 );
304
329  rtems_id task_id,
330  rtems_id scheduler_id,
331  rtems_task_priority *priority
332 );
333
344  rtems_id id,
345  rtems_task_entry entry_point,
346  rtems_task_argument argument
347 );
348
361  rtems_time_of_day *time_buffer
362 );
363
375  rtems_interval ticks
376 );
377
385  rtems_id id
386 );
387
406  rtems_id id,
407  size_t cpusetsize,
408  cpu_set_t *cpuset
409 );
410
439  rtems_id id,
440  size_t cpusetsize,
441  const cpu_set_t *cpuset
442 );
443
456  rtems_id task_id,
457  rtems_id *scheduler_id
458 );
459
484  rtems_id task_id,
485  rtems_id scheduler_id,
486  rtems_task_priority priority
487 );
488
495
507 typedef bool ( *rtems_task_visitor )( rtems_tcb *tcb, void *arg );
508
523 void rtems_task_iterate(
524  rtems_task_visitor visitor,
525  void *arg
526 );
527
541  rtems_name name,
542  rtems_id *id
543 );
544
558  uint32_t cpu_index,
559  rtems_id *id
560 );
561
582  size_t cpusetsize,
583  const cpu_set_t *cpuset,
584  rtems_id *id
585 );
586
604 #define rtems_scheduler_get_processor() _SMP_Get_current_processor()
605
615 RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t
617 {
619 }
620
637 #define rtems_scheduler_get_processor_maximum() _SMP_Get_processor_maximum()
638
648 RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t
650 {
652 }
653
671  rtems_id scheduler_id,
672  size_t cpusetsize,
673  cpu_set_t *cpuset
674 );
675
696  rtems_id scheduler_id,
697  uint32_t cpu_index
698 );
699
721  rtems_id scheduler_id,
722  uint32_t cpu_index
723 );
724
736  rtems_id scheduler_id,
737  rtems_task_priority *priority
738 );
739
753  rtems_id scheduler_id,
754  rtems_task_priority priority,
755  int *posix_priority
756 );
757
771  rtems_id scheduler_id,
772  int posix_priority,
773  rtems_task_priority *priority
774 );
775
778 #ifdef __cplusplus
779 }
780 #endif
781
782 #endif
783 /* end of include file */
bool(* rtems_task_visitor)(rtems_tcb *tcb, void *arg)
Task visitor.
Definition: tasks.h:507
uint32_t rtems_attribute
Definition: attr.h:41
rtems_status_code rtems_task_wake_after(rtems_interval ticks)
RTEMS Task Wake After.
Definition: taskwakeafter.c:25
rtems_status_code rtems_task_set_affinity(rtems_id id, size_t cpusetsize, const cpu_set_t *cpuset)
Sets the processor affinity set of a task.
Definition: tasksetaffinity.c:26
size_t stack_size
Definition: tasks.h:125
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
rtems_status_code rtems_task_get_scheduler(rtems_id task_id, rtems_id *scheduler_id)
Gets the scheduler of a task.
Definition: taskgetscheduler.c:22
rtems_status_code rtems_scheduler_ident(rtems_name name, rtems_id *id)
Identifies a scheduler by its name.
Definition: schedulerident.c:22
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
void rtems_task
Definition: tasks.h:101
RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t rtems_get_processor_count(void)
Returns the processor maximum supported by the system.
Definition: tasks.h:649
rtems_name name
Definition: tasks.h:123
rtems_status_code rtems_task_wake_when(rtems_time_of_day *time_buffer)
RTEMS Task Wake When.
Definition: taskwakewhen.c:27
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
rtems_status_code rtems_task_ident(rtems_name name, uint32_t node, rtems_id *id)
RTEMS Task Name to Id.
Definition: taskident.c:29
Definition: tasks.h:135
rtems_status_code rtems_scheduler_map_priority_from_posix(rtems_id scheduler_id, int posix_priority, rtems_task_priority *priority)
Map a POSIX thread priority to the corresponding task priority.
Definition: schedulermapfromposix.c:43
rtems_status_code rtems_scheduler_get_processor_set(rtems_id scheduler_id, size_t cpusetsize, cpu_set_t *cpuset)
Gets the set of processors owned by the specified scheduler instance.
Definition: schedulergetprocessorset.c:22
Definition: tasks.h:129
rtems_status_code rtems_task_mode(rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set)
RTEMS Task Mode.
Definition: taskmode.c:30
rtems_status_code rtems_task_get_affinity(rtems_id id, size_t cpusetsize, cpu_set_t *cpuset)
Gets the processor affinity set of a task.
Definition: taskgetaffinity.c:26
SuperCore SMP Support API.
rtems_status_code rtems_scheduler_ident_by_processor_set(size_t cpusetsize, const cpu_set_t *cpuset, rtems_id *id)
Identifies a scheduler by a processor set.
Definition: scheduleridentbyprocessorset.c:23
Definition: tasks.h:637
rtems_status_code rtems_task_create(rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
RTEMS Task Create.
Definition: taskcreate.c:36
Data structure to manage and manipulate calendar time.
Definition: types.h:141
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: thread.h:732
Definition: tasks.h:127
void rtems_task_iterate(rtems_task_visitor visitor, void *arg)
Iterates over all tasks in the system.
Definition: taskiterate.c:23
Definition: tasks.h:131
rtems_status_code rtems_task_delete(rtems_id id)
RTEMS Delete Task.
Definition: taskdelete.c:24
rtems_status_code rtems_scheduler_add_processor(rtems_id scheduler_id, uint32_t cpu_index)
Adds a processor to the set of processors owned by the specified scheduler instance.
Definition: scheduleraddprocessor.c:24
Returns the index of the current processor.
Definition: tasks.h:604
rtems_status_code rtems_task_start(rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument)
RTEMS Start Task.
Definition: taskstart.c:25
rtems_status_code rtems_task_set_scheduler(rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority)
Sets the scheduler instance of a task.
Definition: tasksetscheduler.c:23
rtems_status_code rtems_task_is_suspended(rtems_id id)
Definition: taskissuspended.c:25
rtems_id rtems_task_self(void)
RTEMS Get Self Task Id.
Definition: taskself.c:23
rtems_status_code rtems_task_set_priority(rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
RTEMS Set Task Priority.
Definition: tasksetpriority.c:61
RTEMS_DEPRECATED RTEMS_INLINE_ROUTINE uint32_t rtems_get_current_processor(void)
Definition: tasks.h:616
rtems_status_code rtems_scheduler_map_priority_to_posix(rtems_id scheduler_id, rtems_task_priority priority, int *posix_priority)
Map a task priority to the corresponding POSIX thread priority.
Definition: schedulermaptoposix.c:43
rtems_task(* rtems_task_entry)(rtems_task_argument)
Definition: tasks.h:111
CPU_Uint32ptr rtems_task_argument
Definition: tasks.h:106
uintptr_t CPU_Uint32ptr
Definition: cpu.h:662
rtems_mode mode_set
Definition: tasks.h:133
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
rtems_status_code rtems_scheduler_ident_by_processor(uint32_t cpu_index, rtems_id *id)
Identifies a scheduler by a processor index.
Definition: scheduleridentbyprocessor.c:23
rtems_status_code rtems_task_get_priority(rtems_id task_id, rtems_id scheduler_id, rtems_task_priority *priority)
Gets the current priority of the specified task with respect to the specified scheduler instance.
Definition: taskgetpriority.c:23
rtems_status_code rtems_task_restart(rtems_id id, rtems_task_argument argument)
RTEMS Task Restart.
Definition: taskrestart.c:24
Definition: tasks.h:121
uint32_t rtems_mode
Definition: modes.h:41
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
rtems_status_code rtems_scheduler_remove_processor(rtems_id scheduler_id, uint32_t cpu_index)
Removes a processor from set of processors owned by the specified scheduler instance.
Definition: schedulerremoveprocessor.c:64
rtems_status_code rtems_task_suspend(rtems_id id)
RTEMS Suspend Task.
Definition: tasksuspend.c:24
rtems_status_code rtems_scheduler_get_maximum_priority(rtems_id scheduler_id, rtems_task_priority *priority)
Gets the maximum task priority of the specified scheduler instance.
Definition: schedulergetmaxprio.c:35
rtems_status_code rtems_task_resume(rtems_id id)
RTEMS Resume Task.
Definition: taskresume.c:24
Definition: tasks.h:55
