RTEMS 6.3
Directive Status Codes
This group contains the Classic API directive status codes and support functions. More...
#define RTEMS_STATUS_CODES_FIRST   RTEMS_SUCCESSFUL
 This constant represents the lowest valid value for a Classic API directive status code.
#define RTEMS_STATUS_CODES_LAST   RTEMS_PROXY_BLOCKING
 This constant represents the highest valid value for a Classic API directive status code.
enum  rtems_status_code {
  RTEMS_SUCCESSFUL = 0 , RTEMS_TASK_EXITTED = 1 , RTEMS_MP_NOT_CONFIGURED = 2 , RTEMS_INVALID_NAME = 3 ,
  RTEMS_INVALID_ID = 4 , RTEMS_TOO_MANY = 5 , RTEMS_TIMEOUT = 6 , RTEMS_OBJECT_WAS_DELETED = 7 ,
  RTEMS_INVALID_SIZE = 8 , RTEMS_INVALID_ADDRESS = 9 , RTEMS_INVALID_NUMBER = 10 , RTEMS_NOT_DEFINED = 11 ,
  RTEMS_RESOURCE_IN_USE = 12 , RTEMS_UNSATISFIED = 13 , RTEMS_INCORRECT_STATE = 14 , RTEMS_ALREADY_SUSPENDED = 15 ,
  RTEMS_ILLEGAL_ON_SELF = 16 , RTEMS_ILLEGAL_ON_REMOTE_OBJECT = 17 , RTEMS_CALLED_FROM_ISR = 18 , RTEMS_INVALID_PRIORITY = 19 ,
  RTEMS_INVALID_CLOCK = 20 , RTEMS_INVALID_NODE = 21 , RTEMS_NOT_CONFIGURED = 22 , RTEMS_NOT_OWNER_OF_RESOURCE = 23 ,
  RTEMS_NOT_IMPLEMENTED = 24 , RTEMS_INTERNAL_ERROR = 25 , RTEMS_NO_MEMORY = 26 , RTEMS_IO_ERROR = 27 ,
  RTEMS_INTERRUPTED = 28 , RTEMS_PROXY_BLOCKING = 29
 This enumeration provides status codes for directives of the Classic API. More...
int rtems_status_code_to_errno (rtems_status_code status_code)
 Maps the RTEMS status code to a POSIX error number.
const char * rtems_status_text (rtems_status_code status_code)
 Maps the status code to a descriptive text.
◆ rtems_status_code
RTEMS_SUCCESSFUL
This status code indicates successful completion of a requested operation.
RTEMS_TASK_EXITTED
This status code indicates that a thread exitted.
This status code indicates that multiprocessing was not configured.
RTEMS_INVALID_NAME
This status code indicates that an object name was invalid.
RTEMS_INVALID_ID
This status code indicates that an object identifier was invalid.
RTEMS_TOO_MANY
This status code indicates you have attempted to create too many instances of a particular object class.
RTEMS_TIMEOUT
This status code indicates that a blocking directive timed out.
This status code indicates the object was deleted while the thread was blocked waiting.
RTEMS_INVALID_SIZE
This status code indicates that a specified size was invalid.
This status code indicates that a specified address was invalid.
This status code indicates that a specified number was invalid.
RTEMS_NOT_DEFINED
This status code indicates that the item has not been initialized.
This status code indicates that the object still had resources in use.
RTEMS_UNSATISFIED
This status code indicates that the request was not satisfied.
This status code indicates that an object was in wrong state for the requested operation.
This status code indicates that the thread was already suspended.
This status code indicates that the operation was illegal on the calling thread.
This status code indicates that the operation was illegal on a remote object.
This status code indicates that the operation should not be called from this execution environment.
This status code indicates that an invalid thread priority was provided.
RTEMS_INVALID_CLOCK
This status code indicates that a specified date or time was invalid.
RTEMS_INVALID_NODE
This status code indicates that a specified node identifier was invalid.
This status code indicates that the directive was not configured.
This status code indicates that the caller was not the owner of the resource.
This status code indicates the directive or requested portion of the directive is not implemented.
This is a hint that you have stumbled across an opportunity to submit code to the RTEMS Project.
This status code indicates that an internal RTEMS inconsistency was detected.
RTEMS_NO_MEMORY
This status code indicates that the directive attempted to allocate memory but was unable to do so.
RTEMS_IO_ERROR
This status code indicates a device driver IO error.
RTEMS_INTERRUPTED
This status code is used internally by the implementation to indicate a blocking device driver call has been interrupted and should be reflected to the caller as interrupted.
This status code is used internally by the implementation when performing operations on behalf of remote tasks.
This is referred to as proxying operations and this status indicates that the operation could not be completed immediately and the proxy is blocking.
Notes
This status will not be returned to the user.
◆ rtems_status_code_to_errno()
int rtems_status_code_to_errno ( rtems_status_code status_code)
Parameters
status_codeis the status code to map.
Return values
0The status code was RTEMS_SUCCESSFUL.
EBADFThe status code was RTEMS_INVALID_NUMBER.
EBUSYThe status code was RTEMS_RESOURCE_IN_USE.
EINTRThe status code was RTEMS_INTERRUPTED.
EINVALThe status code was RTEMS_INVALID_CLOCK, RTEMS_INVALID_NAME, or RTEMS_INVALID_NODE.
EIOThe status code was RTEMS_ALREADY_SUSPENDED, RTEMS_CALLED_FROM_ISR, RTEMS_ILLEGAL_ON_REMOTE_OBJECT, RTEMS_ILLEGAL_ON_SELF, RTEMS_INCORRECT_STATE, RTEMS_INTERNAL_ERROR, RTEMS_INVALID_ADDRESS, RTEMS_INVALID_ID, RTEMS_INVALID_PRIORITY, RTEMS_INVALID_SIZE, RTEMS_IO_ERROR, RTEMS_MP_NOT_CONFIGURED, RTEMS_NOT_DEFINED, RTEMS_OBJECT_WAS_DELETED, RTEMS_PROXY_BLOCKING, RTEMS_TASK_EXITTED, or RTEMS_TOO_MANY.
ENODEVThe status code was RTEMS_UNSATISFIED.
ENOMEMThe status code was RTEMS_NO_MEMORY.
ENOSYSThe status code was RTEMS_NOT_CONFIGURED or RTEMS_NOT_IMPLEMENTED.
EPERMThe status code was RTEMS_NOT_OWNER_OF_RESOURCE.
ETIMEDOUTThe status code was RTEMS_TIMEOUT.
◆ rtems_status_text()
const char * rtems_status_text ( rtems_status_code status_code)
Parameters
status_codeis the status code.
The text for each status code is the enumerator constant.
Return values
?The status code is invalid.
Returns
Returns a text describing the status code, if the status code is valid.
