RTEMS 7.0-rc1
rtems_can_chip Struct Reference
This structure represents one CAN controller. More...
#include <can-devcommon.h>
const char * type
 This member holds controller's type/name.
rtems_vector_number irq
 This member holds controller's interrupt number.
uint32_t freq
 This member holds controller's base clock frequency.
bool close_nonblock
 This member informs whether close operation is blocking or nonblocking. This can be set with RTEMS_CAN_CLOSE_NONBLOCK ioctl.
atomic_uint flags
 This member holds controller's flags.
atomic_uint used
 This member holds the number of users using the controller.
uint32_t ctrlmode
 This member holds the currently set mode. Controller's device driver may set initial modes if needed.
uint32_t ctrlmode_supported
 This member holds modes supported by the controller. Controller's device driver should set this field. Writing unsuported mode via RTEMS_CAN_CHIP_SET_MODE ioctl results in error.
uint32_t capabilities
 This member holds controller's capabilities.
rtems_mutex lock
 This member holds the lock to ensure atomicity of chip operations.
rtems_binary_semaphore stop_sem
 This member is used by the worker to notify the closed operation is finished.
const struct rtems_can_bittiming_constbittiming_const
 This member holds nominal bit timing constants (max/min values)
const struct rtems_can_bittiming_constdata_bittiming_const
 This member holds data bit timing constants (max/min values)
struct rtems_can_bittiming bittiming
 This member holds currently set nominal btt timing values.
struct rtems_can_bittiming data_bittiming
 This member holds currently set data btt timing values.
struct rtems_can_chip_ops chip_ops
 This member holds chip operations.
struct rtems_can_queue_ends_devqends_dev
 This member holds chip's side of queue ends.
struct rtems_can_user_list_t can_users
 This member holds the list of chip's users.
struct rtems_can_stats chip_stats
 This member holds the chip's statistics.
void * internal
 This member holds chip's specific private structure. This structure defines non generic fields and setting.
