RTEMS  5.1
Files | Data Structures | Typedefs | Functions | Variables
Thread-Local Storage (TLS)
Thread-local storage (TLS) support. More...
file  tls.h
struct  TLS_Dynamic_thread_vector
struct  TLS_Thread_control_block
struct  TLS_Index
typedef struct TLS_Thread_control_block TLS_Thread_control_block
uintptr_t _TLS_Get_allocation_size (void)
 Return the TLS area allocation size. More...
char _TLS_Data_begin []
char _TLS_Data_end []
char _TLS_Data_size []
char _TLS_BSS_begin []
char _TLS_BSS_end []
char _TLS_BSS_size []
char _TLS_Size []
char _TLS_Alignment []
 The TLS section alignment. More...
Variants I and II are according to Ulrich Drepper, "ELF Handling For Thread-Local Storage".
◆ _TLS_Get_allocation_size()
uintptr_t _TLS_Get_allocation_size ( void  )
Returns
The TLS area allocation size.
Variable Documentation
◆ _TLS_Alignment
char _TLS_Alignment[]
This symbol is provided by the linker command file as the maximum alignment of the .tdata and .tbss sections. The linker ensures that the first TLS output section is aligned to the maximum alignment of all TLS output sections, see function _bfd_elf_tls_setup() in bfd/elflink.c of the GNU Binutils sources. The linker command file must take into account the case that the .tdata section is empty and the .tbss section is non-empty.
