RTEMS  5.1
Files | Data Structures | Macros | Enumerations | Functions
Barrier Handler
Functionality for Foundation Barrier Services. More...
file  corebarrier.h
 Constants and Structures Associated with the Barrier Handler.
file  corebarrierimpl.h
 Inlined Routines Associated with the SuperCore Barrier.
file  corebarrier.c
 Initialize CORE Barrier.
file  corebarrierrelease.c
 Manually releases the Barrier.
file  corebarrierwait.c
 Wait For The Barrier.
struct  CORE_barrier_Attributes
struct  CORE_barrier_Control
#define CORE_BARRIER_TQ_OPERATIONS   &_Thread_queue_Operations_FIFO
enum  CORE_barrier_Disciplines { CORE_BARRIER_AUTOMATIC_RELEASE, CORE_BARRIER_MANUAL_RELEASE }
void _CORE_barrier_Initialize (CORE_barrier_Control *the_barrier, CORE_barrier_Attributes *the_barrier_attributes)
 Initializes the core barrier. More...
RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy (CORE_barrier_Control *the_barrier)
 Destroys the core barrier. More...
RTEMS_INLINE_ROUTINE void _CORE_barrier_Acquire_critical (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context)
 Acquires critical core barrier. More...
RTEMS_INLINE_ROUTINE void _CORE_barrier_Release (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context)
 Releases core barrier. More...
Status_Control _CORE_barrier_Seize (CORE_barrier_Control *the_barrier, Thread_Control *executing, bool wait, Thread_queue_Context *queue_context)
 Waits for the barrier. More...
uint32_t _CORE_barrier_Do_flush (CORE_barrier_Control *the_barrier, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context)
 Flushes the barrier. More...
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Surrender (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context)
 Manually releases the barrier. More...
RTEMS_INLINE_ROUTINE void _CORE_barrier_Flush (CORE_barrier_Control *the_barrier, Thread_queue_Context *queue_context)
 Flushes the barrier using _CORE_barrier_Do_flush(). More...
RTEMS_INLINE_ROUTINE bool _CORE_barrier_Is_automatic (CORE_barrier_Attributes *the_attribute)
 Checks if the barrier is automatic. More...
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Get_number_of_waiting_threads (CORE_barrier_Control *the_barrier)
 Returns the number of currently waiting threads. More...
This handler encapsulates functionality which provides the foundation Barrier services used in all of the APIs supported by RTEMS.
◆ CORE_barrier_Disciplines
Flavors of barriers.
This specifies that the barrier will automatically release when the user specified number of threads have arrived at the barrier.
This specifies that the user will have to manually release the barrier in order to release the waiting threads.
◆ _CORE_barrier_Acquire_critical()
RTEMS_INLINE_ROUTINE void _CORE_barrier_Acquire_critical ( CORE_barrier_Control the_barrier,
Thread_queue_Context queue_context
Parameters
[in,out]the_barrierThe barrier to acquire.
queue_contextThe thread queue context.
◆ _CORE_barrier_Destroy()
RTEMS_INLINE_ROUTINE void _CORE_barrier_Destroy ( CORE_barrier_Control the_barrier)
This routine destroys the barrier.
Parameters
[out]the_barrierThe barrier to destroy.
◆ _CORE_barrier_Do_flush()
uint32_t _CORE_barrier_Do_flush ( CORE_barrier_Control the_barrier,
Parameters
[in,out]the_barrierThe barrier to flush.
[out]filterThe filter for flushing.
[out]queue_contextThe thread queue context.
◆ _CORE_barrier_Flush()
RTEMS_INLINE_ROUTINE void _CORE_barrier_Flush ( CORE_barrier_Control the_barrier,
Parameters
◆ _CORE_barrier_Get_number_of_waiting_threads()
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Get_number_of_waiting_threads ( CORE_barrier_Control the_barrier)
This routine returns the number of threads currently waiting at the barrier.
Parameters
[in]the_barrierThe barrier to obtain the number of blocked threads of.
Returns
the current count of waiting threads of this barrier.
◆ _CORE_barrier_Initialize()
void _CORE_barrier_Initialize ( CORE_barrier_Control the_barrier,
CORE_barrier_Attributes the_barrier_attributes
This routine initializes the barrier based on the parameters passed.
Parameters
[out]the_barrierThe barrier to initialize.
[out]the_barrier_attributesThe attributes which define the behavior of this instance.
◆ _CORE_barrier_Is_automatic()
RTEMS_INLINE_ROUTINE bool _CORE_barrier_Is_automatic ( CORE_barrier_Attributes the_attribute)
This function returns true if the automatic release attribute is enabled in the attribute_set and false otherwise.
Parameters
the_attributeThe attribute set to test.
Return values
trueThe automatic release attribute is enabled.
falseThe automatic release attribute is not enabled.
◆ _CORE_barrier_Release()
RTEMS_INLINE_ROUTINE void _CORE_barrier_Release ( CORE_barrier_Control the_barrier,
Parameters
[in,out]the_barrierThe barrier to release.
◆ _CORE_barrier_Seize()
Status_Control _CORE_barrier_Seize ( CORE_barrier_Control the_barrier,
Thread_Control executing,
bool  wait,
This routine waits for the barrier to be released. If the barrier is set to automatic and this is the appropriate thread, then it returns immediately. Otherwise, the calling thread is blocked until the barrier is released.
Parameters
[in,out]the_barrierThe barrier to wait for.
[in,out]executingThe currently executing thread.
waitThis parameter is true if the calling thread is willing to wait.
Returns
The method status.
◆ _CORE_barrier_Surrender()
RTEMS_INLINE_ROUTINE uint32_t _CORE_barrier_Surrender ( CORE_barrier_Control the_barrier,
This routine manually releases the barrier. All of the threads waiting for the barrier will be readied.
Parameters
[in,out]the_barrierThe barrier to surrender.
Returns
The number of unblocked threads.
