59#include <rtems/config.h>
85#if defined(RTEMS_MULTIPROCESSING)
This header file defines the Barrier Manager API.
This header file defines the Fatal Error Manager API.
This header file defines the IO Manager API.
This header file defines the Cache Manager API.
This header file defines the Clock Manager API.
This header file provides the Timer Manager API.
This header file defines the Dual-Ported Memory Manager API.
This header file defines the User Extensions Manager API.
This header file defines the parts of the Signal Manager API.
This header file provides types used by the Classic API.
This header file defines the Initialization Manager API.
This header file defines the Interrupt Manager API.
This header file defines the Message Manager API.
This header file defines the Multiprocessing Manager API.
This header file provides the Classic API directive options.
This header file provides the Partition Manager API.
This header file defines the Rate-Monotonic Manager API.
This header file defines the Region Manager API.
This header file provides the Object Services API.
This header file provides the Event Manager API.
This header file defines the main parts of the Scheduler Manager API.
This header file provides the status codes of Classic API directives and support functions.
This header file defines the Semaphore Manager API.
This header file defines support services of the API.
This header file defines the main parts of the Tasks Manager API.
