RTEMS  5.1
Macros | Enumerations | Functions
status.h File Reference
#define RTEMS_STATUS_CODES_FIRST   RTEMS_SUCCESSFUL
#define RTEMS_STATUS_CODES_LAST   RTEMS_PROXY_BLOCKING
enum  rtems_status_code {
  RTEMS_SUCCESSFUL = 0, RTEMS_TASK_EXITTED = 1, RTEMS_MP_NOT_CONFIGURED = 2, RTEMS_INVALID_NAME = 3,
  RTEMS_INVALID_ID = 4, RTEMS_TOO_MANY = 5, RTEMS_TIMEOUT = 6, RTEMS_OBJECT_WAS_DELETED = 7,
  RTEMS_INVALID_SIZE = 8, RTEMS_INVALID_ADDRESS = 9, RTEMS_INVALID_NUMBER = 10, RTEMS_NOT_DEFINED = 11,
  RTEMS_RESOURCE_IN_USE = 12, RTEMS_UNSATISFIED = 13, RTEMS_INCORRECT_STATE = 14, RTEMS_ALREADY_SUSPENDED = 15,
  RTEMS_ILLEGAL_ON_SELF = 16, RTEMS_ILLEGAL_ON_REMOTE_OBJECT = 17, RTEMS_CALLED_FROM_ISR = 18, RTEMS_INVALID_PRIORITY = 19,
  RTEMS_INVALID_CLOCK = 20, RTEMS_INVALID_NODE = 21, RTEMS_NOT_CONFIGURED = 22, RTEMS_NOT_OWNER_OF_RESOURCE = 23,
  RTEMS_NOT_IMPLEMENTED = 24, RTEMS_INTERNAL_ERROR = 25, RTEMS_NO_MEMORY = 26, RTEMS_IO_ERROR = 27,
  RTEMS_INTERRUPTED = 28, RTEMS_PROXY_BLOCKING = 29
 Classic API Status. More...
RTEMS_INLINE_ROUTINE bool rtems_is_status_successful (rtems_status_code code)
 Checks if the status code is equal to RTEMS_SUCCESSFUL. More...
RTEMS_INLINE_ROUTINE bool rtems_are_statuses_equal (rtems_status_code code1, rtems_status_code code2)
 Checks if the status code1 is equal to code2. More...
int rtems_status_code_to_errno (rtems_status_code sc)
 RTEMS Status Code to Errno Mapping Function. More...
const char * rtems_status_text (rtems_status_code code)
 Returns a text for a status code. More...
This include file contains the status codes returned from the executive directives.
