RTEMS 7.0-rc1
This header file is part of CAN/CAN FD bus common support. It implements functions and defines used to simplify controller's operations. More...
| #define | RTEMS_CAN_USER_MAGIC 0x05402033 |
| This define provides user magic value. It is used to check whether rtems_can_user structure was correctly initialized. | |
| #define | BIT(nr) (1UL << (nr)) |
| #define | GENMASK(h, l) (((~0UL) << (l)) & (~0UL >> (sizeof(long) * 8 - 1 - (h)))) |
| #define | __bf_shf(x) (__builtin_ffsll(x) - 1) |
| #define | FIELD_PREP(_mask, _val) |
| #define | FIELD_GET(_mask, _reg) |
Implementation is based on original LinCAN - Linux CAN bus driver Part of OrtCAN project https://ortcan.sourceforge.net/
| #define FIELD_GET | ( | _mask, | |
| _reg | |||
| #define FIELD_PREP | ( | _mask, | |
| _val | |||
