RTEMS 6.3
getconfigmax.c File Reference
This source file contains the implementation of rtems_configuration_get_maximum_barriers(), rtems_configuration_get_maximum_extensions(), rtems_configuration_get_maximum_message_queues(), rtems_configuration_get_maximum_partitions(), rtems_configuration_get_maximum_periods(), rtems_configuration_get_maximum_ports(), rtems_configuration_get_maximum_regions(), rtems_configuration_get_maximum_semaphores(), rtems_configuration_get_maximum_tasks(), and rtems_configuration_get_maximum_timers(). More...
uint32_t rtems_configuration_get_maximum_barriers (void)
 Gets the resource number of Barrier Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_extensions (void)
 Gets the resource number of User Extensions Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_message_queues (void)
 Gets the resource number of Message Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_partitions (void)
 Gets the resource number of Partition Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_periods (void)
 Gets the resource number of Rate-Monotonic Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_ports (void)
 Gets the resource number of Dual-Ported Memory Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_regions (void)
 Gets the resource number of Region Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_semaphores (void)
 Gets the resource number of Semaphore Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_timers (void)
 Gets the resource number of Timer Manager objects configured for this application.
uint32_t rtems_configuration_get_maximum_tasks (void)
 Gets the resource number of Task Manager objects configured for this application.
