RTEMS 7.0-rc1
This header file is part of CAN/CAN FD bus common support. It declares structures and functions used for CAN bus registration. More...
#include <rtems.h>#include <stdint.h>#include <stdatomic.h>#include <sys/ioccom.h>#include <rtems/thread.h>Go to the source code of this file.
| struct | rtems_can_bus |
| This structure represents CAN bus device. This is the main structure passed throught file system during read/write/ioctl/close operations. More... | |
| int | rtems_can_bus_notify_chip_stop (struct rtems_can_chip *chip) |
| This function notifies all users the chip was stopped. | |
| int | rtems_can_bus_register (struct rtems_can_bus *bus, const char *bus_path) |
| This function registers CAN device into /dev namespace. | |
Implementation is based on original LinCAN - Linux CAN bus driver Part of OrtCAN project https://ortcan.sourceforge.net/
| int rtems_can_bus_notify_chip_stop | ( | struct rtems_can_chip * | chip | ) |
This should be called from the chip's stop function once all frames are either aborted or flushed from the FIFOs. It basically unblocks users waiting on a blocking read.
| chip | Pointer to rtems_can_chip structure. |
| int rtems_can_bus_register | ( | struct rtems_can_bus * | bus, |
| const char * | bus_path | ||
This should be called with already allocated rtems_can_bus structure and initialized controller to be registered.
| bus | Pointer to rtems_can_bus structure. |
| bus_path | Entire path to which the device should be registered (i.e /dev/can0, /dev/my_can etc.). |
