RTEMS  5.1
Files | Data Structures | Macros | Typedefs | Functions | Variables
Classic Timer Implementation
file  timerdata.h
 Classic Partition Manager Data Structures.
file  timerimpl.h
 Classic Timer Implementation.
struct  Timer_Control
struct  Timer_server_Control
#define TIMER_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Timer objects. More...
typedef struct Timer_server_Control Timer_server_Control
RTEMS_INLINE_ROUTINE Timer_Control_Timer_Allocate (void)
 Timer_Allocate. More...
RTEMS_INLINE_ROUTINE void _Timer_Free (Timer_Control *the_timer)
 Timer_Free. More...
RTEMS_INLINE_ROUTINE Timer_Control_Timer_Get (Objects_Id id, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE Per_CPU_Control_Timer_Acquire_critical (Timer_Control *the_timer, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Timer_Release (Per_CPU_Control *cpu, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE bool _Timer_Is_interval_class (Timer_Classes the_class)
RTEMS_INLINE_ROUTINE bool _Timer_Is_on_task_class (Timer_Classes the_class)
RTEMS_INLINE_ROUTINE Per_CPU_Watchdog_index _Timer_Watchdog_header_index (Timer_Classes the_class)
RTEMS_INLINE_ROUTINE Watchdog_Interval _Timer_Get_CPU_ticks (const Per_CPU_Control *cpu)
rtems_status_code _Timer_Fire (rtems_id id, rtems_interval interval, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
rtems_status_code _Timer_Fire_after (rtems_id id, rtems_interval ticks, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
rtems_status_code _Timer_Fire_when (rtems_id id, const rtems_time_of_day *wall_time, rtems_timer_service_routine_entry routine, void *user_data, Timer_Classes the_class, Watchdog_Service_routine_entry adaptor)
void _Timer_Cancel (Per_CPU_Control *cpu, Timer_Control *the_timer)
void _Timer_Routine_adaptor (Watchdog_Control *the_watchdog)
void _Timer_server_Routine_adaptor (Watchdog_Control *the_watchdog)
RTEMS_INLINE_ROUTINE void _Timer_server_Acquire_critical (Timer_server_Control *timer_server, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Timer_server_Release_critical (Timer_server_Control *timer_server, ISR_lock_Context *lock_context)
Objects_Information _Timer_Information
 The Classic Timer objects information.
Timer_server_Control *volatile _Timer_server
 Pointer to default timer server control block. More...
◆ TIMER_INFORMATION_DEFINE
#define TIMER_INFORMATION_DEFINE (   max)
Value:
_Timer, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_TIMERS, \
max, \
NULL \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: timerdata.h:41
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _Timer_Allocate()
RTEMS_INLINE_ROUTINE Timer_Control* _Timer_Allocate ( void  )
Timer_Allocate.
This function allocates a timer control block from the inactive chain of free timer control blocks.
◆ _Timer_Free()
RTEMS_INLINE_ROUTINE void _Timer_Free ( Timer_Control the_timer)
Timer_Free.
This routine frees a timer control block to the inactive chain of free timer control blocks.
Variable Documentation
◆ _Timer_server
Timer_server_Control* volatile _Timer_server
This value is NULL when the default timer server is not initialized.
