RTEMS  5.1
Files | Macros
Context Handler
Functionality for Abstraction of Thread Context Management. More...
file  context.h
 Information About Each Thread's Context.
#define CONTEXT_FP_SIZE
 Size of floating point context area. More...
#define _Context_Initialize(_the_context, _stack, _size, _isr, _entry, _is_fp, _tls_area)
 Initialize context area. More...
#define _Context_Initialization_at_thread_begin()
#define _Context_Switch(_executing, _heir)   _CPU_Context_switch( _executing, _heir )
 Perform context switch. More...
#define _Context_Restart_self(_the_context)   _CPU_Context_Restart_self( _the_context )
 Restart currently executing thread. More...
#define _Context_Initialize_fp(_fp_area)   _CPU_Context_Initialize_fp( _fp_area )
 Initialize floating point context area. More...
#define _Context_Restore_fp(_fp)   _CPU_Context_restore_fp( _fp )
 Restore floating point context area. More...
#define _Context_Save_fp(_fp)   _CPU_Context_save_fp( _fp )
 Save floating point context area. More...
#define _Context_Destroy(_the_thread, _the_context)
This handler encapsulates functionality which abstracts thread context management in a portable manner.
The context switch needed variable is contained in the per cpu data structure.
◆ _Context_Initialization_at_thread_begin
#define _Context_Initialization_at_thread_begin ( )
This macro is invoked from _Thread_Handler to do whatever CPU specific magic is required that must be done in the context of the thread when it starts.
If the CPU architecture does not require any magic, then this macro is empty.
◆ _Context_Initialize
#define _Context_Initialize (   _the_context,
  _stack,
  _size,
  _isr,
  _entry,
  _is_fp,
  _tls_area
Value:
_CPU_Context_Initialize( _the_context, _stack, _size, _isr, _entry, \
_is_fp, _tls_area )
This routine initializes _the_context such that the stack pointer, interrupt level, and entry point are correct for the thread's initial state.
Parameters
[in]_the_contextwill be initialized
[in]_stackis the lowest physical address of the thread's context
[in]_sizeis the size in octets of the thread's context
[in]_isris the ISR enable level for this thread
[in]_entryis this thread's entry point
[in]_is_fpis set to true if this thread has floating point enabled
[in]_tls_areaThe thread-local storage (TLS) area begin.
◆ _Context_Initialize_fp
#define _Context_Initialize_fp (   _fp_area)    _CPU_Context_Initialize_fp( _fp_area )
This routine initializes the floating point context save area to contain an initial known state.
Parameters
[in]_fp_areais the base address of the floating point context save area to initialize.
◆ _Context_Restart_self
#define _Context_Restart_self (   _the_context)    _CPU_Context_Restart_self( _the_context )
This routine restarts the calling thread by restoring its initial stack pointer and returning to the thread's entry point.
Parameters
[in]_the_contextis the context of the thread to restart
◆ _Context_Restore_fp
#define _Context_Restore_fp (   _fp)    _CPU_Context_restore_fp( _fp )
This routine restores the floating point context contained in the _fp area. It is assumed that the current floating point context has been saved by a previous invocation of _Context_Save_fp.
Parameters
[in]_fppoints to the floating point context area to restore.
◆ _Context_Save_fp
#define _Context_Save_fp (   _fp)    _CPU_Context_save_fp( _fp )
This routine saves the current floating point context in the _fp area.
Parameters
◆ _Context_Switch
#define _Context_Switch (   _executing,
  _heir
This routine saves the current context into the _executing context record and restores the context specified by _heir.
Parameters
[in]_executingis the currently executing thread's context
[in]_heiris the context of the thread to be switched to
◆ CONTEXT_FP_SIZE
Value:
( ( CPU_CONTEXT_FP_SIZE + CPU_HEAP_ALIGNMENT - 1 ) \
& ~( CPU_HEAP_ALIGNMENT - 1 ) )
#define CPU_CONTEXT_FP_SIZE
Definition: cpu.h:652
This constant defines the number of bytes required to store a full floating point context.
