RTEMS  5.1
Files | Macros | Typedefs
Attributes
file  attr.h
#define RTEMS_DEFAULT_ATTRIBUTES   0x00000000
#define RTEMS_LOCAL   0x00000000
#define RTEMS_GLOBAL   0x00000002
#define RTEMS_FIFO   0x00000000
#define RTEMS_PRIORITY   0x00000004
#define RTEMS_NO_FLOATING_POINT   0x00000000
#define RTEMS_FLOATING_POINT   0x00000001
#define RTEMS_SEMAPHORE_CLASS   0x00000030
#define RTEMS_COUNTING_SEMAPHORE   0x00000000
#define RTEMS_BINARY_SEMAPHORE   0x00000010
#define RTEMS_SIMPLE_BINARY_SEMAPHORE   0x00000020
#define RTEMS_NO_INHERIT_PRIORITY   0x00000000
#define RTEMS_INHERIT_PRIORITY   0x00000040
#define RTEMS_NO_PRIORITY_CEILING   0x00000000
#define RTEMS_PRIORITY_CEILING   0x00000080
#define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING   0x00000000
#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING   0x00000100
#define RTEMS_BARRIER_AUTOMATIC_RELEASE   0x00000010
#define RTEMS_BARRIER_MANUAL_RELEASE   0x00000000
#define RTEMS_APPLICATION_TASK   0x00000000
#define RTEMS_SYSTEM_TASK   0x00008000
typedef uint32_t rtems_attribute
This encapsulates functionality which defines and manages the set of Classic API object attributes.
◆ RTEMS_APPLICATION_TASK
This attribute constant indicates that the task was created by the application using normal Classic API methods.
◆ RTEMS_BARRIER_AUTOMATIC_RELEASE
This attribute constant indicates that the Classic API Barrier instance created will use an automatic release protocol.
◆ RTEMS_BARRIER_MANUAL_RELEASE
This attribute constant indicates that the Classic API Barrier instance created will use the manual release protocol.
◆ RTEMS_BINARY_SEMAPHORE
This attribute constant indicates that the Classic API Semaphore instance created will be a proper binary semaphore or mutex.
◆ RTEMS_COUNTING_SEMAPHORE
This attribute constant indicates that the Classic API Semaphore instance created will be a counting semaphore.
◆ RTEMS_DEFAULT_ATTRIBUTES
This is the default value for an attribute set.
◆ RTEMS_FIFO
This is the attribute constant which reflects that blocking tasks will be managed using FIFO discipline.
◆ RTEMS_FLOATING_POINT
This attribute constant indicates that the task will use the floating point hardware. There will be a floating point context associated with this task.
◆ RTEMS_GLOBAL
This is the attribute constant to indicate global resource.
◆ RTEMS_INHERIT_PRIORITY
This attribute constant indicates that the Classic API Semaphore instance created will use the Priority Inheritance Protocol.
Note
The semaphore instance must be a binary semaphore.
◆ RTEMS_LOCAL
This is the attribute constant to indicate local resource.
◆ RTEMS_MULTIPROCESSOR_RESOURCE_SHARING
This attribute constant indicates that the Classic API Semaphore instance created will use the Multiprocessor Resource Sharing Protocol.
Note
◆ RTEMS_NO_FLOATING_POINT
This attribute constant indicates that the task will not use the floating point hardware. If the architecture permits it, then the FPU will be disabled when the task is executing.
◆ RTEMS_NO_INHERIT_PRIORITY
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Priority Inheritance Protocol.
◆ RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Multiprocessor Resource Sharing Protocol.
◆ RTEMS_NO_PRIORITY_CEILING
This attribute constant indicates that the Classic API Semaphore instance created will NOT use the Priority Ceiling Protocol.
◆ RTEMS_PRIORITY
This is the attribute constant which reflects that blocking tasks will be managed using task priority discipline.
◆ RTEMS_PRIORITY_CEILING
This attribute constant indicates that the Classic API Semaphore instance created will use the Priority Ceiling Protocol.
Note
◆ RTEMS_SEMAPHORE_CLASS
This is the mask for the attribute bits associated with the Classic API Semaphore Manager.
◆ RTEMS_SIMPLE_BINARY_SEMAPHORE
This attribute constant indicates that the Classic API Semaphore instance created will be a simple binary semaphore.
◆ RTEMS_SYSTEM_TASK
This attribute constant indicates that the task was created by RTEMS as a support task.
Typedef Documentation
◆ rtems_attribute
This defines the type used to contain Classic API attributes. These are primarily used when creating objects.
