RTEMS
5.1
Per CPU Core Structure. More...
#include <percpu.h>
Data Fields | |
void * | interrupt_stack_low |
The interrupt stack low address for this processor. | |
void * | interrupt_stack_high |
The interrupt stack high address for this processor. | |
uint32_t | isr_nest_level |
uint32_t | isr_dispatch_disable |
Indicates if an ISR thread dispatch is disabled. More... | |
volatile uint32_t | thread_dispatch_disable_level |
The thread dispatch critical section nesting counter which is used to prevent context switches at inopportune moments. | |
volatile bool | dispatch_necessary |
This is set to true when this processor needs to run the thread dispatcher. More... | |
bool | reserved_for_executing_alignment [3] |
struct _Thread_Control * | executing |
This is the thread executing on this processor. More... | |
struct _Thread_Control * | heir |
This is the heir thread for this processor. More... | |
Timestamp_Control | cpu_usage_timestamp |
The CPU usage timestamp contains the time point of the last heir thread change or last CPU usage update of the executing thread of this processor. More... | |
struct { | |
uint64_t ticks | |
Protects all watchdog operations on this processor. More... | |
Watchdog_Header Header [PER_CPU_WATCHDOG_COUNT] | |
Header for watchdogs. More... | |
} | Watchdog |
Watchdog state for this processor. | |
struct Record_Control * | record |
Per_CPU_Stats | Stats |
This structure is used to hold per core state information.
Timestamp_Control Per_CPU_Control::cpu_usage_timestamp |
Protected by the scheduler lock.
volatile bool Per_CPU_Control::dispatch_necessary |
It is volatile since interrupts may alter this flag.
This member is not protected by a lock and must be accessed only by this processor. Code (e.g. scheduler and post-switch action requests) running on another processors must use an inter-processor interrupt to set the thread dispatch necessary indicator to true.
struct _Thread_Control* Per_CPU_Control::executing |
This member is not protected by a lock. The only writer is this processor.
On SMP configurations a thread may be registered as executing on more than one processor in case a thread migration is in progress. On SMP configurations use _Thread_Is_executing_on_a_processor() to figure out if a thread context is executing on a processor.
Watchdog_Header Per_CPU_Control::Header[PER_CPU_WATCHDOG_COUNT] |
struct _Thread_Control* Per_CPU_Control::heir |
This member is not protected by a lock. The only writer after multitasking start is the scheduler owning this processor. It is assumed that stores to pointers are atomic on all supported SMP architectures. The CPU port specific code (inter-processor interrupt handling and _CPU_SMP_Send_interrupt()) must guarantee that this processor observes the last value written.
A thread can be a heir on at most one processor in the system.
uint32_t Per_CPU_Control::isr_dispatch_disable |
This flag is context switched with each thread. It indicates that this thread has an interrupt stack frame on its stack. By using this flag, we can avoid nesting more interrupt dispatching attempts on a previously interrupted thread's stack.
uint32_t Per_CPU_Control::isr_nest_level |
This contains the current interrupt nesting level on this CPU.
uint64_t Per_CPU_Control::ticks |
Watchdog ticks on this processor used for monotonic clock watchdogs.
