RTEMS
5.1
The information structure used to manage each API class of objects. More...
#include <objectdata.h>
Data Fields | |
Objects_Id | maximum_id |
This is the maximum valid ID of this object API class. More... | |
Objects_Control ** | local_table |
This points to the table of local object control blocks. More... | |
Objects_Control *(* | allocate )(Objects_Information *) |
Allocate an object. More... | |
void(* | deallocate )(Objects_Information *, Objects_Control *) |
Free an object. More... | |
Objects_Maximum | inactive |
This is the number of object control blocks on the inactive chain. More... | |
Objects_Maximum | objects_per_block |
This is the number of object control blocks in an allocation block. More... | |
uint16_t | object_size |
This is the size in bytes of each object control block. More... | |
uint16_t | name_length |
This is the maximum length of names. More... | |
Chain_Control | Inactive |
This is the chain of inactive object control blocks. More... | |
Objects_Maximum * | inactive_per_block |
This is the number of inactive object control blocks per allocation block. More... | |
Objects_Control ** | object_blocks |
This is a table to allocation blocks of object control blocks. More... | |
Objects_Control * | initial_objects |
This points to the object control blocks initially available. More... | |
If objects for the API class are configured, an instance of this structure is statically allocated and pre-initialized by OBJECTS_INFORMATION_DEFINE() through <rtems/confdefs.h>. The RTEMS library contains a statically allocated and pre-initialized instance for each API class providing zero objects, see OBJECTS_INFORMATION_DEFINE_ZERO().
Objects_Control*( * Objects_Information::allocate) (Objects_Information *) |
Allocate an object.
void( * Objects_Information::deallocate) (Objects_Information *, Objects_Control *) |
Free an object.
In case _Objects_Allocate_none() is used, then this may be the NULL pointer.
Objects_Maximum Objects_Information::inactive |
This member is only used if unlimited objects are configured for this API class. It is used to trigger calls to _Objects_Shrink_information() in _Objects_Free().
Chain_Control Objects_Information::Inactive |
This member is statically initialized to an empty chain. The _Objects_Initialize_information() will populate this chain with the object control blocks initially configured.
Objects_Maximum* Objects_Information::inactive_per_block |
It is only used if unlimited objects are configured for this API class.
Objects_Control* Objects_Information::initial_objects |
This member is statically initialized and read-only. In case objects for this API class are configured, it points to a statically allocated table of object control blocks defined by <rtems/confdefs.h>, otherwise this member is NULL.
Objects_Control** Objects_Information::local_table |
This member is statically initialized. In case objects for this API class are configured, it initially points to a statically allocated table defined by <rtems/confdefs.h>. _Objects_Extend_information() may replace the table with a larger one on demand.
Objects_Id Objects_Information::maximum_id |
This member is statically initialized and provides also the object API, class and multiprocessing node information.
It is used by _Objects_Get() to validate an object ID.
uint16_t Objects_Information::name_length |
This member is statically initialized and read-only. A length of zero indicates that this API class has a no string name (OBJECTS_NO_STRING_NAME).
Objects_Control** Objects_Information::object_blocks |
It is only used if unlimited objects are configured for this API class. The object control blocks extend and shrink by these allocation blocks.
uint16_t Objects_Information::object_size |
Objects_Maximum Objects_Information::objects_per_block |
This member is statically initialized and read-only. It is only used if unlimited objects are configured for this API class. It defines the count of object control blocks used to extend and shrink this API class.
