RTEMS 6.1-rc2
tr-tq-surrender.h
2
9/*
10 * Copyright (C) 2021 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/*
35 * This file is part of the RTEMS quality process and was automatically
36 * generated. If you find something that needs to be fixed or
37 * worded better please post a report or patch to an RTEMS mailing list
38 * or raise a bug report:
39 *
40 * https://www.rtems.org/bugs.html
41 *
42 * For information on updating and regenerating please refer to the How-To
43 * section in the Software Requirements Engineering chapter of the
44 * RTEMS Software Engineering manual. The manual is provided as a part of
45 * a release. For development sources please refer to the online
46 * documentation at:
47 *
48 * https://docs.rtems.org
49 */
50
51#ifndef _TR_TQ_SURRENDER_H
52#define _TR_TQ_SURRENDER_H
53
54#include "tx-thread-queue.h"
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
66typedef enum {
67 ScoreTqReqSurrender_Pre_HasOwner_Yes,
68 ScoreTqReqSurrender_Pre_HasOwner_No,
69 ScoreTqReqSurrender_Pre_HasOwner_NA
70} ScoreTqReqSurrender_Pre_HasOwner;
71
72typedef enum {
73 ScoreTqReqSurrender_Pre_Discipline_FIFO,
74 ScoreTqReqSurrender_Pre_Discipline_Priority,
75 ScoreTqReqSurrender_Pre_Discipline_NA
76} ScoreTqReqSurrender_Pre_Discipline;
77
78typedef enum {
79 ScoreTqReqSurrender_Pre_WaitState_Blocked,
80 ScoreTqReqSurrender_Pre_WaitState_IntendToBlock,
81 ScoreTqReqSurrender_Pre_WaitState_NA
82} ScoreTqReqSurrender_Pre_WaitState;
83
84typedef enum {
85 ScoreTqReqSurrender_Post_Dequeue_FIFO,
86 ScoreTqReqSurrender_Post_Dequeue_Priority,
87 ScoreTqReqSurrender_Post_Dequeue_NA
88} ScoreTqReqSurrender_Post_Dequeue;
89
90typedef enum {
91 ScoreTqReqSurrender_Post_Unblock_Yes,
92 ScoreTqReqSurrender_Post_Unblock_No,
93 ScoreTqReqSurrender_Post_Unblock_NA
94} ScoreTqReqSurrender_Post_Unblock;
95
101void ScoreTqReqSurrender_Run( TQContext *tq_ctx );
102
105#ifdef __cplusplus
106}
107#endif
108
109#endif /* _TR_TQ_SURRENDER_H */
void ScoreTqReqSurrender_Run(TQContext *tq_ctx)
Runs the parameterized test case.
Definition: tr-tq-surrender.c:645
Definition: tx-thread-queue.h:148
This header file provides the functions to test the Thread Queue Handler.
