#define | TMS570_CRC_CTRL0_CH2_PSA_SWREST BSP_BIT32(8) |
#define | TMS570_CRC_CTRL0_CH1_PSA_SWREST BSP_BIT32(0) |
#define | TMS570_CRC_CTRL1_PWDN BSP_BIT32(0) |
#define | TMS570_CRC_CTRL2_CH2_MODE(val) BSP_FLD32(val,8, 9) |
#define | TMS570_CRC_CTRL2_CH2_MODE_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_CRC_CTRL2_CH2_MODE_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_CRC_CTRL2_CH1_TRACEEN BSP_BIT32(4) |
#define | TMS570_CRC_CTRL2_CH1_MODE(val) BSP_FLD32(val,0, 1) |
#define | TMS570_CRC_CTRL2_CH1_MODE_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_CRC_CTRL2_CH1_MODE_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_CRC_INTS_CH2_TIMEOUTENS BSP_BIT32(12) |
#define | TMS570_CRC_INTS_CH2_UNDERENS BSP_BIT32(11) |
#define | TMS570_CRC_INTS_CH2_OVERENS BSP_BIT32(10) |
#define | TMS570_CRC_INTS_CH2_CRCFAILENS BSP_BIT32(9) |
#define | TMS570_CRC_INTS_CH2_CCITENS BSP_BIT32(8) |
#define | TMS570_CRC_INTS_CH1_TIMEOUTENS BSP_BIT32(4) |
#define | TMS570_CRC_INTS_CH1_UNDERENS BSP_BIT32(3) |
#define | TMS570_CRC_INTS_CH1_OVERENS BSP_BIT32(2) |
#define | TMS570_CRC_INTS_CH1_CRCFAILENS BSP_BIT32(1) |
#define | TMS570_CRC_INTS_CH1_CCITENS BSP_BIT32(0) |
#define | TMS570_CRC_INTR_CH2_TIMEOUTENR BSP_BIT32(12) |
#define | TMS570_CRC_INTR_CH2_UNDERENR BSP_BIT32(11) |
#define | TMS570_CRC_INTR_CH2_OVERENR BSP_BIT32(10) |
#define | TMS570_CRC_INTR_CH2_CRCFAILENR BSP_BIT32(9) |
#define | TMS570_CRC_INTR_CH2_CCITENR BSP_BIT32(8) |
#define | TMS570_CRC_INTR_CH1_TIMEOUTENR BSP_BIT32(4) |
#define | TMS570_CRC_INTR_CH1_UNDERENR BSP_BIT32(3) |
#define | TMS570_CRC_INTR_CH1_OVERENR BSP_BIT32(2) |
#define | TMS570_CRC_INTR_CH1_CRCFAILENR BSP_BIT32(1) |
#define | TMS570_CRC_INTR_CH1_CCITENR BSP_BIT32(0) |
#define | TMS570_CRC_STATUS_CH2_TIMEOUT BSP_BIT32(12) |
#define | TMS570_CRC_STATUS_CH2_UNDER BSP_BIT32(11) |
#define | TMS570_CRC_STATUS_CH2_OVER BSP_BIT32(10) |
#define | TMS570_CRC_STATUS_CH2_CRCFAIL BSP_BIT32(9) |
#define | TMS570_CRC_STATUS_CH2_CCIT BSP_BIT32(8) |
#define | TMS570_CRC_STATUS_CH1_TIMEOUT BSP_BIT32(4) |
#define | TMS570_CRC_STATUS_CH1_UNDER BSP_BIT32(3) |
#define | TMS570_CRC_STATUS_CH1_OVER BSP_BIT32(2) |
#define | TMS570_CRC_STATUS_CH1_CRCFAIL BSP_BIT32(1) |
#define | TMS570_CRC_STATUS_CH1_CCIT BSP_BIT32(0) |
#define | TMS570_CRC_INT_OFFS_REG_OFSTREG(val) BSP_FLD32(val,0, 7) |
#define | TMS570_CRC_INT_OFFS_REG_OFSTREG_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_CRC_INT_OFFS_REG_OFSTREG_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_CRC_BUSY_CH2_BUSY BSP_BIT32(8) |
#define | TMS570_CRC_BUSY_CH1_BUSY BSP_BIT32(0) |
#define | TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1(val) BSP_FLD32(val,0, 19) |
#define | TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19) |
#define | TMS570_CRC_PCOUNT_REG1_CRC_PAT_COUNT1_SET(reg, val) BSP_FLD32SET(reg, val,0, 19) |
#define | TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1(val) BSP_FLD32(val,0, 15) |
#define | TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_CRC_SCOUNT_REG1_CRC_SEC_COUNT1_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_CRC_CURSEC_REG1_CRC_CURSEC1(val) BSP_FLD32(val,0, 15) |
#define | TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_CRC_CURSEC_REG1_CRC_CURSEC1_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1(val) BSP_FLD32(val,0, 23) |
#define | TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_CRC_WDTOPLD1_CRC_WDTOPLD1_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1(val) BSP_FLD32(val,0, 23) |
#define | TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_CRC_BCTOPLD1_CRC_BCTOPLD1_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2(val) BSP_FLD32(val,0, 19) |
#define | TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 19) |
#define | TMS570_CRC_PCOUNT_REG2_CRC_PAT_COUNT2_SET(reg, val) BSP_FLD32SET(reg, val,0, 19) |
#define | TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2(val) BSP_FLD32(val,0, 15) |
#define | TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_CRC_SCOUNT_REG2_CRC_SEC_COUNT2_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_CRC_CURSEC_REG2_CRC_CURSEC2(val) BSP_FLD32(val,0, 15) |
#define | TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_CRC_CURSEC_REG2_CRC_CURSEC2_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2(val) BSP_FLD32(val,0, 23) |
#define | TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_CRC_WDTOPLD2_CRC_WDTOPLD2_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2(val) BSP_FLD32(val,0, 23) |
#define | TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_GET(reg) BSP_FLD32GET(reg,0, 23) |
#define | TMS570_CRC_BCTOPLD2_CRC_BCTOPLD2_SET(reg, val) BSP_FLD32SET(reg, val,0, 23) |
#define | TMS570_CRC_BUS_SEL_MEn BSP_BIT32(2) |
#define | TMS570_CRC_BUS_SEL_DTCMEn BSP_BIT32(1) |
#define | TMS570_CRC_BUS_SEL_ITCMEn BSP_BIT32(0) |
This header file provides CRC interfaces.
