RTEMS 6.1-rc2
validation Directory Reference
Directories
directory  bsps
file  tc-acfg-appl-does-not-need-clock-driver.c
file  tc-acfg-appl-needs-clock-driver.c
file  tc-acfg-default.c
file  tc-acfg-disabled-bsp-settings.c
file  tc-acfg-one-cpu.c
file  tc-acfg-scheduler-edf-smp.c
file  tc-acfg-scheduler-table-entries-one-cpu.c
file  tc-acfg.c
file  tc-attr.c
file  tc-barrier-create.c
file  tc-barrier-delete.c
file  tc-barrier-ident.c
file  tc-barrier-performance.c
file  tc-barrier-release.c
file  tc-barrier-wait.c
file  tc-basedefs-no-debug.c
file  tc-basedefs-pendant.c
 Helper file to verify the requirements towards the basedefs.
file  tc-basedefs-pendant.h [code]
file  tc-basedefs.c
file  tc-bsp-interrupt-handler-dispatch-unchecked.c
file  tc-c.c
file  tc-cache.c
file  tc-clock-get-tod.c
file  tc-clock-get-uptime.c
file  tc-clock-nanosleep.c
file  tc-clock-set.c
file  tc-clock.c
file  tc-cpu-performance.c
file  tc-cpuuse.c
file  tc-dev-grlib-apbuart-inbyte-nonblocking.c
file  tc-dev-grlib-io.c
file  tc-dev-grlib-irqamp-get-timestamp.c
file  tc-event-performance.c
file  tc-event-send-receive.c
file  tc-events.c
file  tc-flsl.c
file  tc-futex-wait.c
file  tc-futex-wake.c
file  tc-intr-clear.c
file  tc-intr-entry-install.c
file  tc-intr-entry-remove.c
file  tc-intr-get-affinity.c
file  tc-intr-get-attributes.c
file  tc-intr-handler-iterate.c
file  tc-intr-is-pending.c
file  tc-intr-non-smp.c
file  tc-intr-raise-on.c
file  tc-intr-raise.c
file  tc-intr-set-affinity.c
file  tc-intr-smp-only.c
file  tc-intr-vector-disable.c
file  tc-intr-vector-enable.c
file  tc-intr-vector-is-enabled.c
file  tc-intr.c
file  tc-io-getchark.c
file  tc-io-put-char.c
file  tc-io-putc.c
file  tc-message-broadcast.c
file  tc-message-construct.c
file  tc-message-delete.c
file  tc-message-flush-pending.c
file  tc-message-ident.c
file  tc-message-macros.c
file  tc-message-performance.c
file  tc-message-receive.c
file  tc-message-urgent-send.c
file  tc-modes.c
file  tc-object.c
file  tc-options.c
file  tc-part-create.c
file  tc-part-delete.c
file  tc-part-get.c
file  tc-part-ident.c
file  tc-part-performance.c
file  tc-part-return.c
file  tc-part.c
file  tc-preinit-array.c
file  tc-ratemon-cancel.c
file  tc-ratemon-create.c
file  tc-ratemon-delete.c
file  tc-ratemon-get-status.c
file  tc-ratemon-ident.c
file  tc-ratemon-period.c
file  tc-ratemon-timeout.c
file  tc-sched-smp-edf-set-affinity.c
file  tc-sched-smp-edf.c
file  tc-sched-smp.c
file  tc-sched-yield.c
file  tc-scheduler-add-processor.c
file  tc-scheduler-get-maximum-priority.c
file  tc-scheduler-get-processor-set.c
file  tc-scheduler-ident-by-processor-set.c
file  tc-scheduler-ident-by-processor.c
file  tc-scheduler-ident.c
file  tc-scheduler-non-smp.c
file  tc-scheduler-remove-processor.c
file  tc-scheduler-smp-only.c
file  tc-scheduler.c
file  tc-score-fatal.c
file  tc-score-isr.c
file  tc-score-smp-per-cpu-jobs.c
file  tc-score-smp-thread.c
file  tc-score-thread-smp-one-cpu.c
file  tc-score-thread-tls-max-zero.c
file  tc-score-thread-tls.c
file  tc-score-thread.c
file  tc-score-tq-smp.c
file  tc-score-tq.c
file  tc-sem-create.c
file  tc-sem-delete.c
file  tc-sem-flush.c
file  tc-sem-ident.c
file  tc-sem-mrsp-obtain.c
file  tc-sem-obtain.c
file  tc-sem-performance.c
file  tc-sem-release.c
file  tc-sem-set-priority.c
file  tc-sem-smp.c
file  tc-sem-timeout.c
file  tc-sem-uni.c
file  tc-signal-catch.c
file  tc-signal-send.c
file  tc-signals.c
file  tc-start-of-optional-processor-failed.c
file  tc-status-is-equal.c
file  tc-status-is-successful.c
file  tc-status-text.c
file  tc-status.c
file  tc-support-is-name-valid.c
file  tc-support.c
file  tc-sys-lock.c
file  tc-task-construct.c
file  tc-task-create-errors.c
file  tc-task-delete.c
file  tc-task-exit.c
file  tc-task-get-affinity.c
file  tc-task-get-priority.c
file  tc-task-get-scheduler.c
file  tc-task-ident.c
file  tc-task-is-suspended.c
file  tc-task-mode.c
file  tc-task-performance.c
file  tc-task-restart.c
file  tc-task-resume.c
file  tc-task-set-affinity.c
file  tc-task-set-priority.c
file  tc-task-set-scheduler.c
file  tc-task-smp.c
file  tc-task-start.c
file  tc-task-storage-size.c
file  tc-task-suspend.c
file  tc-task-wake-after.c
file  tc-task-wake-when.c
file  tc-task.c
file  tc-terminate.c
file  tc-thread-idle-body-no-return.c
file  tc-timecounter-get-smp.c
file  tc-timecounter-get.c
file  tc-timecounter-install.c
file  tc-timer-cancel.c
file  tc-timer-create.c
file  tc-timer-delete.c
file  tc-timer-fire-after.c
file  tc-timer-fire-when.c
file  tc-timer-ident.c
file  tc-timer-initiate-server.c
file  tc-timer-reset.c
file  tc-timer-server-fire-after.c
file  tc-timer-server-fire-when.c
file  tc-timer.c
file  tc-type.c
file  tc-userext-create.c
file  tc-userext-delete.c
file  tc-userext-ident.c
file  tc-userext.c
file  tc-userext.h [code]
 This header file provides functions used by corresponding test suite.
file  tr-event-constant.c
file  tr-event-constant.h [code]
file  tr-event-send-receive.c
file  tr-event-send-receive.h [code]
file  tr-fatal-boot-processor-not-assigned-to-scheduler.c
file  tr-fatal-boot-processor-not-assigned-to-scheduler.h [code]
file  tr-fatal-idle-thread-create-failed.c
file  tr-fatal-idle-thread-create-failed.h [code]
file  tr-fatal-idle-thread-stack-too-small.c
file  tr-fatal-idle-thread-stack-too-small.h [code]
file  tr-fatal-init-task-construct-failed.c
file  tr-fatal-init-task-construct-failed.h [code]
file  tr-fatal-mandatory-processor-not-present.c
file  tr-fatal-mandatory-processor-not-present.h [code]
file  tr-fatal-scheduler-requires-exactly-one-processor.c
file  tr-fatal-scheduler-requires-exactly-one-processor.h [code]
file  tr-fatal-smp.c
file  tr-fatal-smp.h [code]
file  tr-fatal-start-of-mandatory-processor-failed.c
file  tr-fatal-start-of-mandatory-processor-failed.h [code]
file  tr-fatal-start-on-not-online-processor.c
file  tr-fatal-start-on-not-online-processor.h [code]
file  tr-fatal-too-large-tls-size.c
file  tr-fatal-too-large-tls-size.h [code]
file  tr-io-kernel.c
file  tr-io-kernel.h [code]
file  tr-mtx-seize-try.c
file  tr-mtx-seize-try.h [code]
file  tr-mtx-seize-wait.c
file  tr-mtx-seize-wait.h [code]
file  tr-mtx-surrender.c
file  tr-mtx-surrender.h [code]
file  tr-object-ident-local.c
file  tr-object-ident-local.h [code]
file  tr-object-ident.c
file  tr-object-ident.h [code]
file  tr-sem-seize-try.c
file  tr-sem-seize-try.h [code]
file  tr-sem-seize-wait.c
file  tr-sem-seize-wait.h [code]
file  tr-sem-surrender.c
file  tr-sem-surrender.h [code]
file  tr-signal-constant.c
file  tr-signal-constant.h [code]
file  tr-tq-enqueue-ceiling.c
file  tr-tq-enqueue-ceiling.h [code]
file  tr-tq-enqueue-deadlock.c
file  tr-tq-enqueue-deadlock.h [code]
file  tr-tq-enqueue-fifo.c
file  tr-tq-enqueue-fifo.h [code]
file  tr-tq-enqueue-mrsp.c
file  tr-tq-enqueue-mrsp.h [code]
file  tr-tq-enqueue-priority-inherit.c
file  tr-tq-enqueue-priority-inherit.h [code]
file  tr-tq-enqueue-priority.c
file  tr-tq-enqueue-priority.h [code]
file  tr-tq-flush-fifo.c
file  tr-tq-flush-fifo.h [code]
file  tr-tq-flush-priority-inherit.c
file  tr-tq-flush-priority-inherit.h [code]
file  tr-tq-flush-priority.c
file  tr-tq-flush-priority.h [code]
file  tr-tq-surrender-mrsp.c
file  tr-tq-surrender-mrsp.h [code]
file  tr-tq-surrender-priority-inherit.c
file  tr-tq-surrender-priority-inherit.h [code]
file  tr-tq-surrender.c
file  tr-tq-surrender.h [code]
file  tr-tq-timeout-mrsp.c
file  tr-tq-timeout-mrsp.h [code]
file  tr-tq-timeout-priority-inherit.c
file  tr-tq-timeout-priority-inherit.h [code]
file  tr-tq-timeout.c
file  tr-tq-timeout.h [code]
file  ts-acfg.h [code]
 This header file provides a validation test suite runner for validation test cases specific to the application configuration.
file  ts-config.h [code]
 This header file provides the constants used by the test suite configuration.
file  ts-default.h [code]
 This header file provides the default validation test suite runner and application configuration.
file  ts-fatal-boot-processor-not-assigned-to-scheduler.c
file  ts-fatal-idle-thread-create-failed.c
file  ts-fatal-idle-thread-stack-too-small.c
file  ts-fatal-init-task-construct-failed.c
file  ts-fatal-mandatory-processor-not-present.c
file  ts-fatal-scheduler-requires-exactly-one-processor.c
file  ts-fatal-smp.c
file  ts-fatal-start-of-mandatory-processor-failed.c
file  ts-fatal-start-on-not-online-processor.c
file  ts-fatal-sysinit.h [code]
 This header file provides a configurable validation test suite runner and application configuration for fatal error tests which occur during system initialization.
file  ts-fatal-too-large-tls-size.c
file  ts-idle.h [code]
 This header file provides a configurable validation test suite runner and application configuration for tests which should run within an idle task without a user initialization task.
file  ts-performance-no-clock-0.c
file  ts-terminate.c
file  ts-userext.c
file  ts-validation-0.c
file  ts-validation-1.c
file  ts-validation-acfg-0.c
file  ts-validation-acfg-1.c
file  ts-validation-cache.c
file  ts-validation-intr.c
file  ts-validation-io-kernel.c
file  ts-validation-no-clock-0.c
file  ts-validation-non-smp.c
file  ts-validation-one-cpu-0.c
file  ts-validation-one-cpu-1.c
file  ts-validation-smp-one-cpu-0.c
file  ts-validation-smp-only-0.c
file  ts-validation-smp-only-2.c
file  ts-validation-timecounter-0.c
file  ts-validation-timecounter-1.c
file  ts-validation-timecounter-smp-0.c
file  ts-validation-tls-0.c
file  ts-validation-tls-1.c
file  tx-call-within-isr.c
 This source file contains the implementation of CallWithinISRClear(), CallWithinISRGetVector(), CallWithinISR(), CallWithinISRRaise(), CallWithinISRSubmit(), and CallWithinISRWait().
file  tx-default-task-config.c
 This source file contains the definition of DefaultTaskConfig.
file  tx-interrupt.c
 This source file contains the implementation of HasInterruptVectorEntriesInstalled().
file  tx-io-relax.c
 This source file contains the implementation of SetIORelaxHandler().
file  tx-memory-alloc.c
 This source file contains the implementation of MemoryAllocationFailWhen() and __wrap_rtems_malloc().
file  tx-preemption-intervention.c
 This source file contains the implementation of SetPreemptionIntervention().
file  tx-support.c
 This source file contains the implementation of support functions for the validation test cases.
file  tx-support.h [code]
 This header file provides the support functions for the validation test cases.
file  tx-thread-queue.c
 This source file contains the implementation of the thread queue test support.
file  tx-thread-queue.h [code]
 This header file provides the functions to test the Thread Queue Handler.
file  tx-timecounter.c
 This source file contains the definition of SetGetTimecountHandler(), GetTimecountCounter(), and SetTimecountCounter().
file  tx-timer-server.c
 This source file contains the definition of DeleteTimerServer().
file  tx-wrap-thread-queue.c
 This source file contains the implementation of the thread queue wrapper.
