| file | can-bittiming.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It defines structures used for bit timing representation and settings.
| file | can-bus.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It declares structures and functions used for CAN bus registration.
| file | can-devcommon.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It declares structures and functions used for controller's side of FIFO operations.
| file | can-filter.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It implements structure that represents filter for CAN frames.
| file | can-frame.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It implements CAN frame structure and related defines.
| file | can-helpers.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It implements functions and defines used to simplify controller's operations.
| file | can-impl.h [code] |
| | This file is part of CAN/CAN FD bus common support and implements internal functions for CAN queues handling.
| file | can-queue.h [code] |
| | This file is part of CAN/CAN FD bus common support and implements CAN FIFOs and generic hubs/ends for chip and caracter driver interface sides.
| file | can-stats.h [code] |
| | This header file is part of CAN/CAN FD bus common support. It implements controller's statistics.
| file | can-virtual.h [code] |
| | This file provides definitions for virtual CAN chip.
| file | can.h [code] |
| | This file is part of CAN/CAN FD bus common support and defines generic CAN structures used for common IO operations.
| file | ctucanfd.h [code] |
| | This header file contains the implementation of CTU CAN FD controller.
