RTEMS 7.0-rc1
can-bittiming.h File Reference
This header file is part of CAN/CAN FD bus common support. It defines structures used for bit timing representation and settings. More...
struct  rtems_can_bittiming_const
 This structure is used to represent CAN bit timing constants. More...
 This structure is used to represent CAN bit timing. More...
struct  rtems_can_set_bittiming
 This structure is used to set CAN bit timing values via IOCTL call. More...
struct  rtems_can_get_bittiming
 This structure is used to get CAN bit timing values via IOCTL call. More...
Bit Timing Type
#define RTEMS_CAN_BITTIME_NOMINAL   ( 0 )
 This define is used to select nominal bit timing.
#define RTEMS_CAN_BITTIME_DATA   ( 1 )
 This define is used to select data bit timing.
Bit Timing Source
#define RTEMS_CAN_BITTIME_FROM_BITRATE   ( 0 )
 This define is used to use bit timing calculation from bitrate.
#define RTEMS_CAN_BITTIME_FROM_PRECOMPUTED   ( 1 )
 This define is used to use bit timing from precomputed values.
Implementation is based on original LinCAN - Linux CAN bus driver Part of OrtCAN project https://ortcan.sourceforge.net/
