RTEMS 6.3
Scheduler Manager
This group contains the Scheduler Manager implementation. More...
file  cpukit/include/rtems/rtems/scheduler.h
 This header file defines the main parts of the Scheduler Manager API.
file  cpukit/rtems/src/scheduleraddprocessor.c
 This source file contains the implementation of rtems_scheduler_add_processor().
file  cpukit/rtems/src/schedulergetmaxprio.c
 This source file contains the implementation of rtems_scheduler_get_maximum_priority().
file  cpukit/rtems/src/schedulergetprocessor.c
 This source file contains the implementation of rtems_scheduler_get_processor() which may be used by binding for languages other than C/C++.
file  cpukit/rtems/src/schedulergetprocessormax.c
 This source file contains the implementation of rtems_scheduler_get_processor_maximum() which may be used by binding for languages other than C/C++.
file  cpukit/rtems/src/schedulergetprocessorset.c
 This source file contains the implementation of rtems_scheduler_get_processor_set().
file  cpukit/rtems/src/schedulerident.c
 This source file contains the implementation of rtems_scheduler_ident().
file  cpukit/rtems/src/scheduleridentbyprocessor.c
 This source file contains the implementation of rtems_scheduler_ident_by_processor().
file  cpukit/rtems/src/scheduleridentbyprocessorset.c
 This source file contains the implementation of rtems_scheduler_ident_by_processor_set().
file  cpukit/rtems/src/schedulermapfromposix.c
 This source file contains the implementation of rtems_scheduler_map_priority_from_posix().
file  cpukit/rtems/src/schedulermaptoposix.c
 This source file contains the implementation of rtems_scheduler_map_priority_to_posix().
file  cpukit/rtems/src/schedulerremoveprocessor.c
 This source file contains the implementation of rtems_scheduler_remove_processor().
