RTEMS 6.3
This group contains the Classic API implementation. More...
Topics | |
| Barrier Manager | |
| This group contains the Barrier Manager implementation. | |
| Cache Manager | |
| This group contains the Cache Manager implementation. | |
| Clock Manager | |
| This group contains the Clock Manager implementation. | |
| Directive Attributes | |
| This group contains the implementation to support directive attributes. | |
| Directive Options | |
| This group contains the implementation to support directive options. | |
| Directive Status | |
| This group contains the implementation to support directive status codes. | |
| Dual-Ported Memory Manager | |
| This group contains the Dual-Ported Memory Manager implementation. | |
| Event Manager | |
| This group contains the Event Manager implementation. | |
| I/O Manager | |
| This group contains the I/O Manager implementation. | |
| Interrupt Manager | |
| This group contains the Interrupt Manager implementation. | |
| Message Manager | |
| This group contains the Message Manager implementation. | |
| Object Services | |
| This group contains the Object Services implementation. | |
| Partition Manager | |
| This group contains the Partition Manager implementation. | |
| Rate Monotonic Manager | |
| This group contains the Rate Monotonic Manager implementation. | |
| Region Manager | |
| This group contains the Region Manager implementation. | |
| Scheduler Manager | |
| This group contains the Scheduler Manager implementation. | |
| Semaphore Manager | |
| This group contains the Semaphore Manager implementation. | |
| Signal Manager | |
| This group contains the Signal Manager implementation. | |
| Task Manager | |
| This group contains the Task Manager implementation. | |
| Task Modes | |
| This group contains the implementation to support task modes. | |
| Timer Manager | |
| This group contains the Timer Manager implementation. | |
| User Extensions Manager | |
| This group contains the User Extensions Manager implementation. | |
Files | |
| file | bsps/shared/rtems-version.c |
| This source file contains the implementation of rtems_board_support_package() and the definition of _RTEMS_version. | |
| file | bsps/shared/start/gettargethash-default.c |
| This source file contains the default implementation of rtems_get_target_hash(). | |
| file | cpukit/include/rtems/fatal.h |
| This header file defines the Fatal Error Manager API. | |
| file | cpukit/include/rtems/init.h |
| This header file defines the Initialization Manager API. | |
| file | cpukit/include/rtems/rtems/config.h |
| This header file provides parts of the application configuration information API. | |
| file | cpukit/include/rtems/rtems/intr.h |
| This header file defines the Interrupt Manager API. | |
| file | cpukit/include/rtems/rtems/mp.h |
| This header file defines the Multiprocessing Manager API. | |
| file | cpukit/include/rtems/rtems/options.h |
| This header file provides the Classic API directive options. | |
| file | cpukit/include/rtems/rtems/status.h |
| This header file provides the status codes of Classic API directives and support functions. | |
| file | cpukit/include/rtems/rtems/support.h |
| This header file defines support services of the API. | |
| file | cpukit/include/rtems/rtems/types.h |
| This header file provides types used by the Classic API. | |
| file | cpukit/rtems/src/getapiconfig.c |
| This source file contains the implementation of rtems_api_configuration_table(). | |
| file | cpukit/rtems/src/intrbody.c |
| This source file contains the implementation of directive bindings of the Interrupt Manager for languages other than C/C++. | |
| file | cpukit/rtems/src/intrcatch.c |
| This source file contains the implementation of rtems_interrupt_catch(). | |
| file | cpukit/rtems/src/modes.c |
| This source file contains the implementation of rtems_interrupt_level_body() and the definition of rtems_interrupt_mask to support languages other than C/C++. | |
| file | cpukit/rtems/src/mp.c |
| This source file contains the implementation to support the Classic API in multiprocessing (MP) configurations. | |
| file | cpukit/rtems/src/statustext.c |
| This source file contains the implementation of rtems_status_text(). | |
| file | cpukit/rtems/src/statustoerrno.c |
| This source file contains the implementation of rtems_status_code_to_errno(). | |
| file | cpukit/rtems/src/taskinitdefault.c |
| This source file contains a definition of _RTEMS_tasks_User_task_table without a task entry. | |
| file | cpukit/rtems/src/workspace.c |
| This source file contains the implementation of rtems_workspace_get_information(), rtems_workspace_allocate(), and rtems_workspace_free(). | |
| file | cpukit/rtems/src/workspacegreedy.c |
| This source file contains the implementation of rtems_workspace_greedy_allocate(), rtems_workspace_greedy_allocate_all_except_largest(), and rtems_workspace_greedy_free(). | |
| file | cpukit/sapi/src/exinit.c |
| This source file contains the definition of _Copyright_Notice, _Objects_Information_table, the flexible per-CPU data linker set limits, the system initialization linker set limits and the implementation of rtems_initialize_executive(). | |
| file | cpukit/sapi/src/exshutdown.c |
| This source file contains the implementation of rtems_shutdown_executive(). | |
| file | cpukit/sapi/src/fatal.c |
| This source file contains the implementation of rtems_fatal_error_occurred(). | |
| file | cpukit/sapi/src/fatalsrctext.c |
| This source file contains the implementation of rtems_fatal_source_text(). | |
| file | cpukit/sapi/src/getbuildlabel.c |
| This source file contains the implementation of rtems_get_build_label(). | |
| file | cpukit/sapi/src/getconfigmax.c |
| This source file contains the implementation of rtems_configuration_get_maximum_barriers(), rtems_configuration_get_maximum_extensions(), rtems_configuration_get_maximum_message_queues(), rtems_configuration_get_maximum_partitions(), rtems_configuration_get_maximum_periods(), rtems_configuration_get_maximum_ports(), rtems_configuration_get_maximum_regions(), rtems_configuration_get_maximum_semaphores(), rtems_configuration_get_maximum_tasks(), and rtems_configuration_get_maximum_timers(). | |
| file | cpukit/sapi/src/getcopyrightnotice.c |
| This source file contains the implementation of rtems_get_copyright_notice(). | |
| file | cpukit/sapi/src/getversionstring.c |
| This source file contains the implementation of rtems_get_version_string(). | |
| file | cpukit/sapi/src/interrtext.c |
| This source file contains the implementation of rtems_internal_error_text(). | |
| file | cpukit/sapi/src/sysinitverbose.c |
| This source file contains the implementation of _Sysinit_Verbose(). | |
| file | cpukit/sapi/src/version.c |
| This source file contains the implementation of rtems_version(), rtems_version_control_key(), rtems_version_major(), rtems_version_minor(), and rtems_version_revision(). | |
