RTEMS 6.1-rc4
Modules | Files | Macros | Functions
TMS570 Board Support Package. More...
 System Clocks
 System clocks.
file  clock.c
 This source file contains the Clock Driver implementation.
file  printk-support.c
 This source file contains the definition of BSP_output_char and BSP_poll_char.
file  tms570-sci.c
 This source file contains the Console Driver implementation using the Serial Communication Interface (SCI).
file  bsp.h
 This header file provides BSP-specific interfaces.
file  irq.h
 This header file provides TMS570 interrupt definitions.
file  system-clocks.h
 This header file provides a free-running timer interface.
file  errata_SSWF021_45.h
 This header file provides errata SSWF021#45 interfaces.
file  reg_adc.h
 This header file provides ADC interfaces.
file  reg_ccmsr.h
 This header file provides CCMSR interfaces.
file  reg_crc.h
 This header file provides CRC interfaces.
file  reg_dcan.h
 This header file provides DCAN interfaces.
file  reg_dcc.h
 This header file provides DCC interfaces.
file  reg_dma.h
 This header file provides DMA interfaces.
file  reg_dmm.h
 This header file provides DMM interfaces.
file  reg_efuse.h
 This header file provides EFUSE interfaces.
file  reg_emacc.h
 This header file provides EMACC interfaces.
file  reg_emacm.h
 This header file provides EMACM interfaces.
file  reg_emif.h
 This header file provides EMIF interfaces.
file  reg_esm.h
 This header file provides ESM interfaces.
file  reg_flash.h
 This header file provides flash interfaces.
file  reg_flex_ray.h
 This header file provides FlexRay interfaces.
file  reg_gio.h
 This header file provides GIO interfaces.
file  reg_htu.h
 This header file provides HTU interfaces.
file  reg_i2c.h
 This header file provides I2C interfaces.
file  reg_iomm.h
 This header file provides IOMM interfaces.
file  reg_lin.h
 This header file provides LIN interfaces.
file  reg_mdio.h
 This header file provides MDIO interfaces.
file  reg_n2het.h
 This header file provides N2HET interfaces.
file  reg_pbist.h
 This header file provides PBIST interfaces.
file  reg_pcr.h
 This header file provides PCR interfaces.
file  reg_pll.h
 This header file provides PLL interfaces.
file  reg_pmm.h
 This header file provides PMM interfaces.
file  reg_pom.h
 This header file provides POM interfaces.
file  reg_rti.h
 This header file provides RTI interfaces.
file  reg_rtp.h
 This header file provides RTP interfaces.
file  reg_sci.h
 This header file provides SCI interfaces.
file  reg_spi.h
 This header file provides SPI interfaces.
file  reg_stc.h
 This header file provides STC interfaces.
file  reg_sys.h
 This header file provides SYS interfaces.
file  reg_sys2.h
 This header file provides SYS2 interfaces.
file  reg_tcr.h
 This header file provides TCR interfaces.
file  reg_tcram.h
 This header file provides TCRAM interfaces.
file  reg_vim.h
 This header file provides VIM interfaces.
file  tms570-pinmux.h
 This header file provides interfaces of the I/O Multiplexing Module (IOMM) support.
file  tms570-pins.h
 This header file selects the pin mapping according to the selected chip.
file  tms570-pom.h
 This header file provides interfaces of the Parameter Overlay Module (POM) support.
file  tms570-sci-driver.h
 This header file provides interfaces of the SCI support.
file  tms570.h
 This header file provides TMS570 interfaces.
file  tms570_hwinit.h
 This header file provides interfaces of the hardware initialization support.
file  tms570_selftest.h
 This header file provides TMS570 selftest error codes, addresses and functions.
file  tms570_selftest_parity.h
 This header file provides interfaces of the parity selftest support.
file  tms570lc4357-pins.h
 This header file provides pin mappings for the TMS570LC4357.
file  tms570ls3137zwt-pins.h
 This header file provides pin mappings for the TMS570LS3137ZWT.
file  tm27.h
 This header file provides a TM27 support implementation.
file  irq.c
 This source file contains the interrupt controller support implementation.
file  bspreset.c
 This source file contains the bsp_reset() implementation.
file  bspstart.c
 This source file contains the bsp_start() implementation.
file  bspstarthooks-hwinit.c
 This source file contains the bsp_start_hook_0() implementation.
file  bspstarthooks.c
 This source file contains the bsp_start_hook_1(0 implementation.
file  errata_SSWF021_45.c
 This source file contains errata SSWF021#45 workaround implementation.
file  fail_notification.c
 This source file contains the default bsp_selftest_fail_notification() and tms570_memory_port0_fail_notification() implementations.
file  hwinit-lc4357-hdk.c
 This source file contains parts of the system initialization.
file  hwinit-ls3137-hdk.c
file  init_esm.c
 This source file contains the error signaling module initialization.
file  init_system.c
file  pinmux.c
 This source file contains the I/O Multiplexing Module (IOMM) support implementation.
file  tms570-pom.c
 This source file contains the Parameter Overlay Module (POM) support implementation.
file  tms570_selftest.c
 This source file contains the selftest support implementation.
file  tms570_selftest_par_can.c
 This source file contains the CAN module parity based protection support.
file  tms570_selftest_par_mibspi.c
 This source file contains the MibSPI module parity based protection support.
file  tms570_selftest_par_std.c
 This source file contains the HETx, HTUx, ADC, DMA and VIM module parity based protection support.
file  tms570_selftest_parity.c
 This source file contains parts of the parity based protection support.
file  tms570_tcram_tests.c
 This source file contains TCRAM selftest functions.
RTEMS_NO_RETURN void bsp_restart (const void *addr)
 Restarts the bsp with "addr" address.
◆ bsp_restart()
RTEMS_NO_RETURN void bsp_restart ( const void *  addr)
Parameters
addrAddress used to restart the bsp
