RTEMS 6.1-rc4
Macros | Enumerations | Functions
hwinit-ls3137-hdk.c File Reference
This source file contains parts of the system initialization. More...
#include <bsp/tms570.h>
#include <bsp/tms570_hwinit.h>
#include <bsp/tms570-pinmux.h>
#define TMS570_PINMMR_INIT_LIST(per_pin_action, common_arg)
enum  tms570_system_clock_source {
  TMS570_SYS_CLK_SRC_OSC = 0U , TMS570_SYS_CLK_SRC_PLL1 = 1U , TMS570_SYS_CLK_SRC_EXTERNAL1 = 3U , TMS570_SYS_CLK_SRC_LPO_LOW = 4U ,
  TMS570_SYS_CLK_SRC_LPO_HIGH = 5U , TMS570_SYS_CLK_SRC_PLL2 = 6U , TMS570_SYS_CLK_SRC_EXTERNAL2 = 7U , TMS570_SYS_CLK_SRC_VCLK = 9U
void tms570_pinmux_init (void)
 setups pin multiplexer according to precomputed registers values (HCG:muxInit)
void tms570_emif_sdram_init (void)
 Initialize the External Memory InterFace (EMIF) peripheral.
void tms570_pll_init (void)
 Setup all system PLLs (HCG:setupPLL)
void tms570_map_clock_init (void)
 Setup chip clocks including to wait for PLLs locks (HCG:mapClocks)
◆ tms570_system_clock_source
Alias for oscillator clock Source
Alias for Pll1 clock Source
Alias for external clock Source
Alias for low power oscillator low clock Source
Alias for low power oscillator high clock Source
Alias for Pll2 clock Source
Alias for external 2 clock Source
Alias for synchronous VCLK1 clock Source
◆ tms570_map_clock_init()
void tms570_map_clock_init ( void  )
Initialize the tms570 Global Clock Manager (GCM) registers which sub-divide the input clock source (generally PLL) into the various peripheral clocks (VCLK1-3, etc).
Initialize Clock Tree:
  • Disable / Enable clock domain
  • Wait for until clocks are locked
  • Map device clock domains to desired sources and configure top-level dividers
  • All clock domains are working off the default clock sources until now
  • The below assignments can be easily modified using the HALCoGen GUI
  • Setup GCLK, HCLK and VCLK clock source for normal operation, power down mode and after wakeup
  • Setup synchronous peripheral clock dividers for VCLK1, VCLK2, VCLK3
  • Setup RTICLK1 and RTICLK2 clocks
  • Setup asynchronous peripheral clock sources for AVCLK1 and AVCLK2
◆ tms570_pinmux_init()
void tms570_pinmux_init ( void  )
Initialize the tms570 PINMUX peripheral. This maps signals to pin terminals.
  • set ECLK pins functional mode
  • set ECLK pins default output value
  • set ECLK pins output direction
  • set ECLK pins open drain enable
  • set ECLK pins pullup/pulldown enable
  • set ECLK pins pullup/pulldown select
  • Setup ECLK
◆ tms570_pll_init()
void tms570_pll_init ( void  )
Initialize PLLs source divider/multipliers.
  • Configure PLL control registers
Initialize Pll1:
Initialize Pll2:
  • Enable PLL(s) to start up or Lock
