RTEMS 6.1-rc2
Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Thread Queue Handler
This group contains the Thread Queue Handler implementation. More...
file  threadq.h
 This header file provides interfaces of the Thread Queue Handler which are used by the implementation and the Application Configuration.
file  threadqimpl.h
 This header file provides interfaces of the Thread Queue Handler which are only used by the implementation.
file  threadqops.h
 This header file provides interfaces related to thread queue operations.
file  threadq.c
 This source file contains static assertions related to the Thread Queue Handler, the definition of _Thread_queue_Object_name, and the implementation of _Thread_queue_Acquire(), _Thread_queue_Do_acquire_critical(), _Thread_queue_Initialize(), _Thread_queue_MP_callout_do_nothing(), _Thread_queue_Object_initialize(), _Thread_queue_Queue_get_name_and_id(), _Thread_queue_Release(), and _Thread_queue_Release_critical().
file  threadqenqueue.c
 This source file contains the implementation of _Thread_queue_Deadlock_fatal(), _Thread_queue_Deadlock_status(), _Thread_queue_Do_dequeue(), _Thread_queue_Enqueue(), _Thread_queue_Enqueue_do_nothing_extra(), _Thread_queue_Enqueue_sticky(), _Thread_queue_Extract_locked(), _Thread_queue_Path_acquire(), _Thread_queue_Path_release(), _Thread_queue_Resume(),_Thread_queue_Surrender(), _Thread_queue_Surrender_no_priority(), _Thread_queue_Surrender_sticky().
file  threadqextract.c
 This source file contains the implementation of _Thread_queue_Extract().
file  threadqextractwithproxy.c
 This source file contains the implementation of _Thread_MP_Extract_proxy().
file  threadqfirst.c
 This source file contains the implementation of _Thread_queue_First().
file  threadqflush.c
 This source file contains the implementation of _Thread_queue_Flush_default_filter(), _Thread_queue_Flush_status_object_was_deleted(), _Thread_queue_Flush_status_unavailable(), and _Thread_queue_Flush_critical().
file  threadqgetnameandid.c
 This source file contains the implementation of _Thread_queue_Queue_get_name_and_id().
file  threadqops.c
 This source file contains the definition of _Thread_queue_Operations_default, _Thread_queue_Operations_FIFO, _Thread_queue_Operations_priority, and _Thread_queue_Operations_priority_inherit.
file  threadqtimeout.c
 This source file contains the implementation of _Thread_queue_Add_timeout_ticks(), _Thread_queue_Add_timeout_timespec(), _Thread_queue_Add_timeout_monotonic_timespec(), and _Thread_queue_Add_timeout_realtime_timespec().
struct  Thread_queue_Lock_context
struct  Thread_queue_Context
 Thread queue context for the thread queue methods. More...
struct  Thread_queue_Priority_queue
 Thread priority queue. More...
struct  _Thread_queue_Heads
 Thread queue heads. More...
struct  Thread_queue_Queue
struct  Thread_queue_Operations
 The thread queue operations are used to manage the threads of a thread queue. More...
struct  Thread_queue_Control
struct  Thread_queue_Syslock_queue
 Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock.h>. More...
struct  Thread_queue_Object
 Helper structure to ensure that all objects containing a thread queue have the right layout. More...
#define THREAD_QUEUE_LINK_OF_PATH_NODE(node)    RTEMS_CONTAINER_OF( node, Thread_queue_Link, Path_node );
#define _Thread_queue_Context_ISR_disable(queue_context, level)
#define _Thread_queue_Context_set_MP_callout(queue_context, mp_callout)
 Sets the MP callout in the thread queue context.
#define _Thread_queue_Queue_acquire_critical(queue, lock_stats, lock_context)    _Thread_queue_Queue_do_acquire_critical( queue, lock_context )
#define THREAD_QUEUE_INITIALIZER(_name)
#define THREAD_QUEUE_OBJECT_ASSERT(object_type, wait_queue_member, msg)
#define THREAD_QUEUE_QUEUE_TO_OBJECT(queue)
typedef struct _Thread_Control Thread_Control
typedef struct Thread_queue_Context Thread_queue_Context
typedef struct Thread_queue_Queue Thread_queue_Queue
typedef struct Thread_queue_Operations Thread_queue_Operations
typedef void(* Thread_queue_Enqueue_callout) (Thread_queue_Queue *queue, Thread_Control *the_thread, struct Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Thread queue enqueue callout.
typedef void(* Thread_queue_Deadlock_callout) (Thread_Control *the_thread)
 Thread queue deadlock callout.
typedef struct _Thread_queue_Heads Thread_queue_Heads
 Thread queue heads.
typedef void(* Thread_queue_Priority_actions_operation) (Thread_queue_Queue *queue, Priority_Actions *priority_actions)
 Thread queue action operation.
typedef void(* Thread_queue_Enqueue_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Thread queue enqueue operation.
typedef void(* Thread_queue_Extract_operation) (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Thread queue extract operation.
typedef Thread_Control *(* Thread_queue_Surrender_operation) (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context)
 Thread queue surrender operation.
typedef Thread_Control *(* Thread_queue_First_operation) (const Thread_queue_Heads *heads)
 Gets the first thread on the queue.
typedef Thread_Control *(* Thread_queue_Flush_filter) (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Thread queue flush filter function.
enum  Thread_queue_Deadlock_status { THREAD_QUEUE_NO_DEADLOCK , THREAD_QUEUE_DEADLOCK_DETECTED }
 This is a status code to indicate if a deadlock was detected or not. More...
void _Thread_queue_Enqueue_do_nothing_extra (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Does nothing.
void _Thread_queue_Add_timeout_ticks (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds timeout ticks of the queue to the thread.
void _Thread_queue_Add_timeout_monotonic_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds a monotonic timespec to the thread and sets the watchdog header to monotonic.
void _Thread_queue_Add_timeout_realtime_timespec (Thread_queue_Queue *queue, Thread_Control *the_thread, Per_CPU_Control *cpu_self, Thread_queue_Context *queue_context)
 Adds a monotonic timespec to the thread and sets the watchdog header to realtime.
void _Thread_queue_Deadlock_status (Thread_Control *the_thread)
 Sets the thread wait return code to STATUS_DEADLOCK.
void _Thread_queue_Deadlock_fatal (Thread_Control *the_thread)
 Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
size_t _Thread_queue_Queue_get_name_and_id (const Thread_queue_Queue *queue, char *buffer, size_t buffer_size, Objects_Id *id)
 Copies the thread queue name to the specified buffer.
void _Thread_queue_Enqueue (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Blocks the thread and places it on the thread queue.
bool _Thread_queue_Extract_locked (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Extracts the thread from the thread queue, restores the default wait operations and restores the default thread lock.
void _Thread_queue_Resume (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Resumes the extracted or surrendered thread.
void _Thread_queue_Extract (Thread_Control *the_thread)
 Extracts thread from thread queue.
void _Thread_queue_Surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
 Surrenders the thread queue previously owned by the thread to the first enqueued thread.
void _Thread_queue_Surrender_no_priority (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Status_Control _Thread_queue_Surrender_priority_ceiling (Thread_queue_Queue *queue, Thread_Control *executing, Priority_Node *ceiling_priority, Thread_queue_Context *queue_context, const Thread_queue_Operations *operations)
Thread_Control_Thread_queue_First (Thread_queue_Control *the_thread_queue, const Thread_queue_Operations *operations)
 Returns the first thread on the thread queue if it exists, otherwise NULL.
Thread_Control_Thread_queue_Flush_default_filter (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Default thread queue flush filter function.
Thread_Control_Thread_queue_Flush_status_unavailable (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Status unavailable thread queue flush filter function.
Thread_Control_Thread_queue_Flush_status_object_was_deleted (Thread_Control *the_thread, Thread_queue_Queue *queue, Thread_queue_Context *queue_context)
 Status object was deleted thread queue flush filter function.
size_t _Thread_queue_Flush_critical (Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_queue_Flush_filter filter, Thread_queue_Context *queue_context)
 Unblocks all threads enqueued on the thread queue.
void _Thread_queue_Initialize (Thread_queue_Control *the_thread_queue, const char *name)
 Initializes the thread queue control to the given name.
void _Thread_queue_Object_initialize (Thread_queue_Control *the_thread_queue)
 Initializes a thread queue embedded in an object with identifier.
void _Thread_queue_Do_nothing_priority_actions (Thread_queue_Queue *queue, Priority_Actions *priority_actions)
 Initializes the priority actions so that no actions are performed.
void _Thread_queue_FIFO_enqueue (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Enqueues the thread to the FIFO thread queue.
void _Thread_queue_FIFO_extract (Thread_queue_Queue *queue, Thread_Control *the_thread, Thread_queue_Context *queue_context)
 Extracts the thread from the FIFO thread queue.
Thread_Control_Thread_queue_FIFO_surrender (Thread_queue_Queue *queue, Thread_queue_Heads *heads, Thread_Control *previous_owner, Thread_queue_Context *queue_context)
 Surrenders the thread queue to the first thread on the FIFO thread queue.
Thread_Control_Thread_queue_FIFO_first (const Thread_queue_Heads *heads)
 Gets the first thread on the FIFO thread queue.
const Thread_queue_Operations _Thread_queue_Operations_default
 The default thread queue operations are used when a thread is not enqueued on a thread queue.
const Thread_queue_Operations _Thread_queue_Operations_FIFO
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide FIFO ordering of enqueued threads.
const Thread_queue_Operations _Thread_queue_Operations_priority
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads.
const Thread_queue_Operations _Thread_queue_Operations_priority_inherit
 The FIFO thread queue operations are used when a thread is enqueued on a thread queue and provide priority ordering of enqueued threads with support for priority inheritance.
const char _Thread_queue_Object_name []
 The special thread queue name to indicated that the thread queue is embedded in an object with identifier.
This handler provides the capability to have threads block in ordered sets. The sets may be ordered using the FIFO or priority discipline.
◆ _Thread_queue_Context_ISR_disable
#define _Thread_queue_Context_ISR_disable (   queue_context,
  level
Value:
do { \
_ISR_Local_disable( level ); \
_ISR_lock_ISR_disable_profile( \
&( queue_context )->Lock_context.Lock_context \
} while ( 0 )
◆ _Thread_queue_Context_set_MP_callout
#define _Thread_queue_Context_set_MP_callout (   queue_context,
  mp_callout
Value:
do { \
(void) queue_context; \
} while ( 0 )
Parameters
[out]queue_contextThe thread queue context.
mp_calloutCallout to unblock the thread in case it is actually a thread proxy. This parameter is only used on multiprocessing configurations. Used by thread queue extract and unblock methods for objects with multiprocessing (MP) support.
◆ THREAD_QUEUE_INITIALIZER
#define THREAD_QUEUE_INITIALIZER (   _name)
Value:
.Queue = { \
.heads = NULL, \
.owner = NULL, \
.name = _name \
#define NULL
Requests a GPIO pin group configuration.
Definition: xil_types.h:54
◆ THREAD_QUEUE_OBJECT_ASSERT
#define THREAD_QUEUE_OBJECT_ASSERT (   object_type,
  wait_queue_member,
  msg
Value:
offsetof( object_type, wait_queue_member ) \
== offsetof( Thread_queue_Object, Wait_queue ) \
object_type, \
wait_queue_member, \
Wait_queue \
msg \
#define RTEMS_STATIC_ASSERT(_cond, _msg)
It is defined if a static analysis run is performed.
Definition: basedefs.h:841
#define RTEMS_HAVE_MEMBER_SAME_TYPE(_t_lhs, _m_lhs, _t_rhs, _m_rhs)
Checks if members of two types have compatible types.
Definition: basedefs.h:620
Definition: threadqimpl.h:1408
Definition: b1553brm.c:94
◆ THREAD_QUEUE_QUEUE_TO_OBJECT
#define THREAD_QUEUE_QUEUE_TO_OBJECT (   queue)
Value:
queue, \
Wait_queue.Queue \
#define RTEMS_CONTAINER_OF(_m, _type, _member_name)
Gets the container of a member.
Definition: basedefs.h:306
Typedef Documentation
◆ Thread_queue_Deadlock_callout
Parameters
the_threadThe thread that detected the deadlock.
See also
_Thread_queue_Context_set_deadlock_callout().
◆ Thread_queue_Enqueue_callout
Parameters
[in]queueThe actual thread queue.
[in]the_threadThe thread to enqueue.
[in]cpu_selfThe current processor.
[in]queue_contextThe thread queue context of the lock acquire.
See also
_Thread_queue_Context_set_enqueue_callout().
◆ Thread_queue_Enqueue_operation
A potential thread to update the priority due to priority inheritance is returned via the thread queue context. This thread is handed over to _Thread_Priority_update().
Parameters
[in]the_threadThe thread to enqueue on the queue.
◆ Thread_queue_Extract_operation
Parameters
[in]the_threadThe thread to extract from the thread queue.
◆ Thread_queue_First_operation
Parameters
headsare heads of the thread queue.
Return values
NULLNo thread is enqueued on the thread queue.
Returns
Returns the first thread on the thread queue according to the queue order. This thread remains on the thread queue.
◆ Thread_queue_Flush_filter
Called under protection of the thread queue lock by _Thread_queue_Flush_critical() to optionally alter the thread wait information and control the iteration.
Parameters
the_threadThe thread to extract. This is the first parameter to optimize for architectures that use the same register for the first parameter and the return value.
queue_contextThe thread queue context of the lock acquire. May be used to pass additional data to the filter function via an overlay structure. The filter function should not release or acquire the thread queue lock.
Return values
the_threadExtract this thread.
NULLDo not extract this thread and stop the thread queue flush operation. Threads that are already extracted will complete the flush operation.
◆ Thread_queue_Heads
Thread queue heads.
Each thread is equipped with spare thread queue heads in case it is not enqueued on a thread queue. The first thread enqueued on a thread queue will give its spare thread queue heads to that thread queue. The threads arriving at the queue will add their thread queue heads to the free chain of the queue heads provided by the first thread enqueued. Once a thread is dequeued it use the free chain to get new spare thread queue heads.
Uses a leading underscore in the structure name to allow forward declarations in standard header files provided by Newlib and GCC.
◆ Thread_queue_Priority_actions_operation
Parameters
[in]the_threadThe thread.
[in]queue_contextThe thread queue context providing the thread queue action set to perform. Returns the thread queue action set to perform on the thread queue owner or the empty set in case there is nothing to do.
◆ Thread_queue_Surrender_operation
This operation must dequeue and return the first thread on the queue.
Parameters
[in]headsThe thread queue heads. It must not be NULL.
[in]previous_ownerThe previous owner of the thread queue.
Returns
The previous first thread on the queue.
◆ Thread_queue_Deadlock_status
The operation did not detect a deadlock.
The operation detected a deadlock.
◆ _Thread_queue_Add_timeout_monotonic_timespec()
void _Thread_queue_Add_timeout_monotonic_timespec ( Thread_queue_Queue queue,
Thread_Control the_thread,
Per_CPU_Control cpu_self,
Thread_queue_Context queue_context
Parameters
queueThis parameter is unused.
[in,out]the_threadThe thread to add the timeout and set watchdog header to monotonic.
cpu_selfThe cpu to get the monotonic watchdog header from.
◆ _Thread_queue_Add_timeout_realtime_timespec()
void _Thread_queue_Add_timeout_realtime_timespec ( Thread_queue_Queue queue,
Parameters
[in,out]the_threadThe thread to add the timeout and set watchdog header to realtime.
cpu_selfThe cpu to get the realtime watchdog header from.
◆ _Thread_queue_Add_timeout_ticks()
void _Thread_queue_Add_timeout_ticks ( Thread_queue_Queue queue,
Parameters
[in,out]the_threadThe thread to add timeout ticks to.
cpu_selfThe cpu for the operation.
◆ _Thread_queue_Deadlock_fatal()
void _Thread_queue_Deadlock_fatal ( Thread_Control the_thread)
Parameters
the_threadThe thread for the operation.
◆ _Thread_queue_Deadlock_status()
void _Thread_queue_Deadlock_status ( Thread_Control the_thread)
Parameters
[out]the_threadThe thread to set the wait return code to STATUS_DEADLOCK.
◆ _Thread_queue_Do_nothing_priority_actions()
void _Thread_queue_Do_nothing_priority_actions ( Thread_queue_Queue queue,
Priority_Actions priority_actions
Parameters
queueis unused.
[out]priority_actionsis initialized so that no actions are performed.
◆ _Thread_queue_Enqueue()
void _Thread_queue_Enqueue ( Thread_queue_Queue queue,
const Thread_queue_Operations operations,
This enqueues the thread on the thread queue, blocks the thread, and optionally starts the thread timer in case the timeout discipline is not WATCHDOG_NO_TIMEOUT. Timeout discipline and value are in the queue_context.
The caller must be the owner of the thread queue lock. This function will release the thread queue lock and register it as the new thread lock. Thread dispatching is disabled before the thread queue lock is released. Thread dispatching is enabled once the sequence to block the thread is complete. The operation to enqueue the thread on the queue is protected by the thread queue lock. This makes it possible to use the thread queue lock to protect the state of objects embedding the thread queue and directly enter _Thread_queue_Enqueue() in case the thread must block.
The thread queue context must be set up with the following functions, otherwise the behaviour is unpredictable
  • _Thread_queue_Context_set_thread_state(),
  • _Thread_queue_Context_set_enqueue_callout() or _Thread_queue_Context_set_enqueue_do_nothing_extra() or _Thread_queue_Context_set_enqueue_timeout_ticks() or _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec() or _Thread_queue_Context_set_enqueue_timeout_realtime_timespec(),
  • _Thread_queue_Context_set_deadlock_callout().
#define MUTEX_TQ_OPERATIONS &_Thread_queue_Operations_priority
typedef struct {
} Mutex;
void _Mutex_Obtain( Mutex *mutex )
Thread_queue_Context queue_context;
Thread_Control *executing;
_Thread_queue_Context_initialize( &queue_context );
_Thread_queue_Acquire( &mutex->Queue, queue_context );
executing = _Thread_Executing;
if ( mutex->Queue.owner == NULL ) {
mutex->Queue.owner = executing;
_Thread_queue_Release( &mutex->Queue, queue_context );
} else {
&queue_context,
_Thread_queue_Context_set_enqueue_do_nothing_extra( &queue_context );
queue_context,
&mutex->Queue.Queue,
MUTEX_TQ_OPERATIONS,
executing,
&queue_context
#define STATES_WAITING_FOR_MUTEX
Definition: statesimpl.h:65
void _Thread_queue_Enqueue(Thread_queue_Queue *queue, const Thread_queue_Operations *operations, Thread_Control *the_thread, Thread_queue_Context *queue_context)
Definition: threadqenqueue.c:406
void _Thread_queue_Deadlock_fatal(Thread_Control *the_thread)
Definition: threadqenqueue.c:401
This header file provides interfaces of the Thread States which are only used by the implementation.
Definition: threadq.h:216
Definition: threadq.h:609
Definition: thread.h:812
Definition: mutex.h:4
This header file provides interfaces of the Thread Queue Handler which are only used by the implement...
Parameters
operationsThe thread queue operations.
[in,out]the_threadThe thread to enqueue.
[in,out]queue_contextThe thread queue context of the lock acquire.
◆ _Thread_queue_Enqueue_do_nothing_extra()
void _Thread_queue_Enqueue_do_nothing_extra ( Thread_queue_Queue queue,
Does nothing.
Parameters
the_threadThis parameter is unused.
cpu_selfThis parameter is unused.
queue_contextThis parameter is unused.
◆ _Thread_queue_Extract()
void _Thread_queue_Extract ( Thread_Control the_thread)
This routine removes the_thread its thread queue and cancels any timeouts associated with this blocking.
Parameters
[in,out]the_threadThe pointer to a thread control block that is to be removed
◆ _Thread_queue_Extract_locked()
bool _Thread_queue_Extract_locked ( Thread_queue_Queue queue,
The caller must be the owner of the thread queue lock. The thread queue lock is not released.
Parameters
[in,out]the_threadThe thread to extract.
[in,out]queue_contextThe thread queue context.
Returns
Returns the unblock indicator. True indicates, that this thread must be unblocked by the scheduler using _Thread_Remove_timer_and_unblock(), and false otherwise. In case false is returned, then the thread queue enqueue procedure was interrupted. Thus it will unblock itself and the thread wait information is no longer accessible, since this thread may already block on another resource in an SMP configuration.
◆ _Thread_queue_FIFO_enqueue()
void _Thread_queue_FIFO_enqueue ( Thread_queue_Queue queue,
Parameters
[in,out]queueis the thread queue.
[in,out]the_threadis the thread to enqueue.
[in,out]queue_contextis the thread queue context.
◆ _Thread_queue_FIFO_extract()
void _Thread_queue_FIFO_extract ( Thread_queue_Queue queue,
Parameters
[in,out]the_threadis the thread to extract.
◆ _Thread_queue_FIFO_first()
Thread_Control * _Thread_queue_FIFO_first ( const Thread_queue_Heads heads)
Parameters
◆ _Thread_queue_FIFO_surrender()
Thread_Control * _Thread_queue_FIFO_surrender ( Thread_queue_Queue queue,
Thread_queue_Heads heads,
Thread_Control previous_owner,
Parameters
[in,out]headsare heads of the thread queue.
previous_owneris unused.
Returns
◆ _Thread_queue_First()
Thread_Control * _Thread_queue_First ( Thread_queue_Control the_thread_queue,
Parameters
the_thread_queueThe thread queue.
Return values
firstThe first thread on the thread queue according to the enqueue order.
NULLNo thread is present on the thread queue.
◆ _Thread_queue_Flush_critical()
size_t _Thread_queue_Flush_critical ( Thread_queue_Queue queue,
This function iteratively extracts the first enqueued thread of the thread queue until the thread queue is empty or the filter function indicates a stop. The thread timers of the extracted threads are cancelled. The extracted threads are unblocked.
Parameters
filterThe filter functions is called for each thread to extract from the thread queue. It may be used to alter the thread under protection of the thread queue lock, for example to set the thread wait return code. The return value of the filter function controls if the thread queue flush operation should stop or continue.
Returns
The count of extracted threads.
◆ _Thread_queue_Flush_default_filter()
Thread_Control * _Thread_queue_Flush_default_filter ( Thread_Control the_thread,
Parameters
Return values
◆ _Thread_queue_Flush_status_object_was_deleted()
Thread_Control * _Thread_queue_Flush_status_object_was_deleted ( Thread_Control the_thread,
Sets the thread wait return code of the thread to STATUS_OBJECT_WAS_DELETED
Parameters
[out]the_threadThe thread to extract.
Return values
◆ _Thread_queue_Flush_status_unavailable()
Thread_Control * _Thread_queue_Flush_status_unavailable ( Thread_Control the_thread,
Sets the thread wait return code of the thread to STATUS_UNAVAILABLE.
Parameters
Return values
◆ _Thread_queue_Initialize()
void _Thread_queue_Initialize ( Thread_queue_Control the_thread_queue,
const char *  name
Parameters
[out]the_thread_queueThe thread queue control to initialize.
nameThe name for the_thread_queue.
◆ _Thread_queue_Object_initialize()
void _Thread_queue_Object_initialize ( Thread_queue_Control the_thread_queue)
The object must have the layout specified by Thread_queue_Object. It should be ensured with the THREAD_QUEUE_OBJECT_ASSERT() static assertion.
Parameters
[out]the_thread_queueThe thread queue.
◆ _Thread_queue_Queue_get_name_and_id()
size_t _Thread_queue_Queue_get_name_and_id ( const Thread_queue_Queue queue,
char *  buffer,
size_t  buffer_size,
Objects_Id id
Parameters
[out]bufferThe buffer for the thread queue name copy.
buffer_sizeThe buffer size in characters.
idThe object identifier in case the thread queue is embedded in an object with identifier, otherwise it is set to 0.
Returns
The length of the thread queue name. May be greater than or equal to the buffer size if truncation occurred.
◆ _Thread_queue_Resume()
void _Thread_queue_Resume ( Thread_queue_Queue queue,
This function makes the thread ready again. If necessary, the thread is unblocked and its thread timer removed.
The thread shall have been extracted from the thread queue or surrendered by the thread queue right before the call to this function. The caller shall be the owner of the thread queue lock.
Parameters
queueis the actual thread queue.
[in,out]the_threadis the thread to make ready and unblock.
◆ _Thread_queue_Surrender()
void _Thread_queue_Surrender ( Thread_queue_Queue queue,
Thread_queue_Context queue_context,
The owner of the thread queue must be set to NULL by the caller.
This function releases the thread queue lock. In addition it performs a thread dispatch if necessary.
Parameters
[in,out]queueThe actual thread queue.
previous_ownerThe previous owner thread surrendering the thread queue.
◆ _Thread_queue_Surrender_no_priority()
void _Thread_queue_Surrender_no_priority ( Thread_queue_Queue queue,
Parameters
◆ _Thread_queue_Surrender_priority_ceiling()
Status_Control _Thread_queue_Surrender_priority_ceiling ( Thread_queue_Queue queue,
Thread_Control executing,
Priority_Node ceiling_priority,
Parameters
Variable Documentation
◆ _Thread_queue_Object_name
const char _Thread_queue_Object_name[]
extern
See also
_Thread_queue_Object_initialize().
◆ _Thread_queue_Operations_default
extern
The default operations may be used by _Thread_Priority_apply() and _Thread_Continue() if the thread is not enqueued on a thread queue. The default operations do nothing.
