RTEMS
5.1
#include <tasks.h>
Data Fields | |
rtems_name | name |
size_t | stack_size |
rtems_task_priority | initial_priority |
rtems_attribute | attribute_set |
rtems_task_entry | entry_point |
rtems_mode | mode_set |
rtems_task_argument | argument |
The following records define the Initialization Tasks Table. Each entry contains the information required by RTEMS to create and start a user task automatically at executive initialization time.
rtems_task_argument rtems_initialization_tasks_table::argument |
This is the Initialization Task's argument.
rtems_attribute rtems_initialization_tasks_table::attribute_set |
This is the Initialization Task's attributes.
rtems_task_entry rtems_initialization_tasks_table::entry_point |
This is the Initialization Task's entry point.
rtems_task_priority rtems_initialization_tasks_table::initial_priority |
This is the Initialization Task's priority.
rtems_mode rtems_initialization_tasks_table::mode_set |
This is the Initialization Task's initial mode.
rtems_name rtems_initialization_tasks_table::name |
This is the Initialization Task's name.
size_t rtems_initialization_tasks_table::stack_size |
This is the Initialization Task's stack size.
