RTEMS 6.1-rc2
Data Structures | Enumerations | Functions
#include <rtems/rtems/timerimpl.h>
#include "tx-support.h"
#include <rtems/test.h>
struct  RtemsTimerReqInitiateServer_Entry
struct  RtemsTimerReqInitiateServer_Context
 Test context for spec:/rtems/timer/req/initiate-server test case. More...
enum  RtemsTimerReqInitiateServer_Pre_Priority { RtemsTimerReqInitiateServer_Pre_Priority_Valid , RtemsTimerReqInitiateServer_Pre_Priority_Default , RtemsTimerReqInitiateServer_Pre_Priority_Invalid , RtemsTimerReqInitiateServer_Pre_Priority_NA }
enum  RtemsTimerReqInitiateServer_Pre_Stack { RtemsTimerReqInitiateServer_Pre_Stack_Allocatable , RtemsTimerReqInitiateServer_Pre_Stack_TooLarge , RtemsTimerReqInitiateServer_Pre_Stack_NA }
enum  RtemsTimerReqInitiateServer_Pre_Started { RtemsTimerReqInitiateServer_Pre_Started_Yes , RtemsTimerReqInitiateServer_Pre_Started_No , RtemsTimerReqInitiateServer_Pre_Started_NA }
enum  RtemsTimerReqInitiateServer_Pre_TaskObj { RtemsTimerReqInitiateServer_Pre_TaskObj_Available , RtemsTimerReqInitiateServer_Pre_TaskObj_Unavailable , RtemsTimerReqInitiateServer_Pre_TaskObj_NA }
enum  RtemsTimerReqInitiateServer_Post_Status {
  RtemsTimerReqInitiateServer_Post_Status_Ok , RtemsTimerReqInitiateServer_Post_Status_IncStat , RtemsTimerReqInitiateServer_Post_Status_InvPrio , RtemsTimerReqInitiateServer_Post_Status_TooMany ,
  RtemsTimerReqInitiateServer_Post_Status_Unsat , RtemsTimerReqInitiateServer_Post_Status_NA
enum  RtemsTimerReqInitiateServer_Post_Started { RtemsTimerReqInitiateServer_Post_Started_Yes , RtemsTimerReqInitiateServer_Post_Started_No , RtemsTimerReqInitiateServer_Post_Started_NA }
enum  RtemsTimerReqInitiateServer_Post_TaskPrio { RtemsTimerReqInitiateServer_Post_TaskPrio_Set , RtemsTimerReqInitiateServer_Post_TaskPrio_Nop , RtemsTimerReqInitiateServer_Post_TaskPrio_NA }
enum  RtemsTimerReqInitiateServer_Post_TaskStack { RtemsTimerReqInitiateServer_Post_TaskStack_Set , RtemsTimerReqInitiateServer_Post_TaskStack_Nop , RtemsTimerReqInitiateServer_Post_TaskStack_NA }
enum  RtemsTimerReqInitiateServer_Post_TaskAttr { RtemsTimerReqInitiateServer_Post_TaskAttr_Set , RtemsTimerReqInitiateServer_Post_TaskAttr_Nop , RtemsTimerReqInitiateServer_Post_TaskAttr_NA }
 T_TEST_CASE_FIXTURE (RtemsTimerReqInitiateServer, &RtemsTimerReqInitiateServer_Fixture)
