RTEMS 7.0-rc1
rtems_can_bus Struct Reference
This structure represents CAN bus device. This is the main structure passed throught file system during read/write/ioctl/close operations. More...
#include <can-bus.h>
struct rtems_can_chipchip
 This member holds the pointer to rtems_can_chip structure. Controller specific initialization function should fill this structure properly.
The structure should be allocated by the user in the application.
