RTEMS 6.1-rc2
Macros | Functions
ts-idle.h File Reference
This header file provides a configurable validation test suite runner and application configuration for tests which should run within an idle task without a user initialization task. More...
#include <rtems/bspIo.h>
#include <rtems/test-info.h>
#include <rtems/testopts.h>
#include <rtems/test.h>
#include "tx-support.h"
#include <rtems/confdefs.h>
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS   0
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
#define CONFIGURE_INITIAL_EXTENSIONS    { .fatal = FatalInitialExtension }
#define CONFIGURE_IDLE_TASK_STORAGE_SIZE   RTEMS_MINIMUM_STACK_SIZE
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
#define CONFIGURE_IDLE_TASK_BODY   IdleBody
void * IdleBody (uintptr_t ignored)
