RTEMS  5.1
Files | Data Structures | Typedefs | Functions
Freechain Handler
The Freechain Handler. More...
file  freechain.h
 Freechain Handler API.
file  freechain.c
 Freechain Handler Implementation.
struct  Freechain_Control
 The freechain control. More...
typedef void *(* Freechain_Allocator) (size_t size)
 Allocator function.
RTEMS_INLINE_ROUTINE void _Freechain_Initialize (Freechain_Control *freechain, void *initial_nodes, size_t number_nodes, size_t node_size)
 Initializes a freechain. More...
RTEMS_INLINE_ROUTINE bool _Freechain_Is_empty (const Freechain_Control *freechain)
 Return true if the freechain is empty, otherwise false. More...
RTEMS_INLINE_ROUTINE void * _Freechain_Pop (Freechain_Control *freechain)
 Pop an item from the freechain. More...
void * _Freechain_Extend (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size)
 Extend the freechain with new nodes. More...
void * _Freechain_Get (Freechain_Control *freechain, Freechain_Allocator allocator, size_t number_nodes_to_extend, size_t node_size)
 Gets a node from the freechain. More...
void _Freechain_Put (Freechain_Control *freechain, void *node)
 Puts a node back onto the freechain. More...
The Freechain Handler is used to manage a chain of nodes, of which size can automatically increase when there is no free node left. This handler provides one data structure: Freechain_Control.
◆ _Freechain_Extend()
void* _Freechain_Extend ( Freechain_Control freechain,
size_t  node_size
Parameters
freechainThe freechain control.
allocatorThe allocator function.
number_nodes_to_extendThe number of nodes to extend.
node_sizeThe node size.
Return values
NULLThe extend operation failed.
nodesPointer to the new nodes.
◆ _Freechain_Get()
void* _Freechain_Get ( Freechain_Control freechain,
size_t  node_size
Parameters
[in,out]freechainThe freechain control.
number_nodes_to_extendThe number of nodes in the case an extend is necessary due to an empty freechain.
[in]node_sizeThe node size.
Return values
NULLThe freechain is empty and the extend operation failed.
pointerPointer to a node. The node ownership passes to the caller.
◆ _Freechain_Initialize()
RTEMS_INLINE_ROUTINE void _Freechain_Initialize ( Freechain_Control freechain,
void *  initial_nodes,
size_t  node_size
This routine initializes the freechain control structure to manage a chain of nodes. In the case the freechain is empty the extend handler is called to get more nodes.
Parameters
[out]freechainThe freechain control to initialize.
[out]initial_nodesArray with the initial nodes.
number_nodesThe initial number of nodes.
◆ _Freechain_Is_empty()
RTEMS_INLINE_ROUTINE bool _Freechain_Is_empty ( const Freechain_Control freechain)
Parameters
◆ _Freechain_Pop()
RTEMS_INLINE_ROUTINE void* _Freechain_Pop ( Freechain_Control freechain)
The freechain must not be empty.
Parameters
◆ _Freechain_Put()
void _Freechain_Put ( Freechain_Control freechain,
void *  node
Parameters
[out]nodeThe node to put back. The node may be NULL, in this case the function does nothing.
