RTEMS  5.1
Files | Macros | Enumerations | Functions | Variables
System State Handler
Management of the internal system state of RTEMS. More...
file  sysstate.h
 System State Handler API.
#define SYSTEM_STATE_CODES_FIRST   SYSTEM_STATE_BEFORE_INITIALIZATION
#define SYSTEM_STATE_CODES_LAST   SYSTEM_STATE_TERMINATED
enum  System_state_Codes { SYSTEM_STATE_BEFORE_INITIALIZATION, SYSTEM_STATE_BEFORE_MULTITASKING, SYSTEM_STATE_UP, SYSTEM_STATE_TERMINATED }
 System states. More...
RTEMS_INLINE_ROUTINE void _System_state_Set (System_state_Codes state)
 Sets the current system state to the given state. More...
RTEMS_INLINE_ROUTINE System_state_Codes _System_state_Get (void)
 Gets the current system state. More...
RTEMS_INLINE_ROUTINE bool _System_state_Is_before_initialization (System_state_Codes state)
 Checks if the state is before initialization. More...
RTEMS_INLINE_ROUTINE bool _System_state_Is_before_multitasking (System_state_Codes state)
 Checks if the state is before multitasking. More...
RTEMS_INLINE_ROUTINE bool _System_state_Is_up (System_state_Codes state)
 Checks if the state is up. More...
RTEMS_INLINE_ROUTINE bool _System_state_Is_terminated (System_state_Codes state)
 Checks if the state is terminated. More...
System_state_Codes _System_state_Current
◆ System_state_Codes
System states.
The system is before the end of the first phase of initialization.
The system is between end of the first phase of initialization but before multitasking is started.
SYSTEM_STATE_UP
The system is up and operating normally.
The system reached its terminal state.
◆ _System_state_Get()
RTEMS_INLINE_ROUTINE System_state_Codes _System_state_Get ( void  )
Returns
The current system state.
◆ _System_state_Is_before_initialization()
RTEMS_INLINE_ROUTINE bool _System_state_Is_before_initialization ( System_state_Codes  state)
Parameters
stateThe state to check.
Return values
truestate is before initialization.
falsestate is not before initialization.
◆ _System_state_Is_before_multitasking()
RTEMS_INLINE_ROUTINE bool _System_state_Is_before_multitasking ( System_state_Codes  state)
Parameters
Return values
truestate is before multitasking.
falsestate is not before multitasking.
◆ _System_state_Is_terminated()
RTEMS_INLINE_ROUTINE bool _System_state_Is_terminated ( System_state_Codes  state)
Parameters
Return values
truestate is terminated.
falsestate is not terminated.
◆ _System_state_Is_up()
RTEMS_INLINE_ROUTINE bool _System_state_Is_up ( System_state_Codes  state)
Parameters
Return values
truestate is up.
falsestate is not up.
◆ _System_state_Set()
RTEMS_INLINE_ROUTINE void _System_state_Set ( System_state_Codes  state)
Parameters
stateThe state to set.
