RTEMS 6.1-rc2
Enumerations | Functions
enum  RtemsReqIdent_Pre_Name { RtemsReqIdent_Pre_Name_Invalid , RtemsReqIdent_Pre_Name_Valid , RtemsReqIdent_Pre_Name_NA }
enum  RtemsReqIdent_Pre_Node {
  RtemsReqIdent_Pre_Node_Local , RtemsReqIdent_Pre_Node_Remote , RtemsReqIdent_Pre_Node_Invalid , RtemsReqIdent_Pre_Node_SearchAll ,
  RtemsReqIdent_Pre_Node_SearchOther , RtemsReqIdent_Pre_Node_SearchLocal , RtemsReqIdent_Pre_Node_NA
enum  RtemsReqIdent_Pre_Id { RtemsReqIdent_Pre_Id_Valid , RtemsReqIdent_Pre_Id_Null , RtemsReqIdent_Pre_Id_NA }
enum  RtemsReqIdent_Post_Status {
  RtemsReqIdent_Post_Status_Ok , RtemsReqIdent_Post_Status_InvAddr , RtemsReqIdent_Post_Status_InvName , RtemsReqIdent_Post_Status_InvNode ,
  RtemsReqIdent_Post_Status_NA
enum  RtemsReqIdent_Post_Id {
  RtemsReqIdent_Post_Id_Nop , RtemsReqIdent_Post_Id_Null , RtemsReqIdent_Post_Id_LocalObj , RtemsReqIdent_Post_Id_RemoteObj ,
  RtemsReqIdent_Post_Id_NA
void RtemsReqIdent_Run (rtems_id id_local_object, rtems_name name_local_object, rtems_status_code(*action)(rtems_name, uint32_t, rtems_id *))
 Runs the parameterized test case.
